Question about Inc - 23OZ Rim WHL Cleaner T311
I have a dell xps model WHL and s/n DGPXQ31. When powered up, the monitor power button never changes from yellow to green, and there is nothing on the screen. How can I get it to come up to the point that I can troubleshoot the unit.
    Problem Solver:
  • 6 Answers
I wish to purchase pure nitrogen in Pretoria South Africa
Posted on Oct 12, 2013
Flashing green light on the circuit board. No power at all
I suggest it is the mother board or the power supply. Go to the Dell website on a friend's PC and download PDF manuals pertaining to your model. The battery may have enough power to light an LED.
Jan 08, 2014 | Dell Dimension XPS PC Desktop
Have an xps 200, monitor suddenly went black the other day in the middle of use. Noticed the power light had gone from green to amber. When I push button on monitor says it is in power save mode, to move...
Try connecting the monitor to a friend's computer. If you get some sort of a display it's not the problem. When you say that the computer makes a new noise like the fans are spinning fast, you might have an issue with the video card , motherboard, or power supply.
Aug 05, 2013 | Dell XPS 200 PC Desktop
Dell xps m140 press the power button green lights come on then go off nothing ever comes on screen
dead motherboard or power supply or powercord and or battery try another power cord if nothing take out battery and try to start with out battery if neither works then it will need either a motherboard or power supply
Oct 17, 2010 | Dell Inspiron XPS M140 Notebook
Friends computer just quit. Replaced power supply. No pwr up
Did you not wear an antistatic band? If not, you have killed your PC.
May 05, 2010 | Dell XPS 410 PC Desktop
Monitor stuck in Power Save Mode
yes look like your nvidia run out of juice you can look at nvidia 7200 le or maibe 8200 gs that will be a reasonable price / quality grafics cads for a upgrade of the 6800 thanks
Oct 19, 2009 | Dell XPS 400 PC Desktop
Dell e137fp monitor flashing green...
Below you will find my recommendations for troubleshooting this issue:
1. Reseat the power cord and verify a good power source.
To reseat the power cord, follow the steps below:
1.1 Power down the system.
1.2 Unplug the power cord.
1.3 Wait approximately one minute.
1.4 Reseat the power cord.
1.5 Verify that the power cord is plugged directly into a known good power outlet.
2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
To test the power outlet, perform the following steps:
2.1 Unplug the monitor power cable from the power outlet.
2.2 Plug in a different device, and verify that the device is operational.
2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
3. Verify the monitor is powered on and the power button is engaged.
Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
NOTE: There are two types of power switches:
A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
An electrical switch that has a short travel and almost no click.
A lit monitor LED can be any of the following:
* Green
* Blinking green
* Yellow
* Blinking yellow
* A combination, such as alternating green and yellow
Any of these states indicate the monitor is receiving power and that you should proceed.
4. Swap power cables.
To try a known good power cable on the monitor, follow the instructions below:
4.1 Turn off a working monitor.
4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
4.3 Unplug the cable from the monitor in question.
4.4 Plug in the cable that came from the working monitor.
5. Run the monitor self test.
To run the monitor self test, perform the following steps:
5.1 Power off both the computer and the monitor.
5.2 Unplug the video cable from the computer or video card.
5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
5.4 Power on the monitor.
NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
Jun 15, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor rejects computer
I'm just guessing, but it could be that the resolution you are using on your MS-DOS monitor is not compliant with the new monitor you are trying to use. Check the supported resolutions of the monitor that you would like to use, and then make sure you set that resolution before switching monitors.
May 10, 2009 | Computers & Internet
Cannot turn off monitor
It is problem with power settings. Start/Control Panel/Power Options -- and then pick a Power Scheme from the drop down list and make whatever modifications you want to the settings that power down your monitor
Feb 28, 2009 | Dell E196FP 19" LCD Monitor
Dell XPS 400 tower does not power up monitor?
The “self test” on the monitor displays when not plugged into a computer. This means that it’s working. The LED error code 2 and 4 means the video subsystem has a problem. Either your video card is bad or bad memory module. Try reseating video card and/or memory.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 26, 2008 | Dell XPS 200 PC Desktop
Inc - 23OZ Rim WHL Cleaner T311 Logo
56 people viewed this question
Top Turtle Wax Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Turtle Wax Vehicle Part and Accessory Expert? Answer questions, earn points and help others
