Question about Dayton Dryers
I have a Dayton 5X848N relay switch that needs connected to a well pump. how is it wired
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 81 Answers
Go to www.ehow.com and type in the search box
"relay switch wiring"
and you will pull up 6 web pages of click on the post articles
on how to wire in a relay. somewheres in all that techinical info
someone will be writing about a relay just like yours & be giving step by step instruction as well as tools needed to do job.
try typing in search box---" how to wire dayton 5x848n relay into well pump.
You should also have the make and model of the well pump handy on paper as you will need this to find out where relay goes to pump motor.
If you need more specific info type in search box
*how 2 wire dayton 5x848n relay into make & model well pump*
try that on google.com.;bing.com;ask.com;yahoo.com as well as
ehow.com
they all have search box on upper right coner of web page & they all answer questions with pre writen info.
Posted on Oct 13, 2013
Dayton wiring diagram
Wiring diagram should appear on side of motor.
Dayton is sold by grainger.
Contact WW Grainger with model number etc and they will send email the pdf file showing wiring.
Take photo of wiring diagram on motor label, and attach to question for best possible chance of accurate answer.
May 21, 2013 | Pool & Spa
We have a 1EGD1 dayton timer delay relay what is the wiring diagram
Open following link to identify timer:
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=1EGD1&op=search&Ntt=1EGD1&N=0&sst=subset
This is typical 8 pin delay timer relay.
The wiring diagram appears on side of the timer.
Open following link for example how to wire 8-pin timer.
http://waterheatertimer.org/images/Connect-relay-to-timer.jpg
Example shows 24Volt, but 120Volt wires exactly the same.
The timer is 120Volts. So connect power to terminals 2 and 7.
Other terminals are dry, and receive no power when 120V is connected to 2 and 7.
In the example wiring, the objective is to have power connected to Load at all times except when timer activates. So power is connected to terminal 1 and Load wire is connected to terminal 6.
If the objective was to have power connected to Load only when timer turns ON, then connect power to terminal 1 and connect Load wire to terminal 3.
Read how to wire timer:
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html#pin
Oct 07, 2011 | Amperite Dayton Solid State Timer On Delay...
To palaboy: when you talk about a switch on the left most terminals, you mean with this switch im enable the timer???
Question is not clear.
You posted about Dayton on-delay timer?
This timer has two contacts, and wires similar to a light switch.
Connect 120V power to terminal 1
Connect wire going to load to terminal 3
Maximum Load is 1 amp so this timer should be wire to a contactor/relay and not directly to Load.
If you have Dayton off-delay timer, open following link for wiring diagram, and to see examples of contactors:
If you have a different timer, then add a comment with clear description of timer or in-focus photo of timer posted on Flickr
Jul 11, 2011 | Amperite Dayton Solid State Timer On Delay...
I have a 3e402 heater sometimes the fan comes on and sometimes it doesnt could that be a bad fan relay
Yes but it could also be a sticking fan switch located on the heat exchanger. Replace the switch first, it's cheaper. Look for any bad connections, follow wires from fan to the switch.
Nov 28, 2010 | Dayton (3E379) Heater
Is the button NC or NO? I have it currently wired this way but still it does not work and I'm using a switch not a button. Any suggestion?
The switch is OFF or NO normally open
See wiring diagram at following link
The way the timer works is this::
You click switch ON
When you turn switch OFF, the Dayton begins the timing sequence
The Dayton turns on the circuit going to load for 1/2 second => 5 minutes depending on model of Dayton timer
Grainger sells 120V push buttons if you don't want to turn the switch on-and-off each time
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=push+button+switch&op=search&Ntt=push+button+switch&N=0&sst=subset
http://www.grainger.com/Grainger/IDEAL-Push-Button-1XWT9?Pid=search
Oct 12, 2010 | Amperite Dayton Solid State Timer On Delay...
I have a 6a859 relay, does the 120 power lead go on 2 or 3?
Your load cannot exceed 1 amp
You'll need to connect load wires to a contactor or relay that has 120V coil
Local HVAC supply carries contactors
Grainger has contactors 120V coil and 25 amp across terminals
Fasco H230A with 120V coil and 30 amp across terminals
Sep 19, 2010 | Amperite Dayton Solid State Timer On Delay...
How to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
Aug 28, 2009 | Dayton Permanent Split Capacitor Motor Fan
Wiring a dayton timer relay
Open following link for illustrations showing how to wire 8 and 11 pin off-delay timers:
Jun 01, 2009 | Amperite Dayton Solid State Timer On Delay...
How to wire a dayton off delay timer relay for 1 min. solenoid ac
found a reference to the relay class I was in need of information on here:http://www.hauntedattraction.com/38/currentissue_workshops.shtml describing a particular circuit r&d that I could equate to my dilemma... took a little mapping out of the schematic as I read, but wasn't too difficult to correlate. It pays to persevere in your googling methods ;-)
Apr 17, 2009 | Amperite Dayton Solid State Timer On Delay...
Dryers Logo
168 people viewed this question
Top Dayton Dryers Experts
Jay Finke
Jay Finke
AZBen
AZBen
Piyal Perera
Piyal Perera
Are you a Dayton Dryer Expert? Answer questions, earn points and help others
