Question about Dryers
My Roper RED440SQ0 dryer heats but does not tumble. What can it be?
  • Dryers Master
  • 7,482 Answers
Hi Lila S
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley, or a faulty motor.
Note: This method works for most front loading machines.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completely.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
Here is a link to see a picture of your belt routing in case the belt is broken when you open your dryer:
http://www.expertappliance.com/dryerbeltconfiguration.html
While you have the drum out, I would recommend that you remove and lubricate the drum rollers.
And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
You can order parts from the following webpage
http://www.partselect.ca/Models/RED4400SQ0/#PartsBud
Posted on Oct 12, 2013
  • 74 Answers
SOURCE: Dryer tumbles but doesn't heat
When this happens, something has interrupted the heat source. Run the dryer for a couple of minutes to see if it gets hot. Be sure you don't have the dial or controls on a non-heat setting, such as "Fluff" or "Wrinkle Control." On an electric dryer, this may mean that the circuit breaker or fuse that controls the power has blown --check and replace or reset. Be aware that a dryer may have two breakers or fuses: the motor will run when one works, but the heating element requires both. On a gas dryer, recheck the control's setting to be sure it's not on a heat-free setting. Check the gas valve behind the dryer to be sure the gas supply is turned on. Also make sure the house's main gas valve is turned on. On an older dryer, make sure the pilot light is burning. If it isn't, re-light it. You can find directions HERE or in your owner's manual (pilot light instructions are often mounted next to the pilot light on the burner, too). Note: Most modern dryers have electronic ignition instead of a pilot light. If yours has electronic ignition and isn't heating, call a qualified repair person.
Posted on Jan 18, 2006
SOURCE: Roper Gas Dryer
Taking the back off the dryer towards the bottom in the center there is a white pc.of plastic about 3 inches long and 3/8" wide. Its clipped on the inside panel and has a screw securing it. It has two wires clipped to it.Thats the fuse ! I got a replacement form the local Sears parts store for about $15.00.
Posted on Dec 31, 2007
  • 147 Answers
SOURCE: Roper dryer, timer doesn't time out and not heating up?
Dryer will run forever if it doesnt heat up, Dryer has to heat up and thermostat has to get hot and open to start the timer. Odds are rally great, it is your heating element.
Posted on Oct 20, 2008
  • 163 Answers
SOURCE: My Roper Electric Dryer will not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
SOURCE: Roper Dryer Won't Turn On
Ok...almost same problem...resolved by replacing thermal fuse by blower....so I guess the thermal fuse can just go with a little surge from opening closing door switch if it was already on its way out...or something...but simple fix anyway....thanks for giving me the order of things to try!
Posted on Jan 16, 2009
My Roper dryer, model RED4100sq0, will tumble but not dry. Also, the timer does not run so the dryer runs continously after starting. There is no heat from the element. Both of these problems started at...
I fixed a roper dryer with a no heat problem and I did a youtube video you can google Roper Dryer no heat if my movie does not show but I gonna post it for you.
Sep 30, 2013 | Roper Dryers
MY Roper Dryer model # RED4340SQ1,Will Tumble but not Dry Clothes
For this job, all your work is going to be behind the machine. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced
Apr 25, 2012 | Roper REX4634KQ Electric Dryer
My Roper dryer quit running...it's heating but doesn't seem to come on or tumble.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 20, 2010 | Dryers
My Roper elictric dryer is not drying clothes
If you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some tihings to check before assuming there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call. If you check everything and still have poor heating issues, please let me know. You may have an internal bias or hi-limit thermostat malfunctioning.
Jan 05, 2010 | Roper RES7646KQ Electric Dryer
Roper Gas Dryer not heating.
Is the fuse on the picture is the one you bypassed:
The thermal fuse
- The wiring diagram which may help you.Here is information about prices n more elements that you may need.http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/Dryer-Thermostats-and-Fuses/index.aspx "Did I answer your question ?
Did it solve your problem?"
Jan 19, 2009 | Roper RGX4634KQ Gas Dryer
Dryer tumbles, no heat
its a gas dryer it doesnt have ,,heating element...replace thermal fuse
Dec 28, 2008 | Roper RGX4634KQ Gas Dryer
Gas dryer problem
I am getting water in my vent hose. What could cause this.
Dec 13, 2008 | Roper RGX4634KQ Gas Dryer
Oct 01, 2008 | Roper REX4634KQ Electric Dryer
Emerso Dyrer doesn't give heat
Your issue is;
"I have an Emerson electric dryer model # RED440SQ0. The dryer spins but there is no help. Thanks for any help. "
Based on the information provided above, I am unable to access my database to provide you with exacting information. An invalid model number was returned... However, I have provided some common solutions to help guide you in your search.
This information is for a generic brand dryer only!
My Solution is:
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual.
Note: A volt-ohm meter is beneficial in performing electrical tests.
Temperature Switch; make sure a positive heat selection has been made, still no heat, then check these:
If your dryer doesn't heat, check these:
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 23, 2008 | Dryers
Dryers Logo
41 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
