Question about Vacuums
Hoover windtunnel air model UH70400. How to replace the on off switch
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
SOURCE: hoover windtunnel U6476-910 switch doesn't work
What has worked for me on this vacuum is once the handle is off and the on-off switch is visible, work it back and forth manually.  Mine was very stiff and it did not get any better.   I went to radio shack and bought a spray can of Control/Contact Cleaner and Lubricant. It comes with a small piece of tubing.  I put the tube into the top edge of the switch and pushed the button FOR A FRACTION OF A SECOND and then did the bottom edge of the switch.   I worked the switch manually a couple of times.   I repeated the spraying one more time and the rocking.   I put it all back together and has been working fine for me.   This stuff is made for electrical contacts...  HOWEVER, use it very very sparingly!!!  ALSO, a new can has a bit of pressure so watch out that you don't blow some back at you.   JOE
Posted on Jan 19, 2009
  • 4 Answers
SOURCE: Belt replacement
No belt- it is motor driven. what happens to these if the rollers get stuck(by- say, a Lego® or something)  is the roller itself has an insert which will break, requiring roller replacement.
simple fix, but costs a little more than a belt. remove two screws holding the roller cover, accessible by flipping the vac over. then figure out which roller is broken, and remove the 2 outer screws on that side. pull the outer bearing cup assembly straight out to remove the rollers.
I have found the rollers as cheap as $3.50 ea/ for generic replacements. Also I reckon any Vac shop would have them on hand.
Posted on Apr 28, 2009
SOURCE: auto brush on hoover windtunnel doesn't spin anymore
I have a Windtunnel S3765 with the same problem - and it has very little use so I'm confident it isn't wear. I find that the wheels do not raise the agitator brush sufficiently high to reduce the drag caused by excessive contact with the carpet. If I raise the front a bit the brush spins as it should. It also works if I take the housing apart and use it without ..... but this is tricky.
Unfortunately I haven't figured out a way to hold it up efficiently. I am toying with afixing something to the bottom of the housing to raise the front enough to give the brush a little more room.
Posted on Jul 09, 2009
  • 8 Answers
SOURCE: Hoover Windtunnel shuts off
I found the following solution on this website. I have searched for hours and finally found this solution, it works! I HAD the same problem after cleaning the filter mentioned below, it is now working like it was new.
***by maverick_bea***
yes this machine has a thermal protector in it to shut off the machine if it gets to hot, this is normal. if there is no clogs in the hoses or in the machine then you will need to wash the filter at the top of the machine. you will have to remove the dirt cup and at the top you should see a half moon orange, well inside of this piece is the washable filter, clean and let it dry completly before putting back into machine. if this gets dirty and has not been cleaned, you can lose alot of suction. in some cases if this filter is not cleaned it can cause the machine to overheat so bad that it can damage the motor.
Posted on Oct 25, 2009
Replace power cord on Hoover windtunnel vacumm
There are many different models of Hoover Windtunnel so I can't be specific to your model, you will need to determine where the cord enters the unit and how to gain access to the internal wiring. Disconnect the old cord and attach the new cord using the proper connectors.
Apr 02, 2017 | Hoover Vacuums
How to install inside on/off switch on hoover windtunnel bagged sweeper
This switch is subject to a recall. Find a local Hoover service center and have it replaced. Completely Free.(YAY!)
Good Luck!
Aug 21, 2012 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Hoover WindTunnel Model # U6445-900. The on/off switch needs to be replaced and I'm not sure what parts are needed to repair it. Thanks Gloria
You can order any parts needed at the below link. This is a parts diagram. The switch kit doesn't have a part number here, but it's the second item on the list.
http://www.fiorijanitorial.com/p-447-hoover-windtunnel-parts-self-propelled-body-u6423-900-u6425-900-u6425-920-u6431-900-u6445-900.aspx
I recommend using the below site to order. It provides a clear picture of the switch kit.
http://www.sweeper-city.com/howiswkit.html
Mar 16, 2011 | Hoover Vacuums
I have a Hoover windtunnel, model U5470900. The on-off switch is broken. How do I order the parts and what is the instructions for replacing the switch?
I think this is a common problem, as the actual switch is located behind the cleaning tools caddy. The switch is toggled via a long, plastic rod connected to the thumb slider on the handle. It's a comically poor design. I'm not sure, but I think you'd have to replace the entire handle assembly if the slider no longer works. An easier solution is to simply plug the vacuum into a surge protector with an on/off switch.
Feb 13, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Windtunnel bagless vaccum model uh6000 on/off switch no longer working, must plug/unplug unit to use. Can switch be replaced?
Yes they can be replaced and are relatively easy to fit. In my opinion, Hoover are one of the best vacuum manufacturers when it comes to obtaining spares and you should have no problem getting one. I did a (very quick) search and this switch apparently fits all Windtunnel Hoovers:
If this doesn't look like your switch, I suggest calling the supplier to verify which part you need for your model. If you'd rather get one fitted for you, any competent appliance enginner or an authorised Hoover service centre should be able to obtain and fit the part easily. I wouldn't pay more than $20-25 in total as they take about 5-10 minutes to fit, max.
Nov 04, 2010 | Hoover Vacuums
Switch does not turn on or off on hoover windtunnel u458-910
Hoover windtunnel switches can be easily replaced by your local Hoover/Dirt Devil dealer. Have them check the model and serial number to see if yours is under a recall for this issue. You may also have a mechanical plastic rod problem (this operates the switch).
May 02, 2010 | Vacuums
Hoover windtunnel self-propelled - will not turn on
You probably need the switch replaced. It's fairly simple to do youself, and it is a known problem with these vacuums.
You can order the switch from hoover for about $10
Oct 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hi I have model u64330-900 hoover windtunnel. It
It sounds like your vacuums belt is stretched and worn. You'll need to replace it. Below is a link to a website that gives instructions with pictures on how to change the belt. You should be able to get a replacement belt at any department store or vacuum retailer.
I hope this helps you.
http://www.info-vacuum-cleaner.com/hoover-vac-belt.php
Sep 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U6434-900 WindTunnel Bagged Supreme
R U SURE THAT IT IS NOT JUST A SAFETY CUT OUT SWITCH , SOME MODELS HAVE A BLACK BUTTON BEHIND THE BRUSH HEAD DIFFICULT TO SEE SOMETIMES
Aug 17, 2008 | Hoover S3639 WindTunnel Bagged Canister...
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
