Ugo lite mobility scooter battery lights flashing and the scooter does not move
  • 103 Answers
SOURCE: battery indicater light just flashes and scooter
how many times do the lights flash?
Posted on Nov 10, 2009
  • 177 Answers
SOURCE: road knight mini, 3 wheel scooter, light flashes o...
Hi. Does the light flash a few times and then pause, and then repeat the flashing ? Count the flashes, it is a fault code. Do you have the fast/slow switch in slow? It might be a speed control fault. How old are the batteries? Might have a faulty motor. Faulty motor or battery leads and connectors. Go for a ride and then check if any of the plugs and sockets feel hot.
Posted on May 28, 2010
mcdevito75
  • 1970 Answers
SOURCE: Battery full on Ascot Mobility scooter but wont start
mcdevito75 here, Double chek the connection at the battery and motor.
Posted on Jun 26, 2010
FixinFax
  • 3085 Answers
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Posted on Jun 27, 2010
SOURCE: won't move lite on battery fully charged
I had this problem with the Cosco 4 wheel scooter. It turned out that one of the primary power lines under the shroud (back housing cover) was loose. It was not disconnected -- just loose. Apparently the loose connection would support enough current flow for the diagnostic circuit, but not enough to move the scooter (similar to using too small of a wire gauge in its effect). Once the power cable connector was tightened down so that the cable would not rotate on the connector, everything worked correctly.
The same symptoms could also be caused by a faulty power cable. If you have access to a multimeter, test the resistance along each cable path. If a path has an unusually high resistance, compared to the others, start to look for problems there.
Posted on Aug 31, 2011
The red ignition light on my careco mobility scooter elite keeps flashing then there is no way it will move battery is fully charged
hi Carol , Please count the flashes how many before it starts flashing again it should pause then start flashing again, this is really important... if it 's a continuous flash, that normally means low battery voltage...
Regards
Rob
Nov 14, 2015 | Elite Health & Beauty
Red lite flashes when i plug it in
I can only guess that the batteries need replaced .
Sep 05, 2015 | Rascal Auto Go 550 Portable Power Scooter...
DMA SCOOTER WONT MOVE ALTHOUGH BATTERY FULLY CHARGED
Are there any fault codes, flashing light. Check your user manual in the trouble shooting guide.
Have you disconnected charger from scooter as it will not move if it is still connected to scooter.
Apr 18, 2015 | Health & Beauty
The error lite on Buzzaround Lite scooter flashing
5 flash code is the electro magnetic Brake. This is referring to the brake on the motor that can be released by the freewheel lever.
1. place the freewheel lever into the free wheel position. Ensure the scooter is in free wheel and move the scooter forwards and backwards a few times.
2. Place the freewheel lever in drive position, push on scooter to ensure it is in drive and does not move. Turn on key and press the throttle. If you have the same code again, call a technician to check the brake, chances are it needs replaced.
Aug 25, 2014 | Health & Beauty
Wrench lite comes on and scooter will not move. I have checked the electric hook ups, all OK. I wiggled the control stick and it move for just a few feet. What could it be?
The wrench light indicates a problem count the number of flashes ie 4 flashes pause 4 flashes indicate a motor problem See my tips on flash codes. Once you get the flash code then you will have to get the chair repaired because there is no self fix for those errors Hope this helps
Jun 10, 2011 | Electric Mobility Invacare Pronto M41...
1997 PRIDE VICTORY GIVEN TO ME, BUT NEEDED FRESH BATTERIES PURCHASED NEW BATTERIES INSTALLED THE KEY, LITES & HORN WORK BUT UNIT WILL NOT MOVE FORWARD AND/OR BACK
check the freewheel lever on th rear of the chair near the right rear wheel if you can push the scooter easily then you are in freewheel locate the lever and move it to the drive mode and try to drive the scooter again if it still won't move then you have other problems that can only be checked by a service tech Hope this helps
Feb 26, 2011 | Pride Mobility Products Pride Mobility...
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
Not moving and green light is flashing
this is batteries
if slowed down first then stopped
mobility centre penge
Apr 14, 2010 | Golden Technologies Companion II Travel...
95 people viewed this question
k24674
jasbo
jasbo
