Question about Bosch 33614-2g 14.4v Brute Tough 1/2" Cordless Drill
Need to remove chuck on new BOSCH DDS181-02 18v cordless drill. No screw evident @ bottom of chuck-only small 1/16" hole. How do I remove chuck?
    Sergeant:
  • Bosch Expert
  • 206 Answers
There is supposed to be a Phillips head LH thread screw in the chuck. I have seen the screw head worn down so you can no longer get a screwdriver to work.
We usually cut the chuck off with a metal chop saw just at the screw - thread what remains of the chuck off, which usually leaves 1/4" of the screw sticking out of the spindle - remove with vise grips.
Its not an easy prospect when that happens.
Posted on Apr 17, 2014
  • Fred Hanadel
    Fred Hanadel Feb 07, 2015
    there is no screw and never was
2 Suggested Answers
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
How to remove a chuck off a GSB 18 V-Li Professional Bosch cordless drill . There seems to be a 1.5mm hole could be a hex drive. Can anyone please confirm.
probably will be a hex drive left hand thread screw in the bottom
The thread is LH to counter the RH thread of the chuck when using the drill in reverse
Mar 19, 2018 | Drills
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Feb 07, 2015 | Bosch 13618 - 2G 18V Brute Tough Cordless...
We need to replace the chuck on our Bosch corded drill 1005VSR. We need detailed instructions on how to remove the chuck . Also, how can we order a new chuck?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench 1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 15, 2011 | Bosch Drills
I have a Black & Decker 18V cordless drill with keyless chuck. The spot where the drill bit fits is in the open position stuck and won't turn in either position. What am I missing how to unlock it?
Look at the three jaws in the chuck,if on is further out than the others the you need to tap ti back into place with a small punch and a hammer.If this does not work then you need to replace the chuck,remove the screw at the bottom of the chuck[where you put the bit],then you will need to to clamp vise grip on the chuck and with it pointed away from you hit the vise grips with a hammer with a sharp blow downward and it should come off.Hope this helps.
Jun 12, 2010 | Black & Decker CD9602SB 9.6 Volt Cordless...
How to use hand drills?
Use of both is the same:
- loosen "chuck" (part where bit is installed).
- insert bit (hand tighen chuck so that bit is secured)
- tighten chuck securely with chuck tool, or by holding rotating chuck with hand and pulling trigger (GENTLY or you will shave off skin!)
- put drill in forward or reverse mode and pull trigger to inser or remove screw / drill hole.
ensure that battery is charged on cordless drilll.
squeeze connectors to remove and place in charger when battery is too low to operate drill.
Apr 27, 2010 | Bosch 14.4V Brute Tough Drill Kit
I have a Bosch PSR12 12V Cordless drill, but no instructions.
This drill has a keyless chuck. Put your bit in the chuck and hold the collar of the chuck while pressing the trigger in the forward position. To undo the chuck do this in reverse. You can also hand tighten the keyless chuck if you prefer. I have a 1/4' adapter that I keep in my drill so I can change bits quickly.
Sep 09, 2009 | Bosch Drills
How do i remove the chuck from the Makita 12v 6227D
There is a left handed screw down at the bottom of the chuck. I believe it is a flathead screw. You need to make sure you are in the lowest gear and turn that screw clockwise. It seems odd, but turning to the right will loosen the chuck screw. Once the chuck screw is removed then you need to remove the chuck from the spindle. Remove the chuck like a regular screw. It has regular threads and should be removed by turning it counterclockwise. Good luck
Sep 07, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
How to change the chuck on a draper red line 18v cordless drill
The screw you are trying to remove is left hand thread. You must turn is clockwise to remove it.
Hope this helps
Apr 15, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
I need to remove the chuck on my Bosch 33618 Brute cordless drill. How do I do it?
You must remove the inner chuck retaining bolt first, it is a torx screw and is left hand thread. once you have this screw out, get yourself a 1/2" allen key (the L kind). Chuck the short end in the chuck to grip it, use a mallet to hit on the long end (this will unthread the chuck). The spindle thread is regular Right hand thread. It may take a few good hits to knock it loose but it will come off.
Mar 31, 2009 | Bosch 33618 - 2G Factory - Reconditioned...
Bosch 18volt brute force cordless drill how do i remove chuck
Jan 31, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Bosch 33614-2g 14.4v Brute Tough 1/2" Cordless Drill Logo
678 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
Tim Venetis
Are you a Bosch Drill Expert? Answer questions, earn points and help others
