Question about Mtd Garden
I have a White 54" cut 25 hp vtwin Kholer engine. Went start up and needed choke out to keep going like it was starving for gas, but also pto (blades) would not engage. Next evening fine, but did not mow. Next day back to problem. Hr. meter was not on either. Could this be in the ignition switch? Thanks for any help. Dave
    Novelist:
  • 157 Answers
If ignition switch is a suspect, next time if the problems acts up, try wiggling and slightly turning the key in the ignition. If you notice any differences, then you have bad electrical contacts in the ignition switch assembly. Hope this helps.
Posted on Oct 14, 2013
Testimonial: "Frank S. Thanks for the reply. Ihave narrowed it down to switch. Took apart the switch and seen contact was gone for lights, and ran for 5 minites or so then acted up."
wadembly
  • 513 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
AUTODOC01
  • 216 Answers
SOURCE: Greetings, I have a 26 hp 54 in. cut tractor
check under the deck blades first see if something caught in the blades? if not try to spin the pullies on the deck with the blade off make sore that there are no bearing prblems ? you can buy a new key at sears for like $3.00 there all same? if it runs i doubt you shorted anything but it is possible ? have you checked your fuel and are filters etc, repost if it still acts up will send you more help
Posted on Aug 31, 2009
Testimonial: "I will check this weekend and let you know, as I am in Lockport,Il and the tractor is in Veedersburg,Ind.It just might be a seized bearingon the deck."
  • 61 Answers
SOURCE: I have a scotts (made
sounds like safety switch
Posted on Sep 06, 2009
  • 420 Answers
SOURCE: Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
Posted on May 27, 2010
  • 6468 Answers
SOURCE: pto cuts off while mowing
check the safety switches start with the one on the seat then the one on the clutch/brake pedal then the reverse cut out switch bypass them one at a time with a paper clip to test them also look for a loss connection at all the same switches
Posted on May 25, 2012
How do I replace a pto on a john deere eztrak 445 with 54" hc deck?
Most have a bolt holding it on. And unplug electrial connection.
Sep 20, 2014 | Garden
Pto won't engage blades
ether switch bad fuse blown behind dash or pto bad if pto 300.00
Sep 12, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Cut...
3cyl 993cc daihatsu engine starts and runs then shuts down could this have something to do with the fuel cut solonoid
If you can keep it running with the choke set, your engine is starving for fuel, your fuel filter, or carb is clogged. disconnect the fuel line to the carb and check for flow. Fuel cut would do just that, cut ALL fuel so choking would not matter.
Mar 30, 2014 | Vehicle Parts & Accessories
Husqvarna 24hp VTwin Hydrostatic 48' cut riding lawn mower will not move either direction.
I would check the drive belt going to rear end if not that I would check fluid level in transmission.
Aug 04, 2013 | Husqvarna 24HP VTwin Hydrostatic 54" Cut...
Turn zero
sorry but i would talk to the shop about that.
Jul 30, 2013 | Ariens Zoom 42 In 165 HP Briggs Stratton...
25 hp kholer engine will not stay running without the choke on
if the fuel is newer than 30 days you need to rebuild the carb if not try fresh fuel first
Aug 11, 2012 | Cub Cadet Garden
Engine surges won't run with out choke and then it stalls
If the engine surges and won't run without choke it is starving for fuel. Best place to start is the fuel filter. After the fuel filter, pull the fuel line off of the carburetor and place a container under the fuel line to catch the fuel. Crank the engine over and watch for the amount of fuel being pumped through the line. There should be a good stream of fuel with each pulse from the pump. Chances are the pump diaphragm is getting weak and it cannot keep enough fuel in the carb to run proper. Check those items and let me know if it helps, Daniel.
Sep 29, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
Garden Logo
59 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
