Question about Thermador SC302T Electric Double Oven
I have a Thermador SC302TB double oven. It is taking a lot longer to cook then it use to. I put a thermistor in side the oven and turned it on to 350 the oven went up to 390 and stayed there. any clue. there is no code or anything
Master_Tech
  • 770 Answers
SOURCE: f7 error
F7= function key is stuck or shorted >> you can turn the breaker off to the unit then back on if it come back up it will have to be replaced
Posted on Jan 27, 2008
  • 1314 Answers
SOURCE: Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Posted on Jan 30, 2008
  • 5 Answers
SOURCE: thermador c302 door hinges
487746 is the part number for the 30 inch model and
487747 is the part number for the 27 inch model if this is the parts you recieved then the should fit there should not be much difference
Posted on Jan 15, 2009
SOURCE: thermador SC302 double oven the top oven is not getting hot
Thermador double oven, in Montreal Quebec. Similar problem with the display fading out. Thermador should step up to the plate or be obliged to through legal action.
Posted on May 02, 2010
Macmarkus
  • 2605 Answers
SOURCE: The clock works but the oven does not heat up
Hello George, welcome to fixya.
The symptoms you describe are a common occurrence when the hi-limit has tripped. This typically occur's following a self clean cycle. The display will indicate the oven is indeed "on" but it will not heat do to the circuit being interrupted by the hi-limit ( which is what it was designed to do ).
Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the door and just below the control panel next to the lock latch assembly. **Turn off the 40amp breaker at your service panel or sub-panel in the home before attempting any service...safety first**
With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...if indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down. It will look like the image below...52bc5ab.jpg
Let me know if I can assist you further. If this solves your problem please rate the solution accordingly, if not let me know and I`ll try to guide you through other possible scenario`s.
Thanks for visiting "fixya" and good luck.
macmarkus :)
Posted on Jun 15, 2010
Help!!! Need Replacement knob kit for my Thermador double oven!
these are NLA. No Longer Available.
Try to get something that is acceptable to you and fits by researching "oven Knobs" at repair clinic dot com and selecting by looks and size.
Nov 09, 2013 | Thermador SC302T Electric Double Oven
What does E 2 on a thermador convection thermal double oven mean
depending on the model, could be run away cook/clean temps.
Oct 15, 2012 | Thermador Ovens
I have broken the outer glass on one of the doors on a thermador SC302TB oven. Is replacing the glass something that a handy homeowner could do?
Yes. replacing the over door glass is no more difficult than removing a few screws, inserting the new glass and reattaching the screws.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232432&diagram_id=194162#d194162
That link will take you to a detailed image of the door as well as where you can order a replacement.
Hope this helps.
Sep 06, 2011 | Thermador SC302T Electric Double Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
Probe light stays on so I can't cook
Hey i just got knocked out of the session can you please get back in to the session
Nov 26, 2009 | Thermador SEC272BPSS Electric Double Oven
GE truetemp double oven fan runs for an hour after I turn it off
Take it out back and shoot it. You are better off cutting your losses now and be done with it. If you have had it for 10 years, I am surprised you haven't burned your house down with it.
Seriously, it would cost a lot to fix it, plus it would frustrate you more and more the longer you put money into it.
Feb 03, 2009 | Ovens
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Thermador double oven SC302 Fault code F34
first check to see if the oven is under warranty it might also be a manufacturers defect
Dec 30, 2007 | Thermador SC302T Electric Double Oven
Open Questions:
See all Thermador SC302T Electric Double Oven Questions
Thermador SC302T Electric Double Oven Logo
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
