Question about Sanyo Televison & Video
My sound is distorted on my sanyo tv it has an echo in the backround like the bass is blasted but i have the treble an the bass all the way off
Is the base and treble audio adjustible on this 1996 Sony TV KV- 20S20
Adjusting various sound settings (e.g. bass/treble ... - Sony
docs.esupport.sony.com/imanual/NA/EN/hx850/c_snd_qv.html
You can adjust various sound settings, such as bass, treble, balance, etc. ... [Setting Memory]: Applies custom sound settings to the current input or to common ...
General information on how to adjust the bass and ... - SONY
https://us.en.kb.sony.com/.../general-information-on-how-to-adjust-the-b...
Aug 15, 2015 - Follow this procedure to adjust the bass and treble surround parameters on the A/V ... Adjustable sound field parameters vary by sound field.
Dec 25, 2015 | Sony KV-20S20 20" TV
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
How do i find out what sound card my p.c is using? i'm on windows vista, and need to change the bass and treble level ?
Most laptop sound card do not have a setting for bass and treble.
You can use external powered speakers that have bass and treble settings and connect these speakers to the headphone socket on your laptop.
Jun 26, 2012 | Computers & Internet
What are the best settings for bass , treble and mid in order to get the best sound
There are no hard and fast rules for setting Bass, Midrange and Treble on your radio. Depending on the type of music you are listening to with your radio, it can / will determine your sound settings. To attempt to set the sound settings on your radio, select the sound settings and set all of them to 0. ( Bass,mid,treble ), then start playing your usual music. With the music playing move the treble setting in single incriments 1,2,3,4 and so. A comfortable setting is usually a 5 out of a total number of 6. Then move over to Midrange and repeat process. A 4-5 out of 6 is usually comfortable. Finally comes the Bass. You do not want to overpower your speakers with too much bass as this will damage them over time. Repeat the usual process and listen carfully for any baffling or distortion as you move through the numbers. A comfortable bass setting is usually 2-4 out of 6. Again I must stress that there is no hard and fast rule for settings. It boils down to the type of music, and what your ears tells you sounds good. What sounds good to me might not be enough for you, or vice versa. I hope this helps! Cheers!
Mar 30, 2011 | Pioneer DEH-4300UB Car CD/ MP3 Player
Thanks for the answer - If we have 3 controls as Bass, Mid and Treble. If we keep those in 12 O Clock position, will the output level be equal. In using the Bass and Treble control only (if we have...
If all are in 12 o'clock position they are "flat" (nothing has been added or subtracted foam input signal) If you only have bass & treble, yes adjusting will affect "mids" but Mids change can go both ways dependent on increase or decrease of Bass and /or treble. By increasing bass you will pull some mids up also. By increasing treble you'll subtract some mids.
Mar 17, 2011 | Audio Players & Recorders
How to get the best sound
punk and metal tones (late 80s): treb-7 mid-6-7 bass 6-8, presence 6-10, gain/distortion all the way up. classic rock just turn down the gain/distortion to 6-7. bridge pickup
metal mid 90s & up: treb 6-7, mids 3-5, bass 7-9, gain all the way up, presence (which is a mid and treble boost) 4-6. bridge pickup
blues SRV: treb 6, mid 6, bass 7.5, presence 8, gain 5, reverb (if you got it). use your neck pick up
of course this is subjective and depends on the guitar, cable quality, etc. it looks like a small speaker with a low watt output. that little speaker in there is going to be hard to articulate any tones. more than likely it will have a harsh bit to it cause the value of the pots and the logarythm you hear. reduce treble as needed to smooth out the harsh, keep the mids up.
Nov 02, 2009 | Washburn Amplifiers: 25 WATT Guitar...
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Jensen JMP 50 sounds like I am in a tunnel or well.
Have you powered up the speakers have you checked the sound drivers?? but remember the sound of the Jensen JMP-50s is a bit hollow and lacking in bass, and the speakers do lack bass and treble controls, which can often be found in other speakers in the same price range.
Aug 18, 2008 | Jensen JMP-50 Computer Speakers
Acer ast180 speakers do not work properly the sound is echoing
check the volume , bass, treble settings. Check whether u have plugged the wires correctly
Mar 08, 2008 | Acer Aspireā„¢ T180 PC Desktop
Sanyo 31 inch dbx mts color monitor (1992-93?)
Your TV is in the demo mode. Try this: Press the MENU button and hold it down for about 10 seconds.
Aug 14, 2007 | Sanyo DS31590 31" TV
Televison & Video Logo
108 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
