Question about Microwave Ovens
I have a Riccar microwave oven Model RM691N. The power button broke off. any idea where I could get a replacement part?
MicrowaveSvc
  • 9047 Answers
SOURCE: jenn air microwave oven door handle
You can find helpful exploded view diagrams for the similar model M438 here: http://tinyurl.com/gv383
The model M437 is not listed, but the M438 is, and it should be similar enough to guide you. Just don't count on the part numbers being the same.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Sensor Microwave Oven (Model
You can download your owner's manual free here
Posted on Jun 23, 2008
vitg55
  • 70 Answers
SOURCE: My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Posted on Dec 15, 2008
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Posted on Mar 26, 2009
  • 4088 Answers
SOURCE: HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Posted on Jul 12, 2009
Kitchen aid mircowave #KCMS125YSB-0
I went to the following website but it is not looking good for parts for your microwave. I am guessing from the number of things that are not available anymore, and the very high prices on things that are still available that this must be an old microwave. They might be able to point you in another direction if they do not have your part.
KitchenAid Oven Microwave Combo Model KCMS125YSB0 Parts
Feb 26, 2015 | Microwave Ovens
GE SPACEMAKER MICROWAVE OVEN MODEL J VM64 003 LIGHT SWITCH BROKE HOW DO I REPLACE IT?
Unfortunately it appears none of these parts are avail anymore. The physical buttons, key panel assy, touch pad support are no longer available. The smart board (WB27X5239) seems to floating around, but this does not appear to contain either of the 2 buttons or switches as part of it's assembly. Pleazer Appliance..
Jan 11, 2015 | GE Microwave Ovens
Has stopped working. light gone off at same time. plug fuse has not broke. any ideas ?
There is a fuse inside the microwave also.It is a ceramic fuse,usually 15A.It has to be replaced with another ceramic fuse of the same rating.Bear in mind,the fuse blew for a reason,so if it is the interior fuse replace it after a search for a fault.
Dec 17, 2014 | Microwave Ovens
Viking Microwave Model DMOC205SS, manufactured June, 2004 does not have any Power. It is Not a fuse problem. Any ideas?
Have you tried toggling the door button? I have found that we need to hold the door button to get power on. One person said this due to slamming of the microwave door.
Aug 24, 2012 | Viking VMOC205SS Microwave Oven
No power on microwave. model mmv1153BAW. is it broke
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 07, 2011 | Maytag Appliances Over-the-Range Microwave...
No power to oven after removing light bulb
What happend is that when the bulb broke the filiments touched (shorted out) and caused the reset switch on the unit to set>>>you need to find the reset button on this unit, look at your service manual. Additionally on some units there is a fused link internally, that may have blown>>>>both are an easy fix, so dont throw it out.
Good luck,
Geodesy
Sep 22, 2009 | LG Over-the-Range Microwave
'Start' button won't depress, seems jammed; timer knob broke off
the button is stuck because of food buildup over the years underneath the button, this happens even to newer ones after about a year of use, new microwaves are cheap and the lower end models start at only $35 from walmart I would reccomend buying a new one, newer microwaves use less power and are more effecient so a new one will pay for itself in saved electricty costs after about 2-3 years of use.
May 11, 2009 | Emerson Microwave Ovens
No Power Whirlpool MH7140XF
does it not light up at all? A microwave has a fuse on it. Probably accessible from the back panel. if not you would need to disassemble it. Most likely cause of this is slamming the door broke one of the safety switches the door has so the microwave knows when the door is open. And it shorted against something when it broke. It might have simply blew the fuse but then again you might have fried it.
Oct 01, 2007 | Whirlpool MH7140XF Microwave Oven
Microwave Ovens Logo
74 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
