Question about Refrigerators
Beverage Air UR30GE Won't Get Cold.
I have turned the thermostat all the way cold. I have removed the cover and by-passed the thermostat. No luck. The evaporator and condenser fans are both running. The compressor is not kicking in consistently. I did hear it kick in after I moved it around and knocked on the relays around the compressor. Is there a replacement relay, sensor or capacitor on the compressor? A manual with schematics and exploded views would be helpful.
It is possible it is low on refrigerant!
Kicking and knocking parts wont help here.................there is a low pressure swith in the line and when the gas gets low ( a leak ) it protects the compressor by shutting down!
Since the pressure's fluctuate in a system when it is on and then off; it will cycle.
Posted on Aug 19, 2009
  • 209 Answers
If the thermostat has been bypassed it sounds like lack of refrigerant gas in the system. The level cant be checked visually, it will need to be checked by an engineer with pressure gauges.
Posted on Sep 28, 2007
Refrigerator not cooling; freezer fine
I don't know which model refrigerator you have but nearly all refrigerators cool the refrigerator section by passing cold air from the freezer section. Often the air passage will ice up so that the cold air can't get through. A thermostat controls the air flow,
That should be enough information to help you find the problem. You may have to remove some inner covers to find the problem.
Aug 03, 2014 | Admiral Refrigerators
Fridge is running but not getting cold. Line underneath feels very cold but air coming in fridge is not cold. Fan under the freezer and fridge is running.
If refrigerator is not cooling properly it can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer is bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to a bad defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
Hope this helps...please post back for further assistance.
Jul 17, 2011 | Refrigerators
My mt 12 cooler doesnt blow cold just warm air
thermostat could not be set properly, compressor could not be running, unit could be low on freon. start checking some items and let me know.
Aug 03, 2009 | Carrier Beverage Air® Marketeer® MT12-1-B...
Beverage air model UR30G, not cold, fan still running
check the thermostat for proper setting, evap could be frozen up, the condenser fan could not be running, unit could be low on freon. start check some items and let me know.
Jun 09, 2009 | Carrier Beverage-Air UR30GEFD Beverage...
No cold air
First unplug and remove front cover, straight wire the thermostat wires together and if it works replace thermostat. If not get back with me. Sea Breeze
Apr 24, 2009 | Heating & Cooling
Hello I am having a problem with my Beverage Air UCF48A Frezzer and was hoping you can help? The problem is this. When I first start the unit it works fine and gets cold fast but then the next day or so it...
You should check the defrost timer, it is located in the back, probably on the left. The timer can stick. Next time your unit is hot inside, remove the back and turn the defrost timer clockwise (there is a little knob that clicks when you turn it) see if the unit comes on then. If it does you will need to replace this timer. If not you may have a thermostat problem or possibly a refrigeration problem. The part # for the timer is 502-171A. The part # for thermostat, if needed, is 502-111A check on to see who your local parts supplier is.
Mar 27, 2009 | Carrier Beverage-Air Undercounter Freezer...
Refrigerator Keeps running
Replacing the thermostat should correct the problem. Be sure to install the thermstat exactly as the one you are removing, assuming it hasn't been changed prior. Hope this helps
Jun 10, 2008 | Beverage-Air Beverage Air KR48-IAS 44.9...
Refrigerators Logo
1,214 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
