Question about Mantis Gas Mini Tiller/Cultivator, 2 - Cycle
Mantis tiller no fuel getting through to the primer bulb
  • Rose Mccallum-jacobus
    Rose Mccallum-jacobus Apr 30, 2009
    We changed the line, the fuel filter and the primer ball with no results. The gas is still not getting through. Any other ideas?
  • Anonymous May 24, 2009
    cleaned everything, fresh fuel, new primer bubble. Still NO fuel getting into the primer bubble. Any Idea?
  • 3 Answers
The fuel line may be clogged or is collapsed go to a car or a home improvement store go to lawn and garden and get a 3-4 mm gas line
Posted on Apr 23, 2009
4 Suggested Answers
wadembly
  • 513 Answers
SOURCE: Mantis tiller won't start,does not seem to be getting any fuel in
if the primer bulb isn't filling up with gas when you push it the the diphram in the carb. behind bulb is bad needs to be replaced then it should work unless fuel lines are crossed or has holes in them
Posted on Jun 08, 2009
  • 17 Answers
SOURCE: Mantis tiller will not start.
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
Posted on May 24, 2011
  • 179 Answers
SOURCE: mantis tiller will not start
did it also run out of oil, because it seized like it did you might of burnt the engine
Posted on May 31, 2009
Just bought a carb kit. Which way does the diaphragm go in ? Also,the primer bulb won't show gas.
if the primer bulb cannot pick up fuel and the fuel lines are good then you have a bad primer plate and you need a new carb
Mar 25, 2015 | Mantis 2-Cycle Tiller
My mantis tiller with a honda gx22 engine starts then shuts off after approx. 30 sec.
If your unit has a primer bulb, start your engine . When it starts to die push your primer, if the engine comes back to life you have a carb issue.
Aug 09, 2014 | Mantis Tiller 4-Cycle Engine Handy Item...
Vapor lock on Mantis
check the fuel lines for a breakage or the primer bulb for a crack. Sounds like it is sucking air instead of fuel
Jan 06, 2013 | Mantis 2-Cycle Tiller
Cannot fill primer on mantis tiller
Check valve in primer body stuck with debris, cannot clean, buy replacement
May 23, 2012 | Mantis 2-Cycle Tiller
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Primer bulb dose not bring up fuel
cracked bulb or fuel line usually
Apr 11, 2010 | Mantis 2-Cycle Tiller
PUMPING THE PRIMER BULB DOES NOT WORK . HAVE RPLACED BULB AND FUEL LINES. NO SUCTION
the check valves in the plastic pump housing under the primer bulb are bad. Usually caused by cleaning with carb and choke cleaner. The part is available from any echo dealer. Most shops have a junk box full of them,, just ask
Oct 31, 2009 | Mantis 2-Cycle Tiller
Jun 08, 2009 | Mantis Tiller
Would like to know what year this tiller would be.
replace primer bulb. If that's not the problem check the float in the carb for pin holes . check fuel lines and intake line
May 15, 2009 | Mantis Tiller
Mantis Gas Mini Tiller/Cultivator, 2 - Cycle Logo
2,046 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
