Question about Belkin Flip (F1DF102P) KVM Switch
My belkin switch does not light up and when I switch on it doesn't work but when I unplug it from the port on the belkin it works. How can I fix it so I can just press the switch?
Screen resolution keeps switching
If its a usb kvm, check usb connections, one computer should stay fixed, the one that doesn't is your problem
Nov 21, 2011 | Belkin F1DF102PEA 2-port KVM Switch
My wireless light on my router doesn't light up, I been trying to access my router for internet for my phone and tried several things. Any ideas?
Easiest solution first: Unplug the router for 1 minute and plug it back in. See if it works.
Second solution: Log into the router via the built in ethernet switch and see if the wireless capability got switched off by itself (Rare, but it happens). Switch the wireless capability back on.
(BTW, is that the only light that does not light up?)
Jul 18, 2011 | Belkin F5D8236-4 Router
The ''wireless'' light on my wireless router is flashing amber
Contact Belkin for Care at 1-800-585-2494 Toll Free,,
Jan 09, 2010 | Belkin F5D8236-4 Router
How do i hook up my belkin f5d7230-4 router to hughes net internet when there is only one ethernet port?
Connect that one port to your Belkin WAN (Internet)connector (Yellow Port). The other ports go to other computers, to their Broadband RJ45 connectors.
Here's from the manual:
1. Unplug your existing modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router
2. Connect the new cable (provided in the box) to the yellow
port on the Router. Plug the other end into the modem.
G WIRELESS ROUTER Quick Installation Guide
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer (Windows®)
or the Finder (Mac OS® X) and double-click on the
“Setup Assistant” icon
Nov 15, 2009 | Belkin (F5D7230-4) Router (587009)
His speed 7 port USB hub not responding - green light for devices does not stay on and device is not present in Mac window Mac USB ports work directly replugged all connections with no success
If it has its own power then it should be OK however if you have 4 devices connected pulling too much load then it wont work - check the devices to see if this is the case. Unplug one at a time and see what happens
Hope this helps
Mark
Aug 20, 2009 | Belkin (B5U034) 4-Port USB Hub
Conect the router?
1. Unplug your DSL modem’s power supply.
the old router and plug it into the gray port on the new router.
port on the Router.
modem to start up.
4. Locate the CD in this guide and insert it into your computer.
If it doesn’t, open the CD in My Computer and double-click on the
“Setup Assistant” icon.It will guide you through he rest of the setup.
If you need more help please post back,If this help please rate as a fixya.
May 17, 2009 | Belkin (F5D72304F5D7000) Router
Components not recognised automatically with Belkin Switch2
This is not quite a solution, but a workaround. Take a USB cable extender and intercept the 5V supply wire in it (normally red) with a push to break switch. When you have powered up the PC, push the switch and the KVM will then work (same as your unplugging but much easier to do ). Switch bought on Ebay for 0.99GBP. Belkin tried to insist that I had my laptop plugged in and working if I wanted to use my desktop.
Feb 08, 2009 | Belkin F1DF102PEA 2-port KVM Switch
HELLO
First, try to reset the router. Hold the reset button at the back of the router for 20 seconds then unplug the power. Make sure the modem is off as well. While the modem and router are off, double check your physical connection. Make sure the modem is plug into the Internet port of the router and your PC to port number 1. Power on the modem first, wait for the lights to go solid then power on the router. Check if the internet works fine.
Hope that helps.
Sep 15, 2008 | Belkin Computers & Internet
Belkin Router 54g. On Sat night I switched it off at the plug momentarily. When I switched it on again - almost straight away, I'd lost total internet connection and the 'phone' light keeps flashing. In...
I would unplug the power to the router, and go through the steps to reinstall the router drivers..what should blink is the internet light and the port that you are using....
Jul 21, 2008 | Belkin Computers & Internet
Computers & Internet Logo
27 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
