Lg inverter air conditioner power light blinking
dgjtex
  • 405 Answers
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
Posted on Jan 14, 2009
  • 4 Answers
SOURCE: AIR CONDITIONER LG S18AN
The operating LED will be blinking 5 times, means that there is a
comunication error (serial comunication) between the outdoor and the indoor unit.
Posted on Jan 20, 2009
  • 400 Answers
SOURCE: LG Inverter Air Conditioner showing CH 02 what can I do?
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
Posted on Mar 04, 2009
  • 6 Answers
SOURCE: lg 12000 btu air conditioner inverter is not
This alarm state is a CH 06 alarm.
Indication for the Indoor unit pipe temperature sensor (thermister) not plugged in or out of calibration.
This alarm will also occur when the unit gas charge is to low and the indoor unit temperature reached a temperature of -5°C for longer that 30 sec. It will switch the machine off.
Posted on Mar 22, 2010
hvac1960
  • 2133 Answers
CH-02 Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
kOhm at 25C. If not replace sensor
Posted on Dec 28, 2010
Hi my lg inverter v is blinking lights when I switched on and not heating. when inspected out side, found the unit was buried in snow. so, I tried to switch on after clearing all snow and the fan too...
PDF]DEFINING COMMON ERROR CODES
www.lg-dfs.com/.../DFS-TP-AG-001-US_012H29_LGTechPaper_Error...
Aug 29, 2012 - Art Coolâ„¢ Mirror High-Efficiency Single Zone Systems ... Refer to Service Manuals posted on www.lg-dfs.com to troubleshoot ... Location of light-emitting... No. of Times Indoor Unit LEDs Blink ... Inverter compressor DC voltage is too high.... unit inverter compressor PCB heat sink temperature is too high.
[PDF]"Universal" Split Systems - LG Comfort Cooling
Jan 23, 2016 | LG Heating & Cooling
Error code for LG underceiling airconditioner
check error codes again LED 1 and LED 2. there is no 64 error code.
May 12, 2014 | LG Heating & Cooling
Power light blinking And no cold air coming out
most units have a diagnostic plate on door or manual that will tell you what blinks mean. steady blink is normal on some units.
Jan 20, 2014 | Heating & Cooling
Blinking power light
Make sure voltage and polarity is good
Dec 17, 2013 | LG Heating & Cooling
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
Hello, I have an LG Inverter Air Conditioner - LSR122V-4 and it is only turning on for 10 minutes at a time then switches itself off and the 'power indicator light' flashes slowly. Do you know what the...
Hello, I have an LG Inverter Air Conditioner - 24BTU and it is only turning on on the inside unit. When I look on the out side unit and I see a 'red light' on and no working.
Do you know what the problem could be?
Thanks,
Gil
Feb 03, 2011 | LG Heating & Cooling
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
