Question about Summit SEH4630 30" European 650 CFM range hood in stainless steel
Flashing light on Summit SEH4630 range hood - Summit SEH4630 30" European 650 CFM range hood in stainless steel
  • william fleming
    william fleming Oct 14, 2013
    More specifically there is a red blinking light on the power button for the halogen lights if i turn on the exhaust fan. Everything seems to work correctly, but this light started blinking not when the light is on by itself only when the exhaust fan is turned on.
Oven shut off and won't re-light
defective glow bar or bad safty valve. But if the glow bar does not light at all, most likely it will be a bad glow bar
Jul 09, 2014 | Summit WNM4307KW 36" Freestanding Gas...
Installing the 471106
I would say if you are going to make it functional by cutting a hole in your hood you leave them off if it is for show only they are block off plates so it does not get full of debris and keeps the wind out.
Apr 14, 2014 | Summit Racing Sum-471106:Racing Hood...
Nutone indicator lights flashing
I'd make a note of which lights are flashing & contact the manufacture for solution.
Nov 02, 2013 | Broan-NuTone Allure II QS230SS Kitchen...
Brian range hood model CJD130SS fan light on display flashes with fan off or on.
I believe that's the "change or clean filter" indication. Clean the aluminum filters in the dishwasher, replace the charcoal filters if non-ducted, press the fan light over 3 seconds and it should reset.
Sep 02, 2013 | Broan-NuTone Broan Elite E661...
I have a viking Professional range hood. While
FLASH covers a multitude of possibilities. What is the voltage of the blower motor. What you are describing often happens when 220 is wired to a 110 lighting circuit. I would not be running the blower motor although I hope it has inherent built in motor protection. If the voltage is applied higher to light bulbs they become flash bulbs. Florescents can become fire fixtures fast. If you are not an electrician back away from this and disconnect power at your breakers. Do not open up and trouble shoot if you are not qualified so you do not get embarrassed and have a dirt nap. It only takes about 40 vo;ts and a few milliamps cross chess to kill you. Also when ever you turn something on start and keep the habit of using one hand to turn it on and one hand to grab your pants behind you. OK OK or skirt. This prevents a cross chest shock . Old Navy (USN) death defeating rule that sved me many times and still. Remember call a pro when you do not know .
Dec 03, 2009 | Viking Kitchen Ranges
ISL93.IKSS range hood display flashes "A" and little/no suction
Check to see if your filter is plugged that will slow the air flow.
Oct 02, 2009 | Kitchen Ranges
Summit electric range overcooks bottom of baked goods
have it calibrated or get oven thermometer and figure differential yourself, say it runs 30 degrees hot etc
Aug 23, 2009 | Summit Appliances Division Professional...
Summit SEH4630 30" European 650 CFM range hood in stainless steel Logo
29 people viewed this question
Top Summit Dishwashers Experts
Owen Barnes
Are you a Summit Dishwasher Expert? Answer questions, earn points and help others
