Question about Garden
Replacing the speed cable on a Honda HRX217HYA push mower
2 Suggested Answers
  • 6468 Answers
SOURCE: Control cable to 3 speed HR215
you need to take apart the whole rear axle not fun to do
Posted on Aug 16, 2012
How do I fix the speed control on an Ariens walk behind lawn mower?
do you mean the throttle cable? as its a push mower im gussing it is. If the mower is relatively new then it will be fitted with an opc (or dead mans handle) in which case there is no need for a throttle control as the engine speed is governed and should only be used at the fixed goverened speed
Apr 08, 2016 | Ariens 21 In Classic Walk Behind Push Lawn...
My Honda HRC215 commercial mower goes very slow,how do i adjust it to make it go faster
Is your speed adjuster on the handle working properly? if not there should be a screw holding the cable on the engine Loosen that screw and push or pull to speed the engine then tighten back up.If that don't work there should be a spring coming out the to of the carb and if it speeds up when you push or pull it you can shorten or lengthen that spring. Which ever you need.
Nov 07, 2014 | Garden
Honda push mower
NEED BELT DIAGRAM FOR RANSOMES 956105 DECK
Jun 20, 2013 | Garden
Lawn mower idles low
Find a screw touching the linkage on the carb. Turn that screw to speed up the idle.
May 29, 2013 | Husqvarna 7021P 21-Inch 160cc Honda GCV160...
Aug 12, 2012 | Garden
The accelerator pedal is too hard to push and the mower barely goes. What can I do about this?
Sounds like a throttle cable to me might need replacing You should be able to move it by hand from the carb side if not it will need replacing
Jun 14, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
My Suffolk runs erratically at higher speed but when I try to reduce to idle it dies. I had it running half and hour in my work shop but when just about to start cutting it stopped. When running I pushed...
  • Carb jet/s filter and fuel bowl need cleaning. Also tank inside may need cleaning.
  • Air filter needs cleaning oe renewing,
  • Air fuel mixture screw adjustment required.
  • Governor spring need replacing or reconnecting.
  • Throttle cable connections and carburretor arm inspection and remedy.
Hope this helps.
Chris
May 10, 2011 | Garden
How to speed up motor on yardman self propelled lawnmower
You could disconnect the governor linkage at the carburetor and just connect the throttle cable (if it has one) directly to the butterfly plate on the carb. Aftermarket throttle cables (one size fits all) for push mowers are available. If you go this route, be careful not to over rev the motor (esp. when not under load) as you could possibly throw a rod or float a valve.
Aug 13, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Suddenly stopped then could not pull mower backwards because rear wheels would only go forwards, and mower would no longer start
Sounds like your mower has a safety mechanism that has locked up. On your push handle is a bar that must be pulled back in order to pull start cord, it has a cable that goes to the safety brake, check the cable to the safety brake on the flywheel, it may be broke. If it isn't in the safety brake itself, try spraying the cable with WD-40 as this may free it up. Or the cable may need replacing from wear. To check this pull back on the handle and watch the on the side of the engine where this cable attaches, if it is moving on the side of the engine then this cable won't be the problem. In this case it most likely will be the safety brake itself that's the problem. Do not remove the safety brake if under warranty as this will void your warranty.
Aug 08, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
