Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
FIREWALL ON P2P
I am trying to get my p2p to connect i have tried everything absolutely everything...my isp doesn't block p2p and they told me i need to open up ports so that my p2p can work.
  • maxpowers Nov 14, 2007
    ditto
    my isp (Earthlink/Time Warner) does not block p2p but there doesn't seem to be any way to open ports on a RCA/Thomson DCM425
    perhaps that's why they use this router?
There is no firewall in this modem, it's just a modem working in bridged mode. So the problem is in your router (firewall or port forwarding) or the firewall on your computers.
Posted on May 24, 2008
SOURCE:
Computer is slow to connect whatever you are doing
First of all I would suggest you that contact with your ISP ( Internet Service Provider ) If they say: everything is fine! then perform these tips to fix your issue:-
- Update device drivers.
- Check your Preferred DNS address.
- Disable Firewall.
- If you have Free-trial antivirus then uninstall it.
- Uninstall p2p software's (uTorrent, BiTorrent, Team Viewer.)
- Optimize internet setting's (must use reliable program PC Fresher for best result.)
- Install latest Windows updates.
- Restart PC.
Oct 09, 2013 | Computers & Internet
Losing internet connection
- Disable Firewall.
- Restart PC
Sep 24, 2013 | Kaspersky Labs Computers & Internet
I can't connect to the internet
- Disable Firewall.
- Restart PC.
Sep 22, 2013 | Computers & Internet
Cannot connect to internet
- Disable Firewall.
- Restart PC.
Sep 08, 2013 | Computers & Internet
I am using my htc android's hotspot to power all of my wifi gadgets in my home. I just bought bunker Hill H.264 DVR security system and am trying to configure it to my phone for remote viewing. Please...
You need P2P Cloud Setup. DDNS Service will not work.
no option to port forward in mobile or mobile isp use firewall block users to access connect directly to internet.
Visit:- https://www.youtube.com/channel/UCxAhv5XWrbpjvdfVBVEHCMA
Mar 21, 2013 | D-Link Home Security
Belkin n150 download speeds are low
Low Download speed may be due to various conditions such as,
* If your Internet connection is shared with others on your LAN and they are using up all the available bandwidth. Tell them to knock it off
* Your ISP may be limiting your P2P traffic via some method of packet shaping. Call up the ISP and inquire if they do anything with P2P traffic.
* Check whether you haven set up your third party firewall or internet monitor software correctly.
* Your computer might have been infected with malicious software which altered the low level network settings of your operating system.
* You need to optimize your operating system for your current connection speed. First, close all P2P applications. Next run the DSLReports TweakTest. Once you have optimized it, then run a speed test at www.ScanMySpeed.Com This will give you a good idea what your maximum download and upload speeds are. If you're getting within 10% of your connection speed, that's the best you can get! If you are having trouble with your connection, and it relates to packet loss, excessive latency, or Internet or ISP congestion, running the Line Quality Test may help find the cause
Nov 24, 2012 | Belkin Connect N150 Wireless N Router
Luckywire isn't connecting. I tried redownloading it several times but it still doesn't connect. Help please!
Depending on your ISP, you may have blacklisted and blocked. Yes, your ISP can see what you're doing and shut you down if you're using a P2P and it's very easy to spot. My company acts as an agent for an ISP and we do it a dozen times per week at extended stay hotels.
Apr 25, 2011 | LuckyWire
Cant play online games
Here are few things that you can try:
1. update the firmware on the router/modem
2. Open ports on the router/modem for P2P
Jun 10, 2009 | NetGear DG834G Router
Do I need to open ports?
There are no ports to open on the DCM425, as it's a cable modem, not a firewall. Earthlink/Time Warner will likely not be truthful when it comes to blocking ports on their end. Would it be possible to change the port that your PS2 is using?
Same goes for the bittorrent question, only I'd switch to uTorrent and different ports as well.
Nov 14, 2007 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Can't use p2p programs with my 6211-I2
Make sure there is no firewall running. Even the windows xp firewall can screw up p2p applications.
Aug 17, 2007 | Zhone 6211-I3-200 Router
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
368 people viewed this question
Top RCA Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
