Question about Ingersoll Rand Air Tools & Compressors
Ingersoll Rand SSR 350 has a series of numbers on the intellisys panel , how do i clear these numbers or has the card lost its noodle ?
    Novelist:
  • 214 Answers
The controller is most likely bad.
Posted on Oct 16, 2013
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
  • 5603 Answers
SOURCE: ingersoll rand SSR 100Hp w/
Look for any problem involving a dropped phase of the input power. It could be a transient one such as a poor contact that the sensor detects a glitch which then cures itself when you overide the watchdog of the system. Tighten all electrical connections and while doing so look for any heating indicators such as discolored insulation. The electronics can see very short failures that are punched through when running manually. That is what the smart controllers are for to protect the motor. The controller itself probably only uses one phase for its own power. The transient might happen in a tenth of a second.
Posted on Feb 24, 2011
mrhappyface
  • 205 Answers
SOURCE: Orange light on the top
it is on auto restart
Posted on Jul 07, 2011
  • 33 Answers
SOURCE: ingersoll rand SSR ML 75
Hi, Yes there is a key combination on these, but it depends on the controller that i fitted onto it, is it an Intelisis with the 3 Oval buttons with the up and down arrows in the middle of them? If so, as you look at the left hand Oval button, just to the left of that is an invisible button. you need to press/swipe your thumb from the far left of the controller, going over the invisible button, to the left hand oval button. pressing both buttons in the process. Hope that helps
Posted on Sep 03, 2012
SOURCE: where can i find motor fan part # 2mtr
89264527 Cooling Fan 250mm 54480355 Cooling Fan 300mm
Posted on Jun 20, 2013
How to change from BAR to PSI on INGERSOLL RAND INTELLISYS CONTROL for INGERSOLL RAND SSR-6-20-125 AIR COMPRESSOR
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
Ingersoll Rand Intellisys NTLS100-200HP part# 39825716 will not go into auto restart
That could be a programming issue or that specific function of the Intellisys controller can go bad. There are companies that you can send the Intellsiys to for repair.
Jun 29, 2016 | Ingersoll Rand Air Tools & Compressors
I have a ssr ep 100 and the intellisys says no control power ive tryed to clear it but it wont
Probably have a bad High air temp. switch located in the end of the compressor air end. It has control power run thru the switch. If the switch opens on temp or just goes bad you lose control power which will come up on screen as control power loss. Replace HAT switch.
Apr 02, 2013 | Ingersoll Rand Rotary Screw Compressor ...
I'm working on a Ingersoll rand 100HP stationary compressor with an intellisys 39875158 controller.
Make sure the model of your compressor is design for 160psi if not the main motor trip off and safe valve pop. Goto Main Menu, Operator setpoint+select, Offline/Online+select, arrow up and down to change value.
Jul 04, 2012 | Ingersoll Rand Stationary Air Cooled...
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
Aug 25, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
181 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
