Question about Turbo Air Refrigerators
I have a turbo air M3. The two top lids are not insalated. what can I do for this problem?
M3 turbo air freezer. M3F24-1 temp on display is not temp of box
this could be a bad temp sensor or lack of proper air flow. Make sure the evap fan runs when it's supposed to be running. Also make sure the evap is not freezing up. all these items can cause what you are describing.
Aug 06, 2016 | Turbo Air Refrigerators
Why it make loud sound like fan is thatching some metal when i plug in?
check the fan blade to make sure it is tight on shaft. also check to see if any of the fins are bent could be that they are hitting the housing of the fan motor.
Jun 07, 2014 | Turbo Air MUF-48 M3 Series 2 Door 48"...
Where is the IAT (Intake Air Temperature) sensor located on a 2002 2500HD with a 6.6 Duramax Diesel?
The intake air temperature sensor on a 6.6L diesel is part of the mass air flow sensor, located just outside the air filter housing, in the intake air snorkle going to the engine. The other one is for the turbo system and is located directly at the top of the engine in the inlet pipe for the turbo. This on is the intake temperature heater / sensor, and will set a totally different code relating to the turbo. The one you want is incorporated with the MAF sensor. Usually code P0101 sets.
Feb 06, 2011 | 2002 Chevrolet Silverado 2500HD
Need insructions for inserting a Turbo Tax disc. How is it done?
Insert the CD into your cd/dvd drive on your computer (print side up/shiny side down).
Close drive.
select Run from the autoplay menu that pops up, this will install Turbo Tax on your PC.
If autoplay does not start, open my computer and right click the drive with the disc in it, select auto play, then run or install.
after insallation you should have a icon on your desktop for Turbo Tax.
Let me know If this helps
Post as a reply or comment and I'll be notified.
Thank you
Feb 05, 2011 | ASUS Computers & Internet
Hello, we have a Miele cat and dog turbo 5000 vacuum cleaner which we bought in December. It has just started blowing air out of the grid on the top of the cleaner instead of sucking from the tube. The...
The lid not closing properly is almost certainly the cause of your problem. Without that lid sealed tight to the body you will get no suction through the hose. So, the question is: why isn't the lid clipping down properly? Did you just change the bag? You need to check that the bag is properly located and that there's nothing getting caught where it shouldn't be. Get the lid closing properly and your problem should be solved. Good luck!
Dec 29, 2009 | Vacuums
Say M3 on top left how to get rid of it?
It says that the M3 memory contains a non-zero value. To get rid of it store the value 0 in the M3 memory.
Bye
Oct 24, 2009 | Texas Instruments TI-30XA Calculator
Insalling m3 resl deal but cant find DS MENU .dat
apparently m3 dont do upgrades now but this might help http://www.m3-forums.net/viewtopic.php?f=4&t=312
basically it converts the r4 ds menu.dat to work on m3 simply (may work for m3 real) so now all you have to do is go to r4 download site and download latest version. 1.18 from here http://www.r4dscart.com/r4-software.html (select the english update) then patch ur dat file replace it back to where you took it from before patching and then copy all 4 files ( _system_ moonshi _ds_menu.dat _ds_mshl.nds) into the root of micro sd card. advise you to copy any files/games you have on your mem card then copy the games over to your newly installed firmware. oh by the way in the link i provided on how2 patch the ds_menu.dat it might be bit vague on where you put the ds_menu.dat file to patch it, all you do is drag and drop it into the PATCH app thats inside the "r4 to m3 patcher" folder. post a reply to let me know how you got on
Mar 27, 2009 | Nintendo DS Lite Console
Kenmore 90 series agitation problem
suppose to not spin unitl the lid is closed( safety reasons) the reason for the "weak agitation " is a bad set of agitator dogs. by removing the center fabric softener cup, you can get to and unscrew the center shaft bolt7/16. after removing the bolt, the agitaor will remove and the agitator dogs canbe replaced. part number 80040.youll need to split the agitator top and bottom to insall them . they simply slide into place.
Feb 14, 2009 | Whirlpool LSB6200PQ Top Load Washer
Refrigerators Logo
20 people viewed this question
Top Turbo Air Refrigerators Experts
Dennis Boxerman
ray gallant
John Tripp
John Tripp
Are you a Turbo Air Refrigerator Expert? Answer questions, earn points and help others
