Question about Dell Vostro 1520 Notebook
Biose bin file flashing - Dell Vostro 1520 Notebook
Flash bios file bin
here you go https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+945+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D945GCCR&ProdId=2766&LineId=2424&FamilyId=36
Jan 27, 2014 | Intel D945GCCR Motherboard
I dont kno the default 4ne code for my voda4ne 125 handset
hi
Carefully reading user manuals help in most of cases :)
Just use Read flash option. After reading complete, SagemEG will show you phone code. If not success, there is another option to get code - sent flash.bin to Support@SagDD.com.
Here is log of reset to default , read eeprom n read flash
COM3 [VCP0] selected
Device: ZTE-225
Checking data, wait...
Action: reset
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
flash chip supported
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20080118-132834.B1E.bin
loading data...
wrong database file: z225_eep65535.cfg
error: can't load database[11]
Reading [eeprom-sec]...
file saved: backup_eeprom-sec_20080118-132834.B1E.bin
Reading [eeprom-dyn]...
file saved: backup_eeprom-dyn_20080118-132836.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
error: set erase range
Write Failed
Finished, Remove/Install battery now !
Time used: 22 sec
Device: ZTE-225
Action: read eeprom
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133742.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133742.B1E.bin
file saved: backup_eeprom-dyn_20080118-133744.B1E.bin
Check memory...
Reading [eeprom-complete]...
file saved: backup_eeprom-complete_20080118-133750.B1E.bin
Completed
Time used: 21 sec
Device: ZTE-225
Action: read flash
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133815.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133816.B1E.bin
file saved: backup_eeprom-dyn_20080118-133818.B1E.bin
Check memory...
Reading [flash]...
file saved: backup_flash_20080118-134506.B1X.bin
Completed
Time used: 425 sec
I uploaded all files....
http://rapidshare.com/files/84702678/Vodafone_ztc-125_files.rar
Plz add this model in infinity software....Thx....for ratting
May 30, 2011 | Cell Phones
Bad Bios upgrade on Dell M1330
If you cannot start the laptop, you cannot flash the BIOS. You can ship the unit to me, and I'll recover the BIOS. You can email me at buffalonymann@yahoo.com
Nov 02, 2009 | Dell XPS M1330 Laptop
Foxconn 45cmx mainboard does not have any BIOS Update Enable/Disable jumper. When the CMOS RAM setting (BIOS Setup) Super Block Protect is disabled and a DOS based flash BIOS upgrade is attempted, the...
It depends on what bios the machine has, there are recovery procedures, atleast on laptop bioses. That when a set of keys is pressed it reads the bios image from a floppy or from a usb stick / cd and flashes the bios automatically.
Look online for Bios recovery (find out what bios you have, ami, phoenix, etc and then look for _____ bios recovery)
Oct 20, 2009 | Foxconn 45CMX socket LGA775 motherboard...
I want bios driver (bin file) for my intel destop board d915gav/d915pgn
The BIOS bin file is a BIOS upgrade file. It is used to flash the BIOS to upgrade the BIOS version.
This file is has to be downloaded from the motherboard manufacturer's WEB site.
Jul 24, 2009 | Intel D915GAV Motherboard
Gigabyte Motherboard wont flash bios
your bios has been corrupted.
The AWARD BIOS has a similar procedure to AMI. To recover an AWARD BIOS you will need to create a bootable floppy diskette and add the desired BIOS file (we recommend using the most recent). Award BIOS's generally are in .BIN format, where as AMI was .ROM format. You will also add an AWARD flash utility (usually awdflash.exe) and an AUTOEXEC.BAT file.
The AWARD BIOS does not automatically restore the BIOS information to the 'system block' like the AMI BIOS does. You will need to add the commands necessary to flash the BIOS in the AUTOEXEC.BAT file. The system will run the AUTOEXEC.BAT file, which contains the flash instructions.
Note: 12345678.BIN represents the name of your BIOS.
Step by Step:
1. Create a bootable floppy diskette or bootable dos cd /usb drive
2. Copy the BIOS file and flash utility to the disk
3. Create an text file with any standard text editor and add the following lines
@ECHO OFF
awdflash 12345678.BIN /py/sn/f/cc/r
Exchange the awdflash with the name of whatever flash utility you are using, and replace the 12345678.BIN with the name of the BIOS file you are using. The parameters are explained here:
py = program yes
sn = save no
f = flash
cc = clear cmos
r = reboot
Remove disk and restart computer
If you found this useful , please rate below
Kind Regards
1234s282
Jul 02, 2009 | Intel Gigabyte GA-8S648FX-RZ Socket 478...
SAHARA KN1 LAPTOP BIOS FLASH
flashing the bios is a tricky thing to do. basically you will find the file ( i do believe it is a .bin file) , u save on a CD along with an executable file, once you rebooted the computer, it will update it automaticall. some you might have to run the program, pointe it to the bin file, and tada, flashed. try this utility (SIW)
it will tell you what is the BIOS version, among of tons the other info. the utility is free.
there are other methods of flashing, but be careful, you try the wrong thing, and you motherboard is bye bye.
Jun 14, 2009 | Computers & Internet
How can i update bios
hiya
first goto the website of your board maker then download the updated bios, make a bootable floppy disk copy then exe file and the bios file it normally a .bin or .rom file when booted from the floppy run the flash utility with the exact name of the bios file so for instance it wud be
amiflash a123456.bin
hopw this helps
Rik
Feb 25, 2009 | Gigabyte Computers & Internet
Deleted .bin file on disk
you either you put it on wrong file, or the type of file the songs are might not be supported by your phone
Feb 23, 2009 | SanDisk 2GB microSD Memory Card
Trying to download a file
Hi and welcome to FixYa,
To my knowledge most (but not all) *.bin files are meant not to be directly opened by a user but be used by another program to update the firmware of a device. An example, the file 121208.bin is the BIOS version/file and a flashing software like AwardFlash.exe will use to update a motherboard.
In your particular case, I am venturing that the original file would be something like ...XYZ_V123_api_femu.zip which when you unzipped turned out to be ...XYZ_V123_api_femu.bin. This file would then have to be loaded to a device such as a satellite receiver or a cable decoder box. There is nothing a user can do to a *.bin file, rather, the user must point the flashing/updating program to where the *.bin file is stored. This can be accomplished by copying said file to a USB flash/thumbdrive that would be plugged into the USB port of the device (if it exists) or a known location/folder/directory into the computers HD.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 11, 2008 | Microsoft Office Professional 2007 Full...
Dell Vostro 1520 Notebook Logo
55 people viewed this question
Alun Cox
