Question about Dryers
Ge dryer manual dvlr223e
Replace belt
dmftrucker
  • 1922 Answers
SOURCE: dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Posted on Sep 26, 2009
  • 24 Answers
SOURCE: Replacement of belt on dryer
Here's how to replace a belt on an GE Profile DPSE810EG4 electric dryer. There may be some minor variation for other electric GE dryers, but it shouldn't be too different. DO NOT USE THESE INSTRUCTIONS ON GAS DRYERS AS ADDITIONAL PRECAUTIONS MAY BE REQUIRED! For the electric DPSE810EG4, you will need a #2 Philips screwdriver, a flashlight, a new belt, and patience. You will also need something very close to the left front of the dryer against which you will lean the front panel. A chair, a washing machine, or a wall all work fine for this purpose.
1) UNPLUG THE DRYER FOR YOUR SAFETY.
2) Pull the dryer away from the wall and disconnect the ducting.
3) Remove the top four screws on the back panel. (These secure the control panel)
4) Open the dryer door and remove the two screws on the top of the door frame. (These secure the top panel.)
5) Pop up the front of the top panel and slide the top panel forward an inch.
6) Unlock control panel by sliding it to the right, then pull it up to detach it from the top panel.
7) Lift off the top panel and set it somewhere
8) Undo the two screws that hold the front panel.
9) Pull up a little on the front lip of the drum while hinging the front panel forwards. On the DPSE810EG4, you can set the drum down on the support member that is underneath it. (On other models you might need to put something under the drum for it to rest on.)
10) Lift the front panel off of the pins that secure its lower end, and then hinge it to the left (be careful not to yank the wires). Lean it up against something.
11) Open the access door on the back. (On the DPSE810EG4 the access door is the exaust duct itself; remove the screw that secures it and slide it out of the dryer.) Set your flashlight inside the dryer aimed so that you can see the motor and the tension pully.
12) Remove the old belt. If it's snapped in half you can just pull it out. Otherwise, reach in through the back access door with your left arm and pull it off the motor, then come around front, lift up the front of the drum a little and slide the belt off the drum.
13) Reach in through the back access door with a cloth and remove any grease blobs on back of the tension pulley axle. (This way you won't accidentally get grease on the belt during the difficult step which comes next!)
13) Install the new belt. Lift up the front of the drum a little and slide the new belt onto it (the side with the parallel grooves should be touching the drum). Reach into the back access door with your left arm. Grab the belt and pull it around the right side of the plastic tension pulley and then pull it down around the metal motor pulley. You're less likely to get your fingers stuck if you grasp the belt from the front. (The side of the belt without the parallel groves should be in contact with the tension pulley. The side of the belt with the parallel grooves should be in contact with the motor pulley.)
14) Replace the front panel. Set it down on the pins, then hinge it forward while pulling up on the front lip of the drum. Secure the two screws.
15) Make sure the drum turns OK. (If it's fairly difficult to turn, you may wish to try removing the front panel and then try putting it back so that the drum sits inside the felt strip semicircle rather than compressing it. A drum that doesn't turn well will stress the motor and cause it to pause mid-cycle.)
16) Replace the top panel. Put it on top of the dryer, insert the control panel tabs into it, and lock them by sliding the control panel to the left. Slide the top panel back and pop it down in the front. Secure the front with the two long screws and secure the control panel with the four short screws.
17) Replace the rear access door / exhaust duct. Double check that you didn't leave anything inside (including your flashlight). Slide the exhaust duct back into the dryer and secure the screw that holds it.
18) Re-attach the rest of the ducting and move the dryer back into position.
19) Plug it in and make sure it works.
Posted on Dec 26, 2009
SOURCE: How to replace belt on Ge dryer # DNXR473GW0WW
dryer was working ,when wife checked on it , the dryer had stopped with 20 min. left. now it's as though there is no power to the mach. I have checked and there is power at the location.
Posted on Apr 17, 2010
woobie dog
  • 1273 Answers
SOURCE: To replace the belt on GE Dryer DISR473DG1WW, we
Hello, W/D here.
I'm not aware of any dryers shipping with a spare belt on board, but this may vary by region.
You are correct in that the back is removed to gain access to the belt. Disconnect the power first. If there isn't a spare in the cabinet (probably not), take the old belt with you to your local appliance parts supply house and get a replacement, or it may be ordered on-line. The belt number will be on the belt.
Here's a good website showing how your model is assembled. This site also has parts descriptions and prices; useful for comparison shopping. There is also usually a button-link to a free downloadable manual. Here 'tis: http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DISR473DG1WW/0432/0151200?pathTaken=&prst=0&shdMod=DISR473DG1WW
Another good site to check for parts is: http//www.appliancepartspros.com.
Armed with these items, replacing the belt will be child's play for you!
Best regards, (and please rate this solution), --W/D--
Posted on Apr 02, 2011
richroth
  • 9472 Answers
SOURCE: replacing the belt on a ge dryer
Posted on Nov 03, 2012
Replace belt in GE dryer #DDE7108PLLAD
You can buy a manual from GE or manual at appliance parts store in how to replace the belt or go line to get the manual
Mar 04, 2015 | GE Dryers
Tip
Fridgidaire and GE Dryer Belt Replacement
Here are the belt diagrams for replacing your dryer belt for Fridigaire and Ge Dryers
For Fridigaire dryers 1970-1985
9b6122a.gif Style: Flat with ribs
Installation Tips: Ribs face toward drum
For 1985-1995
For 1995- present
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
For Ge Dryers
1970- 1990 standard capacity
Installation Tips: Ribs against drum
1970- 1990 Large capacity
1990 – to present
on Mar 02, 2010 | Dryers
Make sure your cycle is properly selected with the timer and that the dial knob isn't broken. It will make that noise if you try to start it when the cycle is set to off. Otherwise, you might have something stuck in your blower wheel. Try spinning the drum by hand and if it doesn't move, there may be a restriction causing the motor to hum.
Nov 25, 2013 | Dryers
To replace the belt on GE Dryer DISR473DG1WW, we will need to open the back of the cabinet, right? Is there a repair manual showing the process? Does this dryer ship with a spare belt inside?
Hello, W/D here.
Apr 02, 2011 | GE Dryers
I HAVE A GE DRYER DBXR453GA2WW. We replaced the belt. The start knob is missing but we can still get it turn on by manual turning the apparatus underneath the knob. However, the dryer will not stay on.
If the dryer starts but will not stay running, the cientrifugal switch in the motor is likely faulty. The motor will probably need to be replaced.
Kelly
Mar 24, 2011 | GE Dryers
Feb 02, 2010 | GE DBSR453GBWW Gas Dryer
Dryer belt replacement
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Dryers Logo
22 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
