CURTIS DVD8723 i dont know why but now it keeps saying wrong region i got it iu the uk ond only use uk disks pleas help I currently have the same problem with my Curtis DVD 8723UK it is showing wrong region message and is out of warrenty. I wonder if lifeishell could send me the necessary fix for this problem. My email contact is kirstygarratt@btopenworld.com. Many thanks for your assistance
  • 8 more comments
  • kirstygarrat Apr 23, 2009
    I am having trouble with my Curtis DVD 8723UK. It comes up with an error message saying wrong region when you try to play original copies of dvd's. If you enter copies or cd's these both work fine.
    Many thanks for any help.
    Thanks for your help Kevin. I have been told that someone on this site has the details of the firmware update however when people have previously tried to contact Curtis they are unhelpful and not willing to help.
    The dvd player is an English version and the discs we are using are Region 2 and until about a week ago everything was working fine. Then one day we put a dvd in it came up with this error message as has every other original dvd we have tried to play. So I don't think it is a problem with the player needing to be unlocked.
    Thanks very much for your suggestions though.
    Thank again for your help I had considered copying the dvd's but it seems like quite a job.
    If "lifeishell" is still out there I wonder if he could possibly forward me the details of the firmware update.
    Many thanks again for your help
    Thanks again I have just tried to email Curtis directly so will see if I get anywhere with that.
    Thanks for your help. To be honest the unit is a little basic and I have gone through the menus but there is no facility to change the region code, unless I am looking in the wrong place!
    Your help is appreciated.
    Thanks again I have tried but unfortunately no luck.
  • kirstygarrat Apr 24, 2009
    thanks for your help unfortunately as the unit is quite basic there is no facility to enter a region code. I have been advised that as this unit had been working fine it is probably a firmware update that is needed so if anyone is able to assist with this I would be very grateful.
  • kirstygarrat Apr 25, 2009
    Thanks have just tried this as described but unfortunately I am still getting the error message.
  • kirstygarrat Apr 26, 2009
    The dvd player (Curtis 8723UK) is an English version and the discs we are using are Region 2 and until about a week ago everything was working fine. Then one day we put a dvd in it came up with this error message "wrong region" as has every other original dvd we have tried to play. It will play copied DVD's and cd's.
    Thanks for your advise. Can you advise if you need to have a disc in the unit when trying to press clear. We have turned the unit on tried to press hold and clear nothing is happening except the unit is continuing to display wrong region. Please advise if you know what to do.
Try this on both Curtis models:
Turn the player on.
- Press and hold Clear until the screen turns dark.
- Now enter a region code (0 is defult, or 1 - 8).
- Press and hold Clear. The opening screen comes back.
- The default code (Region 0) is reset when the unit is turned off.
It seems (and this should be verified on more players) that if you enter the number 13 instead of the zone, it makes the player multizone permanently.
Posted on Apr 26, 2009
    Novelist:
  • 166 Answers
I read detailed description of your problem.
And I'm a system programmer for embedded systems like DVD players, MP3 coders,iPODs ,etc...
My group works on contract basis for programming the devices of branded company devices.
So, I wanna let you understand that please don't waste your labor & precious time over it. Actually, while writing software for such devices we are already instructed by companies to code them according to legal issues. They give us chart sheets & specifications for original "disks". By using a particular algorithm we get to know whether your disk is having proper credentials or not. If you try to use same old version of software on your DVD player then it will only play OLDER ORIGINAL DVD's. Since, new original DVD have new standard codes & your player's software can't identify it. So its shows such "wrong region" message.
And unfortunately, after "out of warranty" there is no support provided for software of such DVD players & codecs.
So, either you afford new DVD player or keep playing "pirated or copied" DVD's. Only older original DVD will play and new original DVD won't play.
I hope you understood technical reason behind it. So please don't take so much hurdle for it.
With regards,
Shyny
Posted on Apr 27, 2009
  • Shyny Saxena
    Shyny Saxena Apr 27, 2009
    Rate the solution if it was really helpful to you.
  • Shyny Saxena
    Actually such problem is because of hardware problem like motor failure...use better quality of stepper motor which can throw the tray of the unit of unit outside when you presses such keys...
  • 326 Answers
Hello, thank you for choosing FixYa!
It seems that you may have to try this generic unlock code for Curtis devices.
Turn the player on.
- Now enter a region code (0 is default, or 1 - 8).
Although this would need to be verified regarding your specific devices, it seems that if you enter the number 13 as a zone number, it makes the player multi-zone permanently.
Beyond this, Curtis does not have much in the way of an under-ground following, which means there is very little documentation or experimentation available for research; however you should find that the DVD section of the Box.sk portal should have some various materials for you. I looked for about an hour, but there's nothing regarding your products as of now.
I realize that this may be frustrating, however it may be required to send the product in for service. Please try the above code and let us know how that works for you. Thank you.
    President:
  • 1,223 Answers
Please clean ur lens using Cd lens cleaner with brushes installed on surface , as u say that it was woking fine on all DVD's and now it do not read the same dvd's and wrong region is displayed it some times happens when lens gets dirty it is unable to read or have difficulty to read the disks they give this message by default
pls consider it and clean ur lens firmware will do nothing !
Posted on Apr 24, 2009
  • Shoaib Rais
    Shoaib Rais Apr 25, 2009
    get it diagnosed from a service centre lens is the main culprit i am sure pls consider it
    Sergeant:
    Champion:
  • 219 Answers
Hi! have u tried to make ur played multi region. Hi,
Try this
1. Disconnect your player from its main power source for 30seconds
2.Reconnect your player to its power source
3.Press the power on button on your remote control
4.Press the Enter button on your remote control
5.Press 8,4,2,6 and 9
6.Press Enter on remote control and the your player will place itself on standby mode
7.press the power on button on remote control.
your player is multi region.
Thanks! Sandy
  • 90 Answers
Can u just breif me about your problem?
Posted on Apr 25, 2009
  • 854 Answers
"Turn the player on.
It seems (and this should be verified on more players) that if you enter the number 13 instead of the zone, it makes the player multizone permanently."
    Top Expert:
  • Televison & ... Master
  • 79,851 Answers
DVD's are coded to play only in certain regions where they are sold, this has to do with copywrite laws
Turn the player on.
- Now enter a region code, USA and Canada are region 1 (0 is defult, or 1 - 8 ).
Also refer to this link for info on region codes
http://www.somucheasier.co.uk/dvd-formats.html
Posted on Apr 23, 2009
  • 342 Answers
Have you tried using the code 9735 to change your region? That may be your only issue. Let me know how it goes :)
  • 1 more comment
  • Mel Neilsen
    Mel Neilsen Apr 23, 2009
    Good luck, I apologize that the experts here weren't able to be of more assistance
  • Mel Neilsen
    This is the only further information i was able to find in regards to your issue
  • Open the disc tray
  • Enter 1, 1, 1, 1
  • Select the region using ENTER (9 = multi-region)
  • Press SETUP
  • Mel Neilsen
    Mel Neilsen May 06, 2009
    It appears like you have 13 pending charges for different peoples solutions. I'm not sure exactly if all thirteen are still pending, but it is on my account statements. Do you know how to cancel the fee? If so please do so. I do not feel I deserve you money since I did not resolve your issue
    • 4,472 Answers
    To verify what you've said, none of your original discs are working? This would then be a definite problem with the player itself. This actually seems quite common unfortunately and being that curtis isn't supporting the unit. It does seem there should be a way to update the firmware, but if curtis is no help there is not much you can do. I would recommend purchasing replacements, or just copy your dvds so they are region free. If you need further assistance let me know, also please take a moment to rate my solution appropriately.
    Thank you,
    Lee
    • Lee A.
      Lee A. Apr 23, 2009
      Your welcome. I too saw that post but doesn't look like anyone has heard back. It definitely does seem there should be a firmware so I would definitely hold on to them somewhere on the internet they have to be out there. but based on y our description of their customer service it is possible its a defect in that line of players with no solution. I hope you find what your looking for. Thanks for using fixya.
      Lee
      Genius:
    • 1,847 Answers
    If you are using UK Disk then it should not give you this error message, It seem the firmware is corrupted. Contact Curtis service center and get the firmware updated.
    Else you have to look for an unlock code
    eg : http://www.dvdexploder.com/
    Let me know the status
    Thanks
    K
    • 432 Answers
    I would right click on my computer --> properties --> hardware tab --> device manager --> go to the optical drive section ( dvd drives or cd drives - cant remember what the section is called ) and right click on the relevant dvd drive and go to properties --> in there you should have a region tab.
    It should state how many changes you have and what region it is set to.
    I would check in there.
    Also what software are you using to playback dvds, I would try using vlc ( http://www.videolan.org/vlc ) or windows media player classic.
    See if those help at all.
    Am guessing this is a dvd drive in a computer and not a stand alone one ( or am I wrong in thinking that ? )
      Brigadier General:
    • 3,614 Answers
    try to to do this to remove region code warning:
    • Turn the player on.
    • Press and hold Clear until the screen turns dark.
    • Now enter a region code (0 is defult, or 1 - 8).
    • Press and hold Clear. The opening screen comes back.
    • The default code (Region 0) is reset when the unit is turned off.
    Hope this initial info helps.
    Trying to play dvd but says wrong region soneynhv-dx350ab?
    Hi, if its saying wrong region. then either your player or disk is incompatable. region 1 ntsc ( USA ) Region 2 ( UK ) et,c. check your players region coding is compatable for your country, and that you are also playing a dvd with the same region coding as the player. alternatively is to try and find a region free or multi-region solution. Mike @ Compurepair.
    Jun 12, 2009 | LG RC897T DVD Recorder/VCR Combo
    Wrong Region on Curtis DVD player
    Heya, i also have the same problem with my curtis 8723 DVD. i would be really grateful if you could send mt the info too. roo_wales@hotmail.com .Cheers
    Dec 30, 2008 | Car Audio & Video
    You need a firmware update, I can supply the file needed and instructions on how to load it, its very simple
    Apr 18, 2008 | Digix HT1056A DVD
    Curtis DVD8723UK Wrong Region Problem
    This may be of no help to anyone but I have the same problem and I have spoken to Curtis Support today, they say there is no fix, its a fault in the machine and must be returned to the vendor as they have no service network in the UK. I bought mine with a 90 day guarantee off Ebay and it went faulty after 100 days but probably only used for 3 days so I'm stuffed!!!
    Feb 27, 2008 | Digix HT1056A DVD
    No disk
    Try playing Different DVDs, Second Make sure which Region Disk your playing is it Region 1 or Region 2, If your DVD player is Manufactured in USA it plays only Region 1, If its manufactured in UK it plays only Region 2, If still you face same problem Use Lens Cleaner, If still you face same problem do Reset.
    To Reset Dvd player, Remove DVD from Dvd Player, Unplug Power chord from Walloulet for 15minutes so player goes to Defult Factor Settings, Then plug back again Power chord. Turn on Dvd player insert DVD, It should Play or else Claim Warranty.
    Nov 29, 2007 | Curtis DVD8017 Portable DVD Player
    Movie does not play
    Nov 14, 2007 | Curtis DVD8017 Portable DVD Player
    Televison & Video Logo
    2,284 people viewed this question
    Top Televison & Video Experts
