Question about ASUS Eee 4G Notebook
Black screen I got a new computer. I wanted to restore my old computer (Dell 2350 XP) to factory. I was told to put in the service pack 2 CD. I did that but after it installed it my screen resolution was bad & it wouldn't let me change it. I am new to this computer thing & obviously did something wrong. Because my screen now goes black after the Dell logo & Windows logo. Then I hear a beep. If I hit an F# key it says Key board error or keyboard not found. I tried another keyboard but same thing. I do not have that computer set up to the internet yet because I can't see anything on the screen to do it. I moved if from one room to another.
  • 15 more comments
  • connieandtom Apr 23, 2009
    I tried both of those suggestions however I just got a beep as before.
    It is not a new computer. Therefore it isn't still under warranty.
    It isn't a laptop. It is a desktop.
    No problem with your advice I would just like to hear from someone else please. Thanks
    When I went into safe mode it just had about 20 lines or so each line started with:
    multi(0)disk(0)rddisk(0)partition(2)/windows/fonts/vgaoem.con
    It wouldn't do anything in VGA mode. Thanks
    No all the lines were different at the end. How long should I give as a reasonable amout of time?
    I do have all my reinstallation CD's (service pack 1 &2) along with all the other CD's 4 or 5 others. When I wanted to restore it to factory settings because ther was too much stuff on there I was told to just put in Service Pack 2 & that would solve my problems however that's when my problems started. Now if I put in the Service Pack 2 CD nothing happens. The screen just stays black. Someone told me to start my computer, put in the CD, turn off PC & restart with CD in. That didn't work. Screen stayed black.
    No, I don't have that cd. I have one that says Microsoft office xp
    1. I have re-installation cd microsoft Windows xp Home Edition Incliding Service pack one---2. re-installation cd microsoft Windows xp Home Edition Incliding Service pack two--3. Application For Installing/reinstalling Roxio easy CD creator 5.2 basic--4. Drivers & utilities Contents: Device drivers, diagnostics and utilities, computer documentation--5. Application for reinstalling Dell tools system software Contents:Anti-virus software, support software,multi-media software, Internet software--6. Drivers & Utilities for reinstalling v.92/56k Telephony data/fax matem software for microsoft windows.
    YAHOO!! I have a setup screen:Windows xp home edition set-up--welcome to set up. This portion of setup program prepares microsoft windows xp to run on your computer. I have 3 options: Setup win xp now--repair a win xp installation using reovery console-- quit setup
    Now what do I do?? I hope I didn't lose you. You are the most help I have had yet.
  • connieandtom Apr 24, 2009
    Thank you for advice. I just got in & I am going to go right now & try it.
  • connieandtom Apr 25, 2009
    Whoo Hooo!!! You are the expert. Ok it wiped everything out but installed a new windows, Which is fine but do I now need to reinstall application and drivers & utilities discs.
    wipdhuls is the one who solved the problem for me. But as I said I need to know if I now need to reinstall those other discs. When I tried to play a music disc it said "Hardware not installed". I so appreciate all the advice that was given.
    OK that worked great but now when I try to hook up the internet I get a message "need a ethernet adapter" We bought a box that we can install 4 computers into & I installed the ethernet cable to the computer but I still get the error message. Again I can't thank you enough for all of your help.
    It isn't a wireless routher. It is a wired one. I have another computer connected to it & it works fine.
  • connieandtom Apr 27, 2009
    Thank You so much!!! I honestly thought trying to fix my Dell Dimension 2350 XP was a lost cause. But you helped me by giving specific step-by-step instructions which was exactly what I needed since you are the expert & I am totally clueless. Your response time to my questions was very quick. Thanks a heap!!!
    Novelist:
  • 133 Answers
Unfortunately the previous expert left the question open and I had to grab it..
Here is the complete solution .. although it might seem to be hugh but its screen by screen description of what is going to happen and what we are going to select so please do not get intimidated by the lenght of the solution.
By following the steps below, you will repair your computer and will not loose the data and installations on your system .. so its a NON DESTRUCTIVE RECOVERY of the system.
Start your PC with the setup CD in a drive, and hit a key when you see the message "Press any key to boot from CD"
If instead of booting to the CD your PC boots from the hard drive, you may need to modify your PC's "boot order." It's easy and only takes a minute to make the change so that the PC will check for a bootable CD before trying to boot from the hard drive. It done from the BIOS setup screen.
Once your PC starts to boot from the CD, you'll see something like "Setup is inspecting your computer's hardware..."
After a minute or two, you'll see the "Windows Setup/Setup is starting Windows" screen. Don't be alarmed.. It's still just the setup process running, and nothing's been changed on your PC yet.
Soon after above Screen, you'll be presented with the normal "Welcome to Setup" screen".
Hit Enter, just as if you were setting up Windows afresh and from scratch.
Press F8 to accept the licensing terms and to go on.
Next, the XP setup process will show another screen that you may recall from your initial setup of XP. It searches for "a previous version of Microsoft Windows." In our case, we're not replacing a previous version of Windows, but rather repairing the very same version that's on the setup CD--but that's OK; it's just another poorly worded screen.
Setup should find your damaged copy of XP and present it for repair
If your damaged copy of XP isn't highlighted in the list box, highlight it now. When it's selected, press R to start the repair process.
The Repair process then selectively deletes system files in the \Windows folder and subfolders and copies undamaged replacement files from the setup CD to their proper locations.
The system then needs to reboot and will do so automatically. If your setup CD is still in the drive, remove it so that the system won't try to boot from it.
The first Repair reboot will take longer than normal.
Please Don't be alarmed when Setup resumes. Once again, it will appear that you're performing a full, from-scratch setup; there's nothing on-screen to indicate that you're repairing an existing version of XP. But although the setup screens are the same as what you'd see in a full install, it's still a repair process, as will become clearer in a moment.
Follow the normal steps.
When this portion of the Repair is done, you'll see a "completing installation" screen
Setup then reboots your PC again, and this reboot will also take longer than usual. This is normal.
After the reboot, you'll be brought to an abbreviated version of the "Welcome To Windows" setup pages.
You'll be asked if you want to register and--depending on how badly hosed the previous installation was--you may or may not be asked to reactivate the copy of Windows. Next, the setup software handles the final networking details and then offers a "thank you" screen.
In most cases, the system will now reboot for a final time. The Repair is done. It's a normal boot, bringing you to the normal choices for login.
If all has gone as planned, you'll find all the user accounts and passwords intact, all the hardware devices set up as before, and all the previously installed software still installed and configured. In fact, if all has gone as planned, the only significant change will be that whatever problem your copy of XP was previously experiencing will now be gone!
Please let me know if this has been helpful to you and do not forget to rate the solution in case it was helpful to you.
Thanks and Regards,
Srinivas
Posted on Apr 24, 2009
  • 2 more comments
  • Srinivas Dhulipala
    Srinivas Dhulipala Apr 25, 2009
    I am glad that I could assist you :)
    For the other question that you had ...
    Right click on the "My computer" --> Proterties --> Hardware tab --> Click on the Device manager button.
    If you find that there is a Question Mark (?) or a Red X or an exclamation mark next to any of the Hardware devices, then Yes, you will have to uninstall the corrupt device drivers and install a new copy or you can just right click on the device and choose Update drivers and the computer would try to select correct and upgraded drivers for the device itself.
    Please let me know if that helps :)
    Best Regards,
    Srinivas
    What I understand from your description is that you have bought a Wireless Router and the Ethernet is connected to the router and you surf internet using wireless... In that case just turn the wireless ON on your computer and see if the computer able to detect any wireless signal.. and if does then check to see if you can get connected to the available network.. If you can detect the signal but are unable to connect to it then it would be due to the WEP/WAP key protection that is enabled on the Router.. You might want to contact the router support in that case or provide me the model number of the router and I will see if I can gather any info.
    Thanks and Regards,
    Srinivas
    Did you try reinstalling the Network card drivers?
    When you connect the Ethernet cable to the computer .. is there any indication on the router that a computer has been connected (usually in a form on LED) ?
    As you said you have another computer that works so did you try swapping the Ethernet cable?
    When you connect the Ethernet cable .. there is a green LED in the NIC (Network Interface Card) that glows .. do u see the LED glow?
    Does the Device manager indicate that the NIC is working fine?
    Did you try disabling the Windows Firewall?
    Please try the above steps and let me know if that works...
    All the best :)
    Regards,
    Srinivas
    Srinivas Dhulipala Apr 27, 2009
    Hello ConnieAndTom,
    I am still waiting for an update .. Please let me know if it helped. :)
    Thanks and Regards,
    Srinivas
  • ASUS Master
  • 13,433 Answers
The keyboard error comes most likely because your holding the buttons down and the computer thinks the keyboard is broken.
To start up your computer, before the xp logo comes but after the dell logo has gone, tap f8 around every second untill advanced start up options come up, then select safe mode or vga mode.
one or the other of these will start the computer.
the issue is most likely with the video card drivers.
Ones you are in safe mode, right click on my computer and select manage. then on the management window click on device manager, then on the right side find display adapter.
Right click on the display adapter that comes up, then select uninstall and if it asks put a X on the check box on uninstall software.
ones its uninstalled you can restart the computer normally just let it start up, it should start up normally and now you need to get the correct drivers for the display adapter from the asus website.
let me know how it goes.
Thanks,
Ekse
Posted on Apr 23, 2009
  • 6 more comments
  • Ekse Apr 23, 2009
    its normal to get those lines but did you see the same line many times? let it load it might take a while.
    Do you see the same line with the same file name at the end many times?
  • Ekse Apr 23, 2009
    20 minutes, if it doesn't start up in that time then you need to re-install windows into the computer or restore the computer to originals.
    if it doesn't start up then the windows installation is corrupt or messed up and it can be fixed by installing windows from the cd and it should work normally.
    Did you get disc's with the computer and do you have a cd drive for the computer?
  • Ekse Apr 23, 2009
    You need a cd like this or then a restore cd.
    Thats the original windows xp installation cd. you might have a restore disk ther with you. Try the CD1 and other disks that you have.
    make sure the computer is actually starting from the cd. on somepart of the screen when you turn it on it should say, press XX to enter boot menu or similiar press that button and in the boot menu select the cd rom drive. ir you don't get that then you need to go into the setup / cmos / bios setup settings and change the boot order /start up order so that the computer first tries to start from the cd and then from the hard drive.
    dell instructions
    http://support.dell.com/support/edocs/sy...
  • Ekse Apr 23, 2009
    thats the office, word, excel, powerpoint etc. what order cds do you have? you need a restore disc or the windows xp installation disc to install your windows again into the computer from scratch.
  • Ekse Apr 23, 2009
    Okay then the only problem seems to be starting from the cd. I posted a link to that dell page you can find instructions from there.
  • Ekse Apr 24, 2009
    Hi
    Sorry I had gone to bed.
    Do a fresh install was it enter? Setup win xp now.
    please let me know how it goes, I would really appriciate it if you accept my solution.
    You can email me directly at nikoht@gmail.com to continue solving this problem.
    Thanks,
    Niko ( Fixya - Ekse)
  • Ekse Apr 24, 2009
    I would appriciate it if you could accept my solution. email me if you need further assistance.
    Thanks
  • Ekse Apr 25, 2009
    Are you responding to me? can you email me at nikoht@gmail.com?
  • 3,866 Answers
Hello
Seems like a video card issue, if you new to computers then I would not recommend you open it up and try solutions that way if it is new and under warrenty what needs to happen from here is call DELL there fantastic and they have a in home service that will come to you and switch out that part within a good time frame. Because it is a new computer I will never tell you to open it up and try to fix it youself as its under warrenty please please please have them come out and fixit. If your satisfied what what I am suggesting please accept it, if you have more questions for me please let me know before you rate or accept this solution.
THANKS
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
  • Grand Canyon Tech
    Grand Canyon Tech Apr 23, 2009
    ifthis is a laptop try hooking it up to a monitor and see if it turns on if it does change the resolution to the lowest and see if it works. good luck.
  • Grand Canyon Tech
    Okay the description had a pic of a notebook sorry about this. Your going to need then is to take it in to have the video card looked at because of the no video issue and because of the resoulution being out of controll. I looked on the website for this issue and its tied to the video card and since its on board you may need to get one from like best buy/fry's ETC on your desciption it sais new computer so i assumed it was still under warrenty.
    Thanks
Emachines c2881 unable to upgrade to sp2
Yeah, but you may not care for it.
I, personally abhor the automated feature of Service Packs.
I would rather download Manually, and see what I'm getting.
Takes longer?
Sure.
Cramming junk down my throat that I don't want, don't need, and it is just filling good space I need on my harddrive?
Uh, no.
What to download, there's so much stuff, and I don't know what I'm looking at?
Just download the basics.
What?
Okay, download manually one at a time. When you can't boot your computer, Yep, that one has got to go.
Acer, (Excuse me, I mean eMachines), wants how MUCH?
You told them you could buy a better, used, computer, for that much.
Right?
(I know. I know. Be nice. There's always time to be bad. Lol!)
Lemme see. What could Acer have done for 150 bucks.
Motherboard? Ummm. Harddrive and new genuine copy of Windows XP? Ummmm.
Naa!
They were going to pick your computer apart, to see what the problem was.
You stated " I even tried not using the restore cd but a copy of XP again...."
Meaning a;
1) NEW genuine copy of Windows XP?
2) Genuine copy of Windows XP from another computer?
What are we talkin' about here?
I want to know what the original problem was? Why were you using the Restoration Disk in the first place?
Post back in a Comment.
Regards,
joecoolvette
Jul 08, 2012 | E-Machines Computers & Internet
Factory settings restore on dell inspiron 1525 windows vista
Resetting a Dell Inspiron to the factory settings allows the user to restore the Dell Inspiron to the original operating condition as if it was just taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Get the step-by-step how to guide..http://technical-support-squad.blogspot.in/2012/08/dell-inspiron-how-to-factory-reset.html
Feb 12, 2012 | Dell Inspiron 1525 Laptop
My daughters computer is a dell latitude D610 notebook running Windows XP.....when powering up XP starts to load and then goes to a blank blue screen....Is there a restore disc or something i can download...
Hi. I provided you a link where to download the restore disk. Once you have downloaded the restore disk, here's the instruction on how to use the disk.
Instruction:
  • Backup all the data you want to keep on an external hard drive, flash drive, or rewritable CD. Resetting your Dell to factory defaults will erase all data currently on your computer.
  • 2
    Insert the Recovery CD into your CD-ROM.
  • 3
    Reboot your computer.
  • 4
    Watch the text in DOS carefully. When prompted to boot from your CD, do so.
  • 5
    Choose System Restore and then follow the instructions presented. Once system recovery beings, it may take a few minutes. Once it's done, your system will reboot again.
  • 6
    Remove the Recovery CD from your CD-ROM and store it carefully. Your system has been reset to the factory default.
  • Nov 09, 2010 | Dell Latitude D610 Notebook
    How to restore dell vostro 200 computer back to factory settings
    1. Restart the computer.
    2. As the computer restarts, press the F8 key until the Advanced Boot Options menu appears on the screen.
    Note:
    You must press F8 before the Windows logo appears on the screen. If you press F8 after the Windows logo appears, the Advanced Boot Options menu does not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
    3. Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter.
    4. Specify the language settings that you want, and then click Next.
    5. Log in as a user who has administrative credentials, and then click OK.
    6. Click Dell Factory Image Restore.
    7. In the Dell Factory Image Restore window, click Next.
    8. Click to select the check box for Yes, reformat hard drive and restore system software to factory condition.
    9. Click Next. The computer is restored to the default factory configuration.
    10. When the restore operation is completed, click Finish to restart the computer.
    Jun 11, 2010 | Dell Vostro 200 PC Desktop
    I get a stop error message when I try to install windows like this stop: 0x0000007e pci.sys
    the error that you are getting is caused when you use an old Windows XP CD without service pack 2 integrated. If you want to install XP on to the new system you must use an XP CD that has service pack 2 integrated.
    Nov 16, 2009 | Dell Inspiron B130 Notebook
    How to reset my dell computer dimension 2400 back to factory settings. when I turn on the computer I was told oce I see the blue dell logo to press CTRL F11 but it want bring nothing up to default it back!...
    Here are the Dell instructions for PC-Restore. The actual process is listed in step 3
    http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=2684&l=en&s=pub&docid=DC47E7957E35BBC0E030A68F27280D16&journalid=752C8744BD74435FE040AE0AB6E1477A&Query=cGMrcmVzdG9yZQ==&SystemID=PRN_ALL_A926&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
    When you start the system, after the Dell Splash Screen, there should be a black screen with a blue bar across the top with www.dell.com in white letters. If that page does not show, then PC-Restore will not work. If you do see that screen, you have to be very fast with the CTRL+F11 key combination at that screen. It should open PC Restore by symantec. On a system this old, it if very likely the restore image is no longer intact and my not function. If you get into the tool and it errors out, or you have no PC-Restore, then you will need to install XP from the CD and load drivers.
    Oct 05, 2009 | Dell Dimension 2400 PC Desktop
    How to obtain windows xp install cd to restore to factory setting
    hi
    regarding battery u need new battery
    and regarding battery u can buy it from market or u can download it from the following link http://www.softwarepatch.com/windows/xpsp2.html
    Jun 25, 2009 | Toshiba Satellite M35-S359 Notebook
    After downloading windows xp service pack 3: screen turned black boot failure/won't bootup without CD old files missing screen flickers hardware missing
    you will have to restor it to factory stetings there is nothing else i can think that you would be able to do
    please rate my help to you
    thank you.
    Apr 22, 2009 | Computers & Internet
    Inspiron 6000
    If you purchased your I6000 after 2005, then it still has the PC Restore option. For Dell system with Windows XP, your can restore your computer to factory settings by pressing CTRL+F11 when you see the page after the big DELL Logo. It's a BLACK SCREEN with a blue bar at the top and it has www.dell.com written in white. Usually this screen will show up in between the DELL Logo and Windows Logo.
    Nov 22, 2008 | Dell Inspiron 6000 Notebook
    Dell Dimension 2350 restore cd or bootable cd.
    go to pricegrabber.com to buy a new copy of XP. Save the stuff U want and install the new os. reload U'r saved data. If some of what U wnat to save are programs, U will have to reinstall those. The new XP os will self install from cd on boot up.
    May 21, 2008 | Dell Dimension 2350 PC Desktop
    ASUS Eee 4G Notebook Logo
    192 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
