Question about Canon Pixma MP270 All-in-One InkJet Printer
My printer only prints half the width of the article
  • 3 Answers
The ink is less.
Posted on Oct 12, 2013
Printing half label width
hold feed button and release during 5 blinking lights. printer will auto set the width. Press feed again once you want the desired width.
If it's actual printer issue, then you have to call service tech.
Sep 23, 2013 | Zebra ZP 450 Thermal Label Printer
My new datamax printer is only printing half the label
Half in the print width? If so, there is an adjustment on the outside edge of the head carriage. There is a green know that will level the head across the platen.
Jan 06, 2011 | Datamax I-4208 Thermal Label Printer
Horizontal alignment ok, but right half not printing.
One of two situations exists:
1. If the printing stops with clear stopping edge, then the PRINT WIDTH setting has been changed from the default full width setting of 104mm.
Check this by pressing MENU and then the NEXT button until you see a setting for MAX WIDTH. It should be set to full width of 104mm. Anything less will stop printing beyond whatever the setting is. Change it back to the full width setting.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles that press down on the printhead and the pressure can be adjusted by moving the right toggle to the right so that more pressure falls on that side of the printhead.
Hope that helps !
Jul 20, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Half of the labels information is printing
I'm assuming you mean half is showing up as you go across the label. If that is the case and it's a very clear line where the print is cut off, then check the print width setting through the front panel of the printer. Press SETUP and look for setting called MAX WIDTH. It should be set to 104MM (4") which is the width of the print head. It is set to something smaller if the print is being cutoff.
If the print is fading away as you go across then that it is a print head balance issue. Look at the print head pressure dials on top of the print head assembly to make sure they are set evenly.
Hope that helps !
Apr 14, 2010 | Zebra Z4Mplus Label Printer
PRINTS ON ONLY HALF OF THE LABEL
If the printing clearly stops, then the maximum width setting of the printer is not set to the full 4 inches (104mm) of the printhead. Go into the setup mode on the printer and look for the setting called PRINT WIDTH and make sure it's set to 104mm or close to that. If printing is only half way across the label, it's because the width is set to something less than 104mm.
if the print fades away off the label, that is due to an imbalance in the pressure across the printhead.
Hope that helps !
Feb 18, 2010 | Zebra Z4Mplus Label Printer
The printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Feb 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
My epson rx420 only prints the left hand side of any document ??? Can any one help please . many thanks
have you set the page setup in document is same with page setup at print setup. Some new epson printer use paper sensor to measure the paper width. If page setup wider than actually paper inserted, the printer will print only half page. example : Your document 10 cm wide, page setup 20 cm, and you insert 10 cm paper wide. It will print only half of 10 cm, 5 cm.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Zebra TLP2844 Prints Centered and Half the Width
create a word template document with the page size the same size as the label. Set the margins to 0 and fill the label up with text. This should make the printer print right the way over the bale.
Nov 21, 2007 | Zebra Eltron TLP 2844 Thermal Label...
Printing half the page
Do you know I've had that sometimes- then it sorts itself out. Try Epson technical support on the web site. or www.fixyourownprinter.com
May 30, 2007 | Epson Stylus RX425 Multifunction...
Canon Pixma MP270 All-in-One InkJet Printer Logo
old marine
old marine
