Question about Briggs & Stratton Garden
How to change the coil on a simplicity tractor the coronet series
Where is the coil on a simplicity lawn tractor the coronet series and how do I change it.
  • 69 Answers
SOURCE: HAVE A JOHN DEERE 318 LAWN TRACTOR, CHANGED POINTS
Check the coil impedance on the primary and secondary side. You'll have to disconnect the battery negative cable so you don't short something out. Unplug the spark plug wires and the two sets of smaller wires connected to the primary side of the coil. The primary coil reading should be between 3.7 ohms and 4.6 ohms while the secondary (spark plug side) should be between 34.2 k-ohms and 41.6 k-ohms. If the resistance values you measure are outside of these ranges, you need to replace the coil.
Posted on May 19, 2009
wadembly
  • 448 Answers
SOURCE: how do replace a belt on a simplicity lawn tractor 36''cut 4211-h
what kind of mower do you have
Posted on Jun 08, 2009
mowerman1857
  • 389 Answers
SOURCE: How do I chamnge the oil in my Craftsman lawn
There should be a pipe OR quick release valve coming out the right side at the bottom of the engine where it bolts to the frame. Most of the Craftsman riders I have worked on, had a long pipe with an elbow at the end of it and a plug in the bottom of the elbow for draining. Turn the wheels all the way to the left to allow enough room for a collection pan. It holds less than 2 quarts so the pan doesn't need to be too large
Posted on Sep 22, 2009
rwvanlue
  • 486 Answers
SOURCE: what year is my simplicity lawn tractor model
You are missing one digit on the model number, but I believe it to be a Regent 16hp 2001-2002
Posted on Nov 22, 2009
  • 27 Answers
SOURCE: My simplicity Coronet Hydro 13 lawn tractor loses
The fluid in the transmission is a multigrade oil. sometimes you can change the oil by removing the transmission partially or entirely and change the oil to a heavier grade like 15W40 or 20W50, the transmission has a vent mechanism on top that is where the oil would be extracted or drained from and then refilled, the level at full cold is 1" to 1 1/4" below the bottom edge of the inside of the vent pipe or plug boss. some of these had a flat vent plug, some have a hose with the vent in the end attached at a nipple and still some older units had a reservoir like on the larger tractors. The reason your trans is slowing is due to wear in the hydraulic pump face.
Posted on Jun 04, 2010
Engine just stopped. manual said that it could be a fuse where are fuses?
the whole wiring harness is pretty much under the seat shroud. it will be a blade type fuse if there is one. there's also a circuit breaker that is bolted to the starter solenoid. that may be bad. did you removed and reinstalled the battery then it wouldn't work?
Jun 17, 2015 | Simplicity "Coronet 30"" Briggs And...
5216 simplicity riding mower has gas going in with the oil
the needle and seat in the carb needs replaced. or if it has a vaccum operated fuel pump, the diaphragm may have a hole in it causing the gas to enter thru the pulse hose.take your air filter out and check to see if theres fuel puddling down inside the carb
Sep 30, 2014 | Simplicity "Coronet 30"" Briggs And...
Intech engine started smoking
Have had this happen and it was a head gasket
Sep 22, 2013 | Simplicity "Coronet 30"" Briggs And...
Intech briggs and stration started smokeing
check oil level, be careful not to over fill, drain gas, put fresh gas with cap full of fuel injector cleaner to offset eythenoyl gas .
My simplicity Coronet Hydro 13 lawn tractor loses power in the transition after about 20 minute run time. It has a sealed Hydro Gear box. Any suggestions to make it run better? It has a 30" Deck and a...
Jun 04, 2010 | Garden
I have a simplicity model 4211 lawn tractor with no spark.
terry, check for kill line on motor to see if grounded out,you can remove from ground clip.
also you say you checked points??????
check for flywheel to coil pickup clearance .
point type coil to flywheel the airgap should be 25- 1000ths with feeler guage. on electronic ignition coil to flywheel pickup the air gap should be set @ 10-1000ths with feeler guage. hope this solves your problem..........lemmee kno.....chris
Jun 07, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Garden Logo
100 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
