Question about Toshiba Televison & Video
Toshiba model 22dl834b no colour on dvd - Toshiba Televison & Video
My Toshiba model 56hm66 has suddenly become a black & white tv. Any suggestions???
Ask for a reduction in TV license fee!
Have you tried a game or DVD through the TV? If also B/W then it sounds like colour electronics have failed.
Apr 03, 2015 | Toshiba Televison & Video
What is the Remote Model for TOSHIBA Colour TV Model 2168TIV
In my opinion, you should not have to give them the remote number, but you can look this up by contacting the customer service website of Toshiba, giving them the model number of your tv..and explaining your situation...also check eBAY for remotes.
Sep 10, 2014 | Toshiba Televison & Video
DVD Playback is only Black & White
Different areas use different colour systems. The most common types being PAL and NTSC. What I think you might have done is changed the colour type setting to one that is not compatible with your TV. If you have the manual look up the colour settings. If you haven't got the manual look around the main menu for them. If all else fails use the factory reset.
Mar 12, 2017 | Toshiba Bdx1200 Blu-ray Disc Player
Toshiba Portege 7200 i try to fomat it it does no format why
Windows won't as a rule allow format of an older system onto a newer system, it goes into protect mode.
If you are trying to format the laptop with say XP and you have XP with SP3 installed, because SP3 is newer than XP it will try to stop you from destroying the newer system. Matbe you are running out of space?
Processor
Mobile Intel® Pentium® III processor at 600 MHz featuring Intel® SpeedStep™ technology, 256 KB 2nd level cache, 100 MHz Front Side Bus
Memory
Standard 64 MB SDRAM, expandable to 320 MB
Hard disk
12.0 GB1) capacity, S.M.A.R.T. hard disk
Internal video modes
1,024 x 768 x 16.7 million colours Display
13.3" (33.8 cm) TFT active matrix colour display
Battery
Removable lithium-ion battery, 2-3 hrs battery life, with extra high capacity battery up to 5 hrs
Size and Weight
297 x 241 x 25 mm, 2 kg
Diskette drive
External: 3.5" 1.44 MB/720 KB
DVD-ROM drive2)
6-speed (max) with optional DVD Network Dock II, 12 cm (5.25") and 8 cm (3.5") disks, data transfer 3,600 KB/sec, average access time: 140 ms
Graphics adaptor
128-bit graphics accelerator, SVGA-/VGA compatible, AGP bus, 64-bit BiTBlT, 4 MB internal Video RAM
External video modes
640 x 480 x 16.7 million colours,
800 x 600 x 16.7 million colours,
1,024 x 768 x 16.7 million colours,
1,280 x 1,024 x 65,536 colours,
1,600 x 1,200 x 65,536 colours
Up to 85 Hz refresh rate
Keyboard
86 keys, 12 function keys, 8 dedicated cursor keys, inlaid numeric keypad, 8 Hot Keys, 2 Windows® keys, AccuPoint™ II, Euro key
Sound System
16-bit stereo Sound Blaster Pro compatible, 3D-wide mode, MIDI & Wavetable synthesis, volume dial, built-in speaker and microphone
BIOS
ACPI (1.0b) enabled BIOS, SM BIOS V. 2.3
Expansion
2 x PC Card Type II or
1 x PC Card Type III, CardBus support, memory expansion slots
Communication
Integrated international V.90 modem (56 Kbps data, 14.4 Kbps fax)
Interfaces
FDD connector, external monitor, USB, Fast Infrared Port, I/O adaptor connector, RJ 11 modem jack, headphone, external microphone, slot for Kensington Cable Lock
With I/O Adaptor:
serial, parallel, PS/2™ mouse and keyboard
With Docking Station (DVD Network Dock II):
serial, parallel, external monitor, PS/2™ mouse and keyboard, video out (NTSC/PAL), line-in, line-out, integrated FDD, includes built-in Ethernet (Wake-On-LAN and Service Boot support), 6-speed DVD-ROM drive
Power supply
Autosensing 100-240 V AC adaptor for world-wide usage
Casework
Magnesium alloy
Bundled software
Windows® 95 and Windows® 98 selectable installation, Windows® NT 4.0 on request (limited language versions available), PC Card management software, Toshiba utilities and drivers (all pre-installed on the hard disk)
Bundled hardware
External diskette drive, autosensing AC adaptor, I/O adaptor
Special features
Toshiba Hibernation and Resume, Toshiba Power Extensions, System Password Securities, HDD password on request, SecureSleep™, LANDesk Client Manager (LDCM), Wake-On-LAN and Service Boot support (with manageability software and LAN chip), Recovery CD, 3-year international warranty
Options
DVD Network Dock II, carrying case, extra high capacity battery, battery charger, 32, 64, 128 and 256 MB memory modules
Dec 31, 2010 | Toshiba Portege 7200CT Notebook
We have reconnected our DVD to our new flatscreen and can see the picture, hear the sound but the picture is only black and white
This sounds like either the colour settings on the DVD are wrong for your new TV, or the TV has got the wrong setting for the socket that the DVD is connected to.
Go to the menu of the DVD first and look for picture settings etc. Or colour, keep your eyes peeled for the words PAL or NTSC.
Feb 06, 2010 | Toshiba SD-K770KU DVD Player
There is no colour on the movie
Make sure you have the cables hook up right. If you are running component mode it takes three for video blue red and white ends. If you are running composite it takes red, white, and yellow.
Nov 20, 2009 | Toshiba HD-A20
DVD PLAYER ONLY PLAYS IN BLACK IN WHITE
Tries diffirence outputs.Like with a S-Video cable or a HDMI cable.Mighht just change ur RCA cable see what happen.
Sep 02, 2009 | Toshiba 42H81 42" Rear Projection...
DVD Writer is not working
a yellow mark shows the drivers are not installed,
Oct 03, 2008 | Toshiba Satellite 5005-S504 Notebook
COLOUR MISMATCHING
befor going anywhere change vga cable between pc and projector.-and run video source from anywhere and check colour mismatch.if you got mismatch from both pc and video go to menu and make some correction to colour . if all failed you have to pass it to service center.
Jan 29, 2008 | Toshiba TDP-T90 Multimedia Projector
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
