Electrolux EWX14450W tripping the breaker randomly....anyone else had this problem? Thanks
2 Suggested Answers
  • 56 Answers
SOURCE: How fix blown element on Electrolux induction range?
If it's a year old and under a 5 year warranty then it will be covered under the warranty and shouldn't cost you a dime. If it happens again then speak to someone about getting a different range since you may have received a lemon.
Posted on Nov 01, 2012
My Zanussi ZTH485 condenser tumble dryer trips our electricity after it has been on for about an hour. The Electrolux repair man can't find anything wrong with it. What can I do now? Thank you.
call an electrician to check the amps draw for the machine when it is running ( they use an amp meter that clips around the wire for this) to the check the capacity of the breaker that is tripping
probably find that the breaker capacity is too close to the current draw and it takes very little additional current to trip.
he may consider the installation of a breaker with , say , 5 extra amps capacity, may fix the problem
Nov 22, 2016 | Electrolux Dryers
What is wrong with my electrolux model mf81522429 stove top The large regular burner will not shut off always on high tripped breaker to reset still comes back on high all other burners are ok
Hello friend, thank you for your post!
I understand that the large burner on your Electrolux range will not shut off. This could be a possible issue with the switch or control panel. Since it could be anyone of these underlying issues I would recommend contacting a professional technician for a proper diagnosis and repair. We hope this information is helpful to you. -Matt
Jan 17, 2016 | Electrolux Kitchen Ranges
Electrolux dishwasher tripping on drying cycle
Good Afternoon friend, thank you for your post!
From my understanding your Electrolux dishwasher is tripping your circuit breaker during the cycles. This could be a wiring issue within your dishwasher and you may need to have a professional technician come out. The technician will have the appropriate tools needed for pinpointing the issue within your dishwasher. Best of luck! -Matt
Feb 11, 2015 | Electrolux Dishwashers
My washing machine just turns white light on display but nothing to display and white background light also comes when i turn it 2 times on n off
Good Morning Friend,
I understand you are having trouble with the display on your Electrolux washer, model# EWX14450W. In researching your model number, I have determined that it was manufactured in the UK. I suggest contacting the manufacturer for further assistance. They should be able to point you in the right direction for having your display repaired. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Electrolux Washing Machines
Dishwasher trips mains
I understand that your Electrolux dishwasher, model# ESL4114, keeps tripping your main breaker. This appears to be a UK Electrolux dishwasher. I suggest contacting the manufacturer directly for further assistance. Hope this is helpful.
-Best Regards-
WP
May 17, 2014 | Electrolux 18 in. ESL4114 Slim-Line...
Electrolux washer dryer EWX14440W. It just seems to have died. No power, noise, lights, error codes or other signs of life. Can anyone advise where to start?
check fuse in plug ,check main circuit breaker tripped also do u have a neon switch on wall in room check this fuse also, to check scoket out let plug some thing else thats works to check out scoket out let
Aug 31, 2013 | Electrolux Washing Machines
Hi, I am having an issue with my Electrolux dishwasher which is causing a fuse to trip on my consumer unit. Is this likely to be the heating element or could it be something else? Many thanks.
Hello Nigel, thank you for your question. Often when a unit has been installed for a while and recently it starts to trip the breaker, it is typically due to a possible shorting on the unit or an issue with the breaker. Since the dishwasher will not complete the cycle, an actual diagnosis from an experienced tech would determine the precise cause to reduce the risk of unnecessary parts.
Aug 13, 2013 | Electrolux Dishwashers
Nov 01, 2012 | Kitchen Ranges
I have bedrooms with arc fault breakers in them. Randomly, the breaker will trip for no apparent reason. Usually only the lights are on in the bedroom, and nothing is plugged in to the outlets. The room...
If your arc fault breakers are tripping, then there is an arc developing somewhere along the line from the panelboard to the rooms that the breakers cover. If they are breaking in more than one room, then the fault lies in the lines somewhere between the panel and junction to these rooms.
You would have to trace the line from the panel to each light/outlet until you find the problem. Remember the arcing could be occurring anywhere, in the line, at the light, or at the outlet.
Your brother should be able to check each section of wire for continuity rather than ripping out all the wires in those circuits.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 27, 2011 | Siemens Seimens Arc Fault Breaker
I have a Electrolux EXC643 Oven. When you turn on the oven, set to 200 deg C for example, the oven fan and light works, but the oven stay's cold. The circuit breaker has not been tripped, at any point....
circular element is almost certainly open circuit. often the breaker will trip when element goes faulty but not always. take rear cover off and check for continuity
Jul 08, 2008 | Electrolux Kitchen Ranges
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
