Need bolts and screws to fasten the tv stand. What size of bolts and screws
  • 298 Answers
SOURCE: Polaroid TV
You are correct. Polaroid does not make the screws available. You will have to obtain locally, per Polaroid.
Posted on Mar 07, 2008
  • 6 Answers
SOURCE: Lost screws for stand on Vizio VU42L
If you pay for shipping I will send you my screws. Maybe a buck or two will cover it in an envelope. I just removed them last night as the TV is being junked for the parts. Email me.
MBSimonds AT aol DOT com
Posted on Mar 31, 2009
  • 128 Answers
SOURCE: I need screws for an Olevia LT37HVS tv stand
Most of these sets us either a M4 or M6, around 22mm. this is close to a 2" long 1/4-20 screw, but in metric.
Home depot or radio shack, or just about any place that sells TVs these days ought to have them.
At radio shack, a wall mount comes with the following screws to fit all TVs:
  • 4 x Phillips screw (M4 x 10 mm)
  • 4 x Phillips screw (M4 x 20 mm)
  • 4 x Phillips screw (M6 x 12 mm)
  • 4 x Phillips screw (M6 x 20 mm)
  • 4 x Phillips screw (M6 x 30 mm)
  • 5 x Phillips screw (M5 x 6 mm)
Only caveat is don't go with a screw substantially longer than what is needed.
Posted on Oct 23, 2009
budmrtn
  • 11361 Answers
SOURCE: screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Posted on Dec 23, 2009
SOURCE: TV Stand Screws
If you still have the manual or know the manufacturer you might want to try giving them a call. They'll know what size screw was used on that model tv stand. Otherwise, measure the insides of the holes and go to a hardware store; they should be able to help you find the right one. Just make sure they are not too long. Screws are pretty cheap, so I'd suggest buying one of a couple different sizes to try out. They should fit snugly in the hole, but should not split the wood/plastic. You'll want to get four of the same size washers and nuts as well once you know what kind of screw you need. That way they won't loosen. :)
Posted on May 18, 2012
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
Sony kdl-55ex501 stand bolt size?
you to tel me what you want ok you want a tv stand do you need to locate where you can get one or what?
Feb 29, 2016 | Sony Kdl-55ex501 55 in. LCD TV
What size bolts do I need for attaching the stand?
They should have come with the TV. Sometimes they are screwed into the place where they attach the stand to the TV. Sometimes in a small bag with the stand or with the remote.
Oct 09, 2014 | LG 42LG50 42 in. LCD HDTV
Graco pack play
Hi Carol, remove the fastener from the opposite side of the one that is missing and take it to a Home Depot or Lowes in your neighborhood. Some well stocked hardware stores may also be able to help. They have both metric and standard threaded screws and bolts and I believe the Graco uses metric. They have boards in the hardware department that should tell you which type you need.
It doesn't usually need to look the same to do the job but if they have nothing to help you out, you will at least know if it's standard (for example 10/24 x 1" which means the screw or bolt is size 10 with 24 threads per inch by 1 inch long) or metric (M5 x 0.8 x 1" which is the metric size closest to a 10/24 x 1") and the type of head, hex or bolt head or a screw driver head, Phillips or flat-bladed.
Armed with that information you'll be able to locate the exact replacement from hardware providers on the internet.
(If the head is unusual, take a picture)
Hope this helps,
The Tinker
Nov 30, 2013 | Baby Gear
I have a Sharp LC-32SB24U. I am trying to mount my tv to a tv tower stand. There are four screw holes in the back of the tv but the bolts supplied with the TV tower don't fit. The directions say use the...
Just make an educated guess judging by the size of the bolts you do have, whether they are too big or too small, or you could measure with a measuring tape by measuring the head of the bolt. Then take those measurements to your local hardware or other store and either you will be able to find one you feel confident about size wize or you can find someone to help you. As far as specific bolts go there really isnt a difference, as long as you get a decent size, if its a little too big it will be ok as the threads will just cut their way in regardless.
Hope this helped.
Feb 07, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Sharp Aquos 47 inch tv. Just moved and can't find the 4 screws to the stand, where can I buy new screws or get the specs if I were to buy new ones at Home Depot? Thx
these are pretty common screws if you still have the box and everything it came wtih new then it perhaps may have the screw sizes included with it in there if not then go to a local fastener store as home depot sells them in large packages for even more money by going to the fastener store you can get multiple sizes in one shot try till you succeed and get more of the ones that fit while you return the rest i hope this helps and they are usually about an inch in 3\4 of an inch in length
Nov 19, 2010 | Sharp LC52SB55U LCD TV
I can not remove the stand from my tv
1. Verify that there are 4 screws fastened (2 screws on each side which can be unscrewed using a hexkey)
2. place the TV on a flat surface with the screen facing down... unscrew the 4 screws using the right hexkey size.
3. Pull the stand downwards to take it off.
Sep 12, 2010 | Sharp LC-52D64U 52 in. LCD HDTV
There are no bolts to mount my Samsung Series 6 to my TV Stand
YES TAKE THE SMALL BOLTS WITH YOU AND GET LONGER ONES
Aug 24, 2009 | Samsung Televison & Video
Need mounting bolts
lg company or go to hardware store and get the biggest bolts that will fit in the holes. Otherwise you may be able to purchase them on ebay.
Jul 09, 2009 | LG 37LC7D 37 in. LCD HDTV
Fasten 32'' insignia plasma model ns-pdp32-09 to wall mount
I think it is probably a metric bolt. Maybe a 10 or 12 MM. There aren't many if any consumer electronics manufactured in the US anymore, and most use metric screws and bolts. Check one of the bolts from that table stand to see what it is. That will tell you if it is metric or standard.
Best of luck.
Jan 30, 2009 | Televison & Video
16 people viewed this question
 Grubhead
Grubhead
