Question about GE Zoneline AZ55H07D Air Conditioner
Zoneline PTAC heat pump problems
We have 150 units with these systems in them and they have three issues that are most common.
1. The small internal fuse blows
2. The main circuit board fails
3. The reversing valve sticks
is there any way to prevent these issues are they common to these units? We seem to have about 10 percent per year fail and some are only 3-4 years old.
    Guru:
  • 1,524 Answers
Typical for those units
Posted on Apr 23, 2009
HOW TO TEST A COMPRESSOR
This is a bit complicated. Turn off power by unplugging it or turn off breaker/disconnect. On the comp you have 3 terminals, C, S, R. (Common start and run). You need to mark, label, or write down what wire goes to what terminal(red to run, black to common.....ect. Remove all 3 wires from the comp. Using a volt/ohm meter set to the ohms position, measure the resistance between common & start, common & run, run & start or C to S, C to R, R to S. All three readings should give a different reading. If all terminals are equal readings or if any terminal shows open or (infinite resistance) then the comp is damaged. Also test each terminal to ground by touching 1 lead to 1 terminal and the other lead to metal housing of unit ensuring you are touching metal and not paint. If any terminal shows a reading, other than infinite, to ground then the compressor is damaged.
Jun 01, 2015 | GE Zoneline In Wall Ptac Unit Air...
Heating and air unit electrical manual
http://www.geappliances.com/products/introductions/zoneline/literature.htm
Aug 20, 2014 | GE Zoneline In Wall Ptac Unit Air...
Ihave 50 ge ptac units that only the middle of evap.is getting cold
short of gas. Check for leak and arrest it. Then vacum and do gas charging.
Aug 18, 2012 | GE Zoneline In Wall Ptac Unit Air...
I have a zoneline ptac unit. The water keeps
They used to use a black rubber hose to run from the front to the back of the unit on the very bottom of the unit. You may also look for a styrofoam chute . Make sure the unit is sloped to the rear slightly.
Aug 18, 2009 | General Electric Zoneline® Deluxe Series...
Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Jan 23, 2009 | GE Zoneline AZ38H12DAD Split System Air...
GE Zoneline PTAC Leaking
Hi Julie,
Is this a newly installed unit? The problem sounds like the sleeve is improperly installed. The sleeve should slope approximately 1/4 inch downward from inside to outside. This way the water will run to the back of the pan where it will be picked up by the slinger fan, or drain to the outside. Most likely this is the cause, not the styrofoam pan. If you need further info, you can contact me at greg.mcnary(at)airdistributors.com (replace (at) with @) and I can get you detailed installation instructions.
Greg McNary
Air Distributors Company, Inc.
Distributors of GE Zoneline PTAC Units and
McQuay PTAC Units
Aug 06, 2008 | GE Zoneline AZ38H12DAD Split System Air...
How to best run this thing
Hi Laurelrobin,
When the unit is on "low fan", it is fan only, and is recirculating room air. If the damper is open, it can also bring in outside air. If the space is not occupied for extended periods, it's OK to turn the unit "OFF", as long as you have a newer unit with Heat Sentinel, and the Heat Sentinel is turned on. Heat Sentinel will not let the room temp get above 85F, as long as the unit is OFF. Also, in most cases it's best to keep the damper closed. You can check your owner's manual for more info on the Heat Sentinel and other auxiliary functions. I also have an article on the temperature limiting functions of the GE Zoneline.
Feel free to contact me at greg.mcnary(at)airdistributors.com if you need further info.
Greg McNary
Louisville, KY
Distributors for GE Zoneline PTAC Units, Zoneiare PTAC Units, and McQuay PTAC Units.
Aug 01, 2008 | GE Zoneline AZ38H12DAD Split System Air...
GE Zoneline AZ55H07D Air Conditioner Logo
605 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
