Question about Electrolux UltraActive Turbo Bagless Canister Vacuum - Tangerine
Heppa filter pops off when I turn the vacuum on
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 179 Answers
Did you replace the exhaust air diffuser? That's the plastic type vent housing the hepa filter was under.
Posted on Oct 18, 2013
Testimonial: "No the vacuum is only 1 year old. Is this a part that needs to be replaced?"
Dyson ball dc25 filter B keeps popping out
Hoover or dyson , can not be both
Jul 22, 2016 | Dyson DC25 Vacuum
Why does pressure release keeps going off in canister on dyson dc24 when turned on
Remove the filter in the ball and the filter in the hood. Turn on and if valve still pops off then you have a clogged hose or tube. If it's ok then one or both the filters are choked and require cleaning.
Jul 23, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Heppa filter keeps popping off when i turn on the vacum
Hi There, 99 times out of 100 this is due to the exhaust filter being too blocked for the air to actually get through. What happens is that the pressure in the motor increases and effectively blows the filter and filter cage clean off. If you have a look at the underside of the filter I would bet that it is very dirty and you will need to buy a new hepa filter
Oct 12, 2013 | Electrolux EL7055A Bagless Canister Vacuum
Hi My Hoover wind tunnel cyclonic stopped working when i was using it. I tried different plug even then it doesnt work . What to do??
If the motor stopped running, it most likely did because it was not being cooled, becuause something was stopping up the air flow. If you have cleaned the secondary filter out and it still stops while running, then remove the exhaust filter cartridge and try it then. If it does not stop running now, then the problem is the previous models like this had a foam filter as the exhaust filter, not a heppa cartridge filter. You will not hurt the machine by running it without the heppa cartridge. Cut a foam filter to fit to replace it. I do not think Hoover knows this yet.
I have a customer working on this problem today (Sept 2010) I have repaired machines for 30 years. This filter is meant to just catch the tiny particles from getting back into the air. However, it worked fine on the previous machines with the foam filter here instead of this Heppa cartridge.
Dave in Texas
Aug 31, 2010 | Dirt Devil Hoover Uh70085 Pet Cyclonic?...
E2 Rainbow vacuum motor protector
Some possible ideas:
Make sure the cone shaped air impeller does not have hair/thread/fibers wrapped around it. This will cause the motor to work harder, and trip the protector.
Make sure you are not overfilling the vacuum with water. If the water is touching the impeller, that will also cause it to move slower, and trip the protector.
Other than that, i'd have to examine it.
Hope that helps!
Nov 15, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Filter cleaning
use an air gun from a air compressor, that is what i use with mine-Lance
Oct 20, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Filter cleaning
the best thing to do is use an air gun off a compressor to blast all the dust out, that is what i do with mine.
Oct 20, 2009 | Vacuums
Water leaking from out of the heppa filter
Reasons for that to happen:
a) You have tilted the vac while vacuuming
b) Used the Rainbow without separator (basket like thing on the bottom of the motor)
c) Overfilled the rainbow tank with water (may have happened when shampooing with AquaMate)
Clean and install back the separator, remove HEPA, Set the Rainbow on empty water pan (with HEPA removed) turn it on for a while so everything will dry. Install new HEPA.
You will have to get a new HEPA filter (you can find them HERE)
Good Luck,
Rocky
Mar 18, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Hoover U5468-900 WindTunnel Supreme suction is suddenly poor
The other possibility is there is a blockage in the foot. these models have dual channel air flow (windtunnel) and become blocked when not cleaned depending on use. under the roller there is a cavity that can be removed for cleaning. a hot motor can be caused by poor air flow.
Mar 15, 2009 | Hoover U5453-900 WindTunnel Supreme Bagged...
Electrolux UltraActive Turbo Bagless Canister Vacuum - Tangerine Logo
88 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
