Termostat not opening when stove is warm - Heating & Cooling
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 53 Answers
Set temp 4 deg above
Posted on Oct 15, 2013
2012 Buick Lucerne overheating changed thermostat still overheats
look some cars have two thermostats. or it could be your waterpump not circulating water. check the belt that drives pump. test your termostat! take it out. connect a thin long wire to the top and plop it in your kettle while boiling. or into a small pot of water on the stove. when it gets hot enough you will see it open. no a little bit but alot. you can also checks its opening temperature to the previous one make sure they exactly the same. good luck
Jul 06, 2016 | Buick Cars & Trucks
Heater on 2001 Oldsmobile Van only warms up when I step on the gas. And it takes a very long time to warm up the first time each day.
Your thermostat is getting weak (Probaly)If it was never (Replaced) There is not a (Problem) With your temperture light comeing on while driving or the temperture gauge needle going higher then usaul. If the termostat was never changed,Try that first, Some times they stick open.End that can cause it to take for ever to warm up inside the vehicle.
Oct 25, 2012 | Cars & Trucks
How to change thermostat
The Termostat fit inside the Termostat Housing. It normally links to one of the radiator hoses leading from the engine block or radiator. Depending on the model you have, the termostat housing needs to be opened, the old termostat removed and the new termostat inserted. It's quiet simple. Before closing up, make sure that the both surfaces on the housing are clean and free from dirt and old sealant. If you remove a gasket, then replace with new gasket. If the housing takes a rubber O ring, then it is advisable to replace this.
Good Luck
Dec 29, 2011 | 2004 GMC Yukon
Heat is not coming up in the van at all
check the coolant level. if that is ok check the radiator hose after it warms up. is it hot to the touch? if not the termostat may not be opening. if so the heater valve may not be opening.
Jan 22, 2011 | 1993 Ford Econoline
What is making my van over heat
well depend on if is loosing coolant or not if not the first and cheaper is replade termostat . next may the catalyctic convertor is cloge i hope not expensive. if the van was over hot before may the water pump and termostat together
Dec 16, 2010 | Chevrolet Astro Cars & Trucks
I have a 1996 volkswagon jetta and I removed the thermostat but the temperature guage is still going pass half. Is there anyway to get the air out of the system and solve this overheating problem?
hallo
without termostat, start the car. in one minute ideling, both hoses from cooller should be warm.
If only top one is warm, check if the hose from front wather cooller to expansion tank is blocked (small one on top). usualy it is blocked on wather cooller itself .if OK, change wather pump.
also check if presure is bildinh inside wather sistem. that indicate head gasket or head itself should be checked
If you had remove the termostat, there can be no air inside the engine (if wather is inside).Even with termostat present, VW has no problem with air pockets.If your temp.go pass half when car is standing still, that is ok, but when driving must drop down.
Marko
Sep 23, 2009 | 1996 Volkswagen Jetta
Westinghouse stove
Turned the self cleaner on my electric stove although oven door at end of cleaning cycle would not open, it remained locked.
Would greatly appreciate any ideas.
Thanks
May 15, 2008 | Westinghouse Bethany Antique Brass- Indoor...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
