Question about Samsung Office Equipment & Supplies
Paper j am samsung Xpress M2870FW
How do i sort out my jammed paper for my samsung multifunction xpress laser printer m2070w please
pull out the toner cartridges and see if paper wedged under the cartridges. Pull out the drum unit see if paper wedged under it.
Check back of printer . may may a cover where paper turns around may be jammed in this location also. check paper tray pull it out see if paper jammed at paper pickup point.
Check printer user manual for clues on how to clear paper jams
page 91
http://downloadcenter.samsung.com/content/UM/201512/20151210113455258/EN/english.pdf
Jul 03, 2016 | Samsung Office Equipment & Supplies
How can I enter the Tech Mode to reset the counters?
Imaging drum reset chip Ebay £15
http://www.ebay.co.uk/sch/i.html?_odkw=Imaging+Drum+reset+chip+for+Samsung+Xpress+SL+C410W+Xpress+SL+C460FW+SL+C460W&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XImaging+Drum+reset+chip+for+Samsung+Xpress.TRS0&_nkw=Imaging+Drum+reset+chip+for+Samsung+Xpress&_sacat=0
Mar 15, 2016 | Samsung Xpress SL-C460FW Laser...
Samsung SL-M2870FW Monochrome Laser All-in-One Printer(SL-M2870FW/XAC) won't turn on
Your power cord could be the problem unplug it and check it to see if the cord has been damaged. Also see if the port on your printer has dust or anything in it that could interfere with connection.
There should be a contact number for Samsung Troubleshooting and Repairs on your printer. Look on the bottom.
Good luck
Ellen
Oct 19, 2015 | Samsung Office Equipment & Supplies
How Do I Open Samsung Xpress M2070w printer machine to Remove Paperjam
Hi, pull out the toner and check if there's any paper sit in the path? Otherwise, you need to remove the front cover, both side cover then the back cover.
Feb 09, 2015 | Samsung Office Equipment & Supplies
Hello there. I have a Samsung C410W Printer which won't print and keeps giving me a "Paper Jam" error message, when there ISN'T one. It is out of Warranty, was bought secondhand, but it is relatively
You need to check all the flags in the paper path to ensure that they move freely. It is pretty common that when removing a paper jam that these little flags get knocked out of position.
Dec 08, 2014 | Samsung Xpress SL-C410W Laser Printer -...
Samsung c460fw factory reset - 1Q5A
What support do u want, not very clear
Oct 13, 2014 | Samsung Xpress SL-C460FW Laser...
Samsung Xpress M2875FD Laser reset firmware
download from samsung website,may use foll link:
http://www.samsung.com/uk/consumer/it/printer-multifunction/black-white-multifunction-printers/SL-M2875FD/SEE
Feb 12, 2014 | Samsung Xpress M2875FD Laser Multifunction...
Samsung how to
I NEED HELP WITH MY NEW TAB. I CAN'T GET IT TO PICK UP MY WEB SITE HELP
Jan 10, 2014 | Samsung Xpress SL-M2875FD Mono Laser...
61 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
