Question about Refrigerators
Amana refrigerator srd 526s
The cold water has not pressure .
aborcass
  • 2651 Answers
SOURCE: Amana Side-by-Side Refrigerator Not Cold
can be a few things, if you open the freezer door do you hear afan running?? perhaps the fan is no good?? is there a large amount of frost on the lower plate of back wall of freezer??? very common issue to have a bad defrost thermostat.
Posted on Feb 19, 2009
farfield
  • 462 Answers
SOURCE: water from dispenser slows down while filling cup
If your water is slowing down the screen on the water valve may be stopped up or the filter (if it has one, when was it last changed?) or line feeding the refrigerator may be stopped up or the water valve its self may not be opening all the way and staying open.
To eliminate 3 of the external problems take the water line off the fridge and run some water into a pan and open and close water like at your kitchen sink and see if the water slows or speeds up noticeably while running into the pan. If so the problem is in the water line. While you have thew line off remove and inspect the water inlet valve screen and replace the hose washer (if so equipped) this brings your problem if you have not found it yet to the inside of the fridge. Usually on the corner of the door hinge the water line makes a turn up to the dispenser inspect it there and see if its twisted or kinked. Also there is a water resiviour inside the fridge look there for the same thing and possibley where food may have been forced agianst the line.
If you still dont find it by now I'D have to know what you did find and where.
If this helps you please rate me with as high a rating as you can and thank you for using fix ya.
Posted on Apr 20, 2009
woodchuck789
  • 4070 Answers
SOURCE: the cold water dispencer freezes in my amana
The water line runs through the door and this is where it freezes. It's usually defetive insulation. Other than replace the door you may can tape or other wise fasten more insulation to the inside of the door in the area you think it's freezing in.
Posted on Aug 26, 2009
Sheikhtijani
  • 1284 Answers
SOURCE: Proper refrigerant levels for Amana Side by Side refrigerator
Hi, normally the suction pressure on a refrigerant -22 system will be between 60 pounds gauge pressure (which keeps it above freezing point) and about 80 pounds. This depends on the temperature condition.Make sure that the superheat and subcooling are correct to see what is to be considered normal for the conditions you have present.
Take care
Posted on Jun 03, 2010
woodchuck789
  • 4070 Answers
SOURCE: How do you get to the water shut off in the door
The water in the door is controlled by the switch you push for water which opens the valve which is the water inlet valve on the rear of the fridge/freezer. It's where your water supply connects to the fridge on back. Yours is sticking open sometimes causing your problem. You need to replace the dual water inlet valve. Part 14 on this Diagram and parts list is your dual water inlet valve.
Posted on Apr 22, 2011
Amana ARB9058CB refrigerator water despenser weak and ice only half-sized
If your water pressure is good everywhere else in house, the refrigerator water valve is most likely causing your problem
Oct 26, 2017 | Refrigerators
Please how can i get a part for amana frige freezer model no srd 528 uw and serial no 9905167491
Try repairClinic.com . They carry a large selection of repair parts with detailed installation instructions. You'll need your model #, serial #, and year of manufacture.
Jan 04, 2011 | Amana Refrigerators
My daughter has an Amana side by side SRD 20S4W. Water/ice puddle on the inside bottom of the freezer section and periodically spill under the door and onto the floor. The problem started about a month...
Yes there is. You will need to remove the back panel to acess it. Try using a turkey baster with warm water or a wire. After clearing mix a 50-50 baking soda water solution and run it down the drain, this will help prevent future clogs.
Jul 27, 2010 | Refrigerators
Take care
Jun 03, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
