Question about Singer 4423 Heavy Duty Sewing Machine
The thread from the bottom keeps bunching up - Singer 4423 Heavy Duty Sewing Machine
    Master:
  • 492 Answers
Adjust the tension on the machine
Posted on Oct 15, 2013
  • Donna Walton
    Donna Walton Nov 05, 2013
    Still is bunching up
  • seakish Nov 06, 2013
    Make sure your using a needle that is specific for sewing on leather. Just like sewing jeans, you need a pacific needle for a specific material.
My thread keeps looping on bottom Have changed tension, needle rethreaded and changed bobbin nothing helps what am I doing wrong?
not sure if this will help you...Check Your Tension Settings. Looping underneath the fabric usually occurs when there is not enough tension in the needle thread to pull the bobbin thread. Sometimesthread buching can be caused by something as simple as the tension dial being inadvertently turned.
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC ? ' eBay
www.ebay.co.uk/gds/WHY-IS-THREAD-BUNCHING-UNDERNEATH-MY.../g.html..
or you could go to this link and see if it helps you out.. thread keeps looping Google Search
Oct 22, 2017 | Sewing Machines
I checked my thread and bobbin watch the video and my machine keep bunches the bottom stitch
Is it really the bobbin thread that is bunching? Generally, thread messes under the fabric are the fault of the top thread, and thread messes on top of the fabric are a bobbin problem.
Top thread bunching under the fabric is called "thread nesting" or "bird nesting" but I prefer to call it thread "barfs." Most often, it occurs because the top thread has not been seated completely in the tension disk.
Install a brand new needle.
Remove the top thread from the machine.
RAISE the presser foot and rethread the top thread.
(Verify the thread path is correct.)
Set the top tension disk at the midway point.
Retest your machine. Tweak the top tension if required.
Mar 27, 2017 | Sewing Machines
I just bought a brand new Brother XL 2600I and it was working great for the first day , next morning i change the thread to actually sew not just test strips . I keep getting bunches of thread or if i
Most likely your top thread is not threaded correctly. Unthread and rethread. Check with your manual to make sure you have threaded correctly. Thread bunching up on bottom indicates top thread is threaded wrongly.
Mar 05, 2014 | Brother XL-2600I
Thread keeps bunching on the bottom of thick material
try a different needle
here's a link to a free manual from singer
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
some machine can't handle thick fabric & some can
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area
make sure the thread has not come off the thread take up lever
Aug 20, 2012 | Singer Curvy 8770 Electronic Sewing...
Thread keeps on bunching up on the bottom side of the fabric
try changing the needle
check the top thread tension to make sure it's not to loose
rethread the machine top & bobbin, make sure the bobbin is wound
correctly & inserted correctly into the machine
Jul 11, 2012 | Brother CS6000i Computerized Sewing...
Bobbon thread keeps bunching
then it's very possible that the machine is out of time & needs to be serviced
make sure the needle is in serted correctly--flat side to the back of the machine & all the way up into the needle holder
May 18, 2012 | Singer Sewing Machines
Keeps "birdnesting", besides rethreading, how do I fix?
when you have bunching on the bottom, you have a problem with the top thread: no tension. (and visa versa) Make sure the thread runs through the tension discs, these discs are activated when you put the presser foot down, so you want to thread the machine with the foot up, also feel if there no burrs, hooks, or whatever, so your top thread comes smooth off the spool, no jerking.
May 24, 2009 | Singer Sewing Machines
Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Jun 14, 2008 | Brother LS-1520 Mechanical Sewing Machine
Singer 4423 Heavy Duty Sewing Machine Logo
63 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
