Question about Pride Jazzy Select Elite JSELECTE
Jazzy select elite- Continuous noise in left side drive motor. Not loud, more a growling noise. I yr. old chair
Check axle bearing no grease
Posted on Oct 20, 2013
Pride jazzy elite he power chair. I can't figure out how to put it in drive. It'll go in neutral. But when I switch the levers to r the lights just run a sequence on joystick then cuts off.
make sure the charger is disconnected from the chair. turn the power on, then push the horn button twice in row, within ten seconds of starting the Joystick. This will reset the lockout. Push on the chair to see if both motors are in the parked position, if one side moves then that side is not locked. both sides need to be locked in order for the chair to run. Strege Mobility
Feb 02, 2017 | Pride Health & Beauty
Can you make a jazzy select elite go faster than manufactured?
if it is not direct drive to the wheels --change the motor pulley/Cog and the driven pulley or cog ratios
but why would a person in a ,motorized wheel chair want to make it unstable by going faster
May 11, 2016 | Select Health & Beauty
My Jazzy Select 6 indicator lights flash 3 times then off and chair won't move. Both switches are in correct place and battery is charged.
Tamera,
Your left motor connection is shorting out to a battery connection. there maybe a bad wire on the left side motor. Strege Mobility
Mar 18, 2016 | Select Health & Beauty
Right wheel turns slower than left one causing chair to turn right only?
hi Robert, normally this is because of the motor on the left hand side either needs new brushes or the brake is not freeing 100% , at worse it is a joystick fault ... check the joystick connections.. and the connections to the left hand side motor
Regards
Rob
Oct 28, 2015 | Pride Jazzy 614 Hd JAZZY 614HD
What is making creaking squeeking noises in power chair?
hi, that noise can be caused by the seat mount moving slightly within the seat holder, because it 's a tight fitting when it does move slightly , you get the noise...only needs mm amounts of movement, Careful spraying WD40 in the gaps will solve this but take CARE making no electronics or electrics are near...disconnecting one battery will be ideal..
a visual inspection of all of the bolts and nuts should prove peace of mind...
WARNING: You need to tip over the power-chair to carry out the instructions set out below so extreme care is required.
This noise can also be caused by the motor gearbox ,, carefully place your hand on the gearbox as someone powers the chair , can you feel a grinding sensation ? , bear in mind you will get some feeling there of a dragging.
Regards
Rob
www.gewizrepairs.co.uk
Oct 10, 2014 | Pride Mobility Jazzy 614 - Jazzy Blue,...
De-sentizie controller on a jazzy elite
Yes, it is possible. If you take the chair to dealer who sells Pride, they should have a programmer available to change the settings on the joystick controller.
Aug 25, 2014 | Pride Mobility Jazzy Select Elite Power...
Cannot figure out how to take apart jazzy elite power chair for traveling
hi, you find all the information you require clicking on the link below.
http://www.pridemobility.com/resourcecenter/Downloads/Product_Owners_Manuals/product_owners_manuals.asp
Regards
GeWiz.
Feb 24, 2013 | Pride Mobility Jazzy Select Elite Power...
Jazzy select is swaying side to side when going forward like it has too much play in the joystick
Check your tire inflation and treads to make sure they can grip the floor/ground without slipping. Make sure that any keystock/keylock needed is installed on the axle, sometimes they slip out. Are your batteries fully charged and in good condition? Are you over the weight limit for the power chair?
Is there any noise or vibration coming from the power chair as you operate it? A grinding sound may indicate bad bearings in the caster wheels and cause problems in steering. A chirping sound may indicate a bad motor, they may be losing power and are not able to move the power chair evenly.
If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Oct 28, 2010 | Pride Jazzy Select 6 Indoor Power...
Pride Jazzy Select Elite JSELECTE Logo
140 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
