Question about Ovens
Whirlpool f 03 error code oven - Ovens
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: whirlpool wall oven error code
f3 generally relates to faulty oven sensor. thin rod in upper left hand corner of oven cavity held in by 2 screwa, easy enough to replace,
Posted on Feb 23, 2008
Error AM71 UI44 EEWET107 when I replug the oven broil does not work
Whirlpool RBD305PDS Electric Double Oven Repair ... - Fixya
www.fixya.com > Forum > Ovens > Whirlpool
Whirlpool Oven has an F1E1 error code. Whirlpool Ovens ' Answered on Nov 04 ...Whirlpool error code am71 ui44 eewet107 ยท Whirlpool Ovens ' Posted on Nov ...
Sep 12, 2015 | Ovens
Oven Whirlpool AKZ 223/IX/1 error code - F 03
Looks like a problem with oven temperature sensor. Some of these models have a thermal fuse which may need to be checked and reset if possible or replaced.
The sensor is not cheap. see site
WHIRLPOOL OVEN SENSOR TEMPER for AKZ223 IX 858522304000
Aug 06, 2014 | Whirlpool Ovens
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
What does F 03 on the display mean (my oven is not working)
Most Whirlpool ovens and F3 code is a failed temp sensor.
See this link:
http://www.applianceaid.com/oven_temp_sensors_help.html
and this one:
http://www.repairclinic.com/Fault-Codes
An oven too HOT indication is also F3 but the cause is still a failed temp sensor.
Thanks for choosing FixYa,
Kelly
Sep 23, 2011 | Whirlpool Ovens
Hi my whirpool oven is stating F 03 what do i have to do? Thanks
Usually the F-03 error code means you have a bad oven tempreture sensor. To test the tempreture sensor you would use a multimeter set to ohms. At room tempreture the sensor should read between 1000-1100 ohms any less then this and you would replace the oven tempreture sensor in the unit. If you have any further questions message me back. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
p.s I also looked afterwards in your service manual and the F-03 error code does refer to the oven tempreture sensor
Sep 13, 2011 | Whirlpool RBS275PD Electric Single Oven
WHIRLPOOL AKR 301 IS FLASHING O3 F Fault code
F-03 code indicates a failure with the temperature sensor. The sensor comes into the oven cavity on the back wall and is a little smaller than a pencil.
The most common reason for this error is a wire connection between the sensor and the control board. Try to measure the sensor with ohm meter, an read about 1080 ohms at room temperature if it is good.
Hope this helps.
Jul 20, 2011 | Whirlpool AKZ159IX Oven
My 16 month old whirlpool inegrated oven has a fault code F03 on screen. How can i fix this myself?
The F 03 code indicates a failure with the temperature sensor.
The sensor comes into the oven cavity on the back wall and is a little smaller than a pencil. The most common reason for this error is a wire connection between the sensor and the control board.
You can measure the sensor if you have access to a good ohm meter. It should read about 1080 ohms at room temperature if it is good.
Aug 01, 2010 | Ovens
F 03 fault on whirlpool double oven AKZ161
(F-03). This code represents a failed oven temperature sensor(RTD). Its open. You will have to replace this sensor to restore optimal performance.
please rate and god bless.
Mar 25, 2009 | Ovens
Whirlpool wall oven error code
Feb 20, 2008 | Ovens
Ovens Logo
18 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
