Question about Motorola Mobility P1002 Dect 6.0 Cordless Phone
I just bought a P1002 and every single time after 14 min of talk time it disconnects and hangs up and i have to redial and start another 14 min call...Whats the problem with that?Any help would be appreciated.thanks,Kathy
Perm Press cycle only runs for 2 min. and jumps to 14-15 min. every time.
find your manual and read it . sounds like the cycle has a 12 to 15 minute limit .
Feb 14, 2016 | Samsung DV330AE Dryer
I just purchased these phones and they will not keep a charge
1-888-331-3383
Mon-Fri 7:00AM-7:00PM CST
(Corded/Cordless Phone email)
Jul 13, 2014 | Motorola Mobility DECT 6.0 Cordless Phone...
Problem with Uniden wireless phone cutting off
The batteries are no good, though it may be new to you the set may have been around for 1-2 years before it was sold to you, and the batteries could be even older depending on where the company got the from, the best thing to do is to take them back for replacement under the one year manufacture warranty at the store you bought them, also if you replace the batteries at cost they will roughly cost about 32.39 with tax. To buy new batteries or attempt to fulfill the manufacture warranty--Good Luck.
Jan 31, 2013 | Lands Phones
MY PHONE REDIALS WHEN I'M GETTING A PHONE CALL
I purchased this phone yesterday, and I had the same problem. I went into the menu and the IPP was set to on. I turned it off and it does not try to redial now.
Jan 22, 2009 | Innovage 1604007 Corded Phone
Magic jack problem
I have a magic jack and I can talk for 10 minutes only or less and then i hangs up , this problem is happening in three majic jacks with other friends
please advise
Jan 15, 2009 | Lands Phones
Toshiba DKT2010-SD Phone
OK, model on bottom of phone is DKT2010-SD, but I found a little cheat card in a file for a STRATA DK8 & DK16 so I used a combination of things. First pick up handset and then hit intercom button, # 652 (for time or #651 for date) and enter time in HHMMSS (hour, minute, second) format, once complete hit the redial button.
Nov 03, 2008 | Toshiba DKT-2010 Corded Phone
I HAVE A PANASONIC FAX kx-FPG376 IT WONT SEND FAX MAKES COPIES AND RECIEVES FAXES
I dont know how we got disconnected but here is the instructions
Adjust the width of the document guides (1)
to fit the actual size of the document.
2 Insert the document (up to 10 pages) FACE
DOWN (2) until a single beep is heard and
the unit grasps the document.
L If the document guides are not adjusted
to fit the document, re-adjust them.
3 If necessary, press {A} or {B} repeatedly to
select the desired resolution.
4 Press {DIGITAL SP-PHONE}.
5 Dial the fax number.
6 When a fax tone is heard:
Press {FAX/START}.
When the other party answers your call:
Ask them to press their start button. When
the fax tone is heard, press {FAX/START
To redial the last number
1. Press {REDIAL/PAUSE}.
2. Press {SET}.
L If the line is busy, the unit will automatically
redial the number up to 2 times.
L To cancel redialing, press {STOP}.
To send more than 10 pages at a time
Insert the first 10 pages of the document. Add
the other pages (up to 10 at a time) before the
last page feeds into the unit.
Pre-dialing a fax number
You can dial the fax number first before inserting
the document. This is convenient if you need to
refer to the document for the other party’s fax
number.
1. Enter the fax number.
2. Insert the document.
3. Press {FAX/START}.
Sending from memory (Quick scan feature)
You can scan the document into memory before
sending it. To use this feature, activate feature
#34 (page 62).
1. Insert the document.
2. Enter the fax number.
L The document will be fed into the unit and
scanned into memory. The unit will then
transmit the data. If the document exceeds
the memory capacity, transmission will be
canceled and this feature will be turned OFF
automatically. You must transmit the entire
document manually.
L This feature cannot be used if {DIGITAL SPPHONE},
{TALK} or {SP-PHONE} is
pressed.
To stop transmission
Press {STOP}.
Aug 27, 2008 | Panasonic Office Equipment & Supplies
NEC DTERM 80 PHONE
After dailing the number in the first time, hang up and take the phone back off the hook. Then press the redial button and it should work.
Aug 18, 2008 | Lands Phones
Need to set my time on my phone
I think this feature is dependent on your system - the phone display is in agreement with the entire network. Check to see what system your phone is on - ours is a Strata DK-280 - and then search Google to find a total solution to changing time.
Dec 07, 2007 | Toshiba DKT-2020 Corded Phone
Handsets bypassed; need to restore
I found some old notes of mine you could try, but they're involved: 1. [Spkr],#,603,500,[Speed Dial],[Redial],[Spkr],pick up hand set, hang up. 2. [Spkr],#,656,9,phone extension,[Redial],[Spkr],pick up hand set, hang up. 2. [Spkr],#,657,#,phone extension,[Redial],[Spkr],pick up hand set, hang up. Were you able to find a free manual online? Pat
Feb 20, 2007 | Toshiba DKT-2010 Corded Phone
Motorola Mobility P1002 Dect 6.0 Cordless Phone Logo
Top Motorola Mobility Lands Phones Experts
john h
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
