What size of bolts and screws on a 46in led tv insignia for the base of the tv
  • 146 Answers
SOURCE: fasten 32'' insignia plasma model ns-pdp32-09 to wall mount
I think it is probably a metric bolt. Maybe a 10 or 12 MM. There aren't many if any consumer electronics manufactured in the US anymore, and most use metric screws and bolts. Check one of the bolts from that table stand to see what it is. That will tell you if it is metric or standard.
Best of luck.
Posted on Jan 30, 2009
SOURCE: Insignia TV stand screws
Had same problem with Insignia TV...#12 - 24 x 1/2" machine screws...found at Home Depot in bagged items (can't use longer because some of the holes don't go all the way thru)
Posted on Jun 19, 2009
  • 3 Answers
SOURCE: Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Posted on Dec 13, 2009
budmrtn
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
SOURCE: need to know what size screws go in to the tv base
I ended up having to take my entire tv into Home Depot. This is what the package says on the screws that worked:
"Machine Screw Pan-Slotted 4mm- & X 20mm Stainless Steel BR-B/ 12-B/322"
I know this is an old post but since I couldn't find any answers when I was looking I wanted to help someone else out.
Posted on Apr 01, 2010
Screw size for wall mount 32 inch model TDE3253
Bolt size is M6 bolt pattern and thread pitch. A 15 to 25 mm long bolt is recommended depending on the thickness of the wall bracket.
I got got this from GPX. If you email them you can get the full TV guide.
Apr 18, 2014 | GPX TDE3282B 32" 720p LED HDTV/DVD Combo,
Size of screws for sanyo 55 inch LCD to mount base to tv
After repeated trips to the hardware store and more calls to Sanyo and conversations with supervisors...depending on the year of the TV....2011 requires M5x16. The next year model requires the same size that bolt to the back of the TV. I had to elevate my request for the size of the base screw of the 2011 model all the way to engineering before I got the answer. They changed the configuration in the 2012 and later models.
Jan 02, 2014 | Sanyo Dp55441 TV
Reattach the base on insignia tv
Place the TV face down on a soft surface. Position the base for installation of attaching screws and install screws. Lift the TV off of the soft surface and place in desired location
Feb 22, 2013 | Insignia LCDTV26 26 in. Television
My 46in led/lcd tv has a vertical black strip 5in wide
could be the format board or the panel, check out http://www.shopjimmy.com/ and order the format board first.
Sep 06, 2012 | Insignia "- 46"" Class / LCD / 1080p /...
Need base for Insignia TV
It will either slide out from the front/back or to the side..Some actually bolt on from the bottom using screws/bolts.And then again some are not meant to be taken off.Make sure it is a wall mountable tv.Then try to take the stand off as directed.
May 29, 2009 | Insignia LCDTV26 26 in. Television
May 20, 2009 | Insignia LCDTV26 26 in. Television
Apr 10, 2009 | Insignia IS-LCDTV32 32 in. Television
Fasten 32'' insignia plasma model ns-pdp32-09 to wall mount
Best of luck.
Jan 30, 2009 | Televison & Video
Removing the stand on Insignia LCD 26F TV
My insignia 26 inch dvd combo TV stand can be removed by removing the access cover to your input connection. There are eleven black phillip-head screws. The three bottom screws also hold the plastic base cover in place. Remove all eleven screws and pull the stand out from below. The four philip-head screws on the back center of the TV is for the location of the wall bracket mount. Good luck.
Jan 26, 2009 | Insignia LCDTV26 26 in. Television
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
15 people viewed this question
 Grubhead
Grubhead
