Question about Health & Beauty
I have an older prymate chair and was wondering what size battery goes in this thing? It's been dead for a while and won't work with out the charger hooked up to it.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
Take seat off and cover and check battery for size must be a gel battery
Posted on Jan 20, 2014
  • 16 Answers
SOURCE: new battries won't charge.
Sounds like the batteries are completely dead, you'll probably need to replace them, sometimes you can only use batteries until they die, and that goes for Wheelchair Batteries too. If they won't charge or keep a charge then they are dead.
Posted on Mar 06, 2009
  • 175 Answers
SOURCE: The wheelchair does not come on or light up at all. When I put t
A note of caution when using a standard battery charger for a car on powerchair or scooter batteries, or ANY sealed batteries. The chargers for this mobility equipment are designed to slowly charge the batteries in spurts so that there isn't a dangerous buildup of hydrogen-sulfide gas which is produced when charging any battery. Because the batt's are sealed, the casing could expand and blow apart when not allowed to slowly, and in spurts, charge.
Car batteries are unsealed, so the gas escapes. In any case, apply no more than 4 amps to any mobility battery, and do so for only an hour or so before letting the battery settle down and the gas recombine with the gel inside.
Gel batteries should be stored with a full charge, disconnected from the equipment in a cool, dry space, and shouldn't be stored for more than a few months without periodic recharging. At the price of them, it pays to take good care.
Posted on Jul 12, 2009
  • 32 Answers
SOURCE: Aspire Quickie Battery Charger
most chargers have an external or internal fuse, try replacing.
Posted on Jul 13, 2009
  • 4 Answers
SOURCE: Hooveround MPV won't move
Most likely either one or both of the batteries have a dead cell. Have your batteries load tested to check their condition.
Posted on Aug 13, 2009
  • 29 Answers
SOURCE: the orange idicator light is flashing.
Replace the batters and used the correct battery charger, Not a car charger.
Posted on Sep 02, 2009
What makes the on board charger not work an how cah it be tested to see if it is good.
There is a fuse in the charger and another in the chair for the charging circuit. Poor connections to the controller and at the batteries will do it too. If the batteries have been completely discharged, then the onboard charger does not have enough power to start recharging them. If that is the case, use an automotive 12 volt charger that has no automatic charging circuits in it to charge them individually. That means removing both batteries from the chair and connect the charger to one battery at a time. You can test the charger with the batteries disconnected and measuring the voltage on the wires you just took off the batteries. The voltage should be 28 volts or so if the charger is working.
Jun 29, 2015 | Jet 3 Ultra Power Chair
Charger not working
When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
Apr 12, 2015 | Health & Beauty
Battery charger is blinking
Most chargers have a certain color light that should be lit when the charger is charging the batteries. If this is what you normally have had, the blinking light means the batteries in the chair are dead or disconnected somehow or the charger is defective. If your chair is still turning on you may have a bad connection somewhere or the charger is defective. If the chair does not turn on anymore the batteries may be to dead to charge. Also if it does not turn on you could have a blown fuse or something disconnected in the battery wiring harness that will not let the charger work.
Oct 06, 2014 | Health & Beauty
Battery charger on quantum electric wheelchair starts out ember color then starts flashing red I check wires everything is plugged check it about 3 months ago everything was ok now th chair won't
Did you charge it at all during the 3 months? Did you store chair on a full charge? Check to see if batteries are dead. Batteries should be disconnected and/or stored on a full charge. If left connected they should be fully charge every week.
Mar 17, 2013 | Health & Beauty
Batt.in my elect. wheel chair will not start charge
how dead are the batteries. some chargers won"t charge until a certain voltage threshold is met as a safety measure
Sep 23, 2012 | Pride Jazzy 1103 Ultra Standard Power...
Batteries for Renegade power wheel chair won't charge
if the batteries are OLD they are quite possibly totally dead and need replaced
Apr 10, 2017 | Health & Beauty
Plug charger in and will not charge the fan on the charger quits running in a few seconds it will beep with charger pluged in and when you unhook charger it clicks like a dead battery i wonder if charger...
David Are you leaving the power on while you are charging the Chair? If you are try charging with power off at the joystick. The manufacturers of all power batteries do not recommend charging with automotive chargers. I would try to locate a friend or neighbor that also has a chair or scooter and borrowing their charger for a few hours to see if it will charge your chair. If not contact your provider and borrow a charger from them. If the different charger works then yours is bad. You shoud be able to order a charger through your provider or by calling Pride Mobility @ 1-800-800-8586 Hope this helps you PS I didn't say you couldn't use the "other" charger. But I wouldn't want you to think I approved of it
Oct 02, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Battery shows 24.8 volts no power
Yes, your batteries are trashed. You need to replace them. Or take them off the chair and put them on a car charger,slow charge. They need to be up over 24VDC. If they fall under 24VDC the charger won`t recognize them and won`t charge.
Mar 30, 2009 | Golden Technologies Buzz Around 3 Wheel...
New battries won't charge.
Mar 03, 2009 | Jet 3 Ultra Power Chair
Health & Beauty Logo
24 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
