Question about Sewing Machines
Baby lock 1550
The right knob/bobin rewinder and to make machine work is brokken will not move needle up and down
    New Friend:
Try using a can of compressed air in the hole where the bobbin winder pin sets and then push back in operating position. Also, take out bobbin holder under the metal plate below the needle. That entire assembly should come out and go back in easily. Again use the compressed air to get any fabric fuzz away from moving parts. Check your manual or online for oiling instructions. Hope this helps.
Posted on Oct 12, 2013
bargainbox
  • 1388 Answers
SOURCE: Needle wont go up or down
If the Handwheel (big knob) is moving but the needle is not moving, you need to engage the clutch ........depending on the model
- push handwheel in to engage, pull out to disengage
or
- if there is a smaller wheel inside the handwheel, tighten to engage, loosen to release.
BUT if all is jammed........
Check for threads that are jamming the motion of the hook around where the bobbin case is
If your bobbin goes in from the top, remove the needleplate and bobbincase remove thread jams by gently rocking handwheel back and forth until released.
Clean around the hook race with a rag moistened with methylated spirit, surgical spirit or similar, then reassemble.
If front loading, open the door for bobbin case area, release 2 retaining clips holding the collar on (take note of the position/orientation for when you re-assemble....even take a digi photo to refer to !?!).....
......then just do jam removal & clean out in much the same way as for the top loader.
In all cases, don't force too much or be too brutal, gentle and patient works best, try to judge where the jam is caught and work with it slowly......you may need to cut jammed threads, just ensure all are removed before you re-assemble.
Posted on Feb 16, 2008
  • 3 Answers
SOURCE: Handwheel on Sewing machine no longer moves needle.
Actually you should have a "set screw" in the hand wheel. The set screw is usally locked down tight to keep the hand wheel from spinning freely. I f you can run the machine slowly and hold the hand wheel in one place but the machine continues running, then you do need to replace the "set screw". If you replace it you will find that you can offset some of the machines vibration by where you lock the wheel down. Trial and error is the only way to achive this adjustment, kind of like balancing the tires on your car.
Posted on Feb 13, 2009
SOURCE: Bobbin Winding
How do I wet wind a 2 inchs long bobbin using varnish.
Thanks
Gholam
Posted on Mar 14, 2009
  • 11 Answers
SOURCE: janome mylock 634D overlocker
this very same thing happened to my flat machine turned out to be a piec of material jammed in the workings also wrong oil used or it might be thread jammed try and see
Posted on Jun 16, 2009
SOURCE: baby lock quest, blq2 bobbin problem
Concerning the Babylock Quest when using the reverse option I seem to be reading a few somplaits what is the best way to reverse without causing and adverse problems?
thanks
sewingcindy
Posted on Jun 13, 2010
Baby lock BLQ2 needle hits on bobin
repair shop time the timing is off
Nov 01, 2017 | Baby Lock Sewing Machines
How do i rethread the bobin
You have to get the machine to switch its gear to wind the bobbin instead of sewing( needle up and down). There are two ways most machines do this...on older or simpler machines you pop the wheel that makes the needle go up and down ( right side of the machine) either in or out! There may be a round knob in the center that pops in or out... Other machines make you move the rod that the bobbin sits on for winding move or swing to engage the gear. There should be a path for it to slide along if that is what your machine does. Good luck!
Jul 07, 2015 | Sewing Machines
Centering needle on Baby Lock Ellure
Make sure the needle is at its highest point. Use the flywheel/ hand wheel on the right side of the machine to move the needle.
Aug 19, 2014 | Baby Lock Ellure
Janome 350 embroidery machine......when I try to rewind the thread, ( shifting the stick to the right ) the needle keeps moving up and down.....any kind of help would be very appreciated.....the deale
Try to find the exact spot on the wheel to make the needle stop. Try different spots to get the one that does not move. You may need a service. You could also remove the thread until you are ready. The needle would go up and down but without thread will not cause havoc.
Jul 29, 2014 | Janome America Inc 350E Memory Craft...
Baby lock companion 1550 manual
I need a owners manual for a baby lock companion 1550
Mar 06, 2013 | Sewing Machines
The security device is activated and the shaft that hold the pressure foot and needle is in the down position and I can not raise it.
it's possible that some part as been damaged, best solution is to have it serviced at a sewing machine shop
Mar 01, 2012 | Baby Lock Ellure
Needle won't move
yes something is wrong with the machine , it needs to be repaired
Feb 27, 2012 | Husqvarna Sewing Machines
LED that illuminates the stitch selection bar quit working as did the up/down needle button.
Check your bobbin spindle. If engaged (pushed toward the right) LED will not light. When the clutch knob is pulled out, when you wind a bobbin, the up & down needle will not move. So you must push the clutch knob in again to let the up & down needle go up and down. The clutch knob on my machine is in the large hand wheel upper right side of my machine.
Jul 17, 2011 | Janome 4623 Mechanical Sewing Machine
Motor works needle does not go up and down
You can call the company toll-free at 1-800-361-4639 and they can tell you what to do. All the phone reps I've talked ot have been wonderful.
Mar 25, 2009 | Euro-Pro Deluxe 7130 Mechanical Sewing...
Janome 634d not working
Check the needle plate. I had this problem with mine and it turned out that the needle plate had cracked.
Feb 03, 2009 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
71 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
