Question about Avanti FF8SSR Top Freezer Refrigerator
Water is accumulating inside fridge, under the vegetable drawer until it leaks out of the door on the floor
I have an Avanti, top freezer refrigerator for tha last 3 years (model FF8SSR/FF8WR. For some reason water accumulates at the bottom of the fridge under the veg. drawer. Over time the water gets high enough to leak out of the door on to the floor. Anything I can do?
  • 198 Answers
SOURCE: water accumulation under vegetable drawer model
its the problem of the compressor present in your fridge... if its malfunctioning, then water wil accumulate under the vegetable tray
Posted on Jun 17, 2008
mgprice
  • 744 Answers
SOURCE: I have a sub zero 611 and water is accumulating
sounds like you have a blocked drain tube....when defrost system kicks in the melted water runs down a tube into a tray adjacent to the compressor and is evaporated by the heat. when the tube becomes blocked the water has nowhere else to go except overflowing and out through the refridge vent down the back and onto the floor of the refridge.
If you are hand with tools i can explain a procedure to fix this problem, If not call a service guy :)
Posted on Jun 23, 2009
woodchuck789
  • 4066 Answers
SOURCE: GE frdge model ctx21eazhrww has water accumulating
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 20, 2009
  • 555 Answers
SOURCE: water accumulating in vegetable bin on model
This is caused by a clogged drain tube or the door is not closing correctly. Be sure the seal around the fridge door is closing correctly. If not, the drain tube needs to be replaced or cleaned.
Posted on Nov 06, 2009
EllaWatson25
  • 725 Answers
SOURCE: My Avanti frig has the model# of FF8SSR/FF8WR but
We have parts for Avanti refrigerators. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the information on your parts.
We look forward to working with you.
Posted on Nov 09, 2009
FRIDGE IS LEAKING LOTS OF WATER UNDER THE CRISPERS
Good Afternoon Friend,
I understand your Frigidaire refrigerator, model# GLHT184TJ, is leaking water underneath the crispers. First, make sure the door is closed as well as you are not opening it frequently or for long periods of time. Secondly, make sure all foods and containers are covered. Lastly, make sure that all vegetables have been dried, if you have washed them, before storing them in the crisper drawers. All of the above can cause moisture inside your refrigerator, which can accumulate at the bottom of your refrigerator. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire GLHT184TJ Top Freezer...
Water leaking inside the vegetable drawer
What is your model number? Also what year, series etc.
Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaking inside my vegetable drawer
Just above the drawers is a drain hole on the back wall. Push a drinking straw or very thin brush down to unblock the drainhole and the water will drain away outside the rear into a pan on top of the compressor
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
Water from freezer dripping into fridge freezing and accumulating in the crisper drawers.
Maytag , MZD2752GRW; Water accumulating and is freezing in bottom of the freezer, then runs out the door on to floor.
Jun 10, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water is accumulating in bottom of fridge under produce drawers
Possibly your defrost drain found inside the freezer back wall is blocked. If you could send me the model number I could help you better. Thanks, Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 28, 2009 | Refrigerators
Water leaking inside of refrigerator from freezer
IT SEEMS LIKE YOU HAVE A CLOGGED DRAIN . CHECK YOUR CONDECER COILS BEHIND KICK PLATE .. AFTER THAT YOU CAN UNPLUG FRIDGE FOR 24 HRS WITH DOORS OPEN AND SOULD DEFROST ENOUGH TO CLEAR DRAIN . IF NOT . DEPENDING ON MODEL YOU SOULD BE ABLE TO GET THROUGH DRAIN THROUGH MOST FREEZERS .
Feb 03, 2009 | Kenmore Refrigerators
Accumulation of water in bottom of fridge
You probably need a new door deal for the freezer. When you cet too much condensation in the freezer, it drains down the back of the refrigerator section during the defrost cycle. Check under the produce bins for a drain. If you don't have one, you're not alone. I used to have have to wipe mine out every other day until I finally replaced the seal.
Feb 02, 2009 | Frigidaire FRT21G4B Top Freezer...
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Avanti FF8SSR Top Freezer Refrigerator Logo
145 people viewed this question
Top Avanti Refrigerators Experts
John Tripp
John Tripp
john h
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
