Question about Hotpoint Dryers
My hotpoint condensed dryer is steaming up my windows and I don't know why as I thought that was the point of the condenser. It's model number is Tcm 850, anyone got any suggestions or can help, thanx
  • Scott
    Scott Mar 07, 2014
    Cleaned all the filter ect, nothing worked so called the guys I bought it from and they replaced it, thanx guys for tips
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
Hello Scot, just make sure the fluff filter is clean and the exit tube for the air is clean they should just slide out fluff filter and pull off the fluff and the air exit tube normally get quite dirty with fluff and debris. So take that out and take it outside and wash it through with a hose from both ends. The water tray should also be emptied regularly but the panel will tell you when that is full.
Hope that helps
Steve
Posted on Oct 12, 2013
Testimonial: "Thanx Steve I will try that, also the dryer is a refurb that I baught don't think that will be a problem will it? When I fitted the dryer it's actually right next the the washing machine which is a tight fit may this be a problem? Thanx"
  • Scott
    Scott Oct 12, 2013
4 Suggested Answers
  • 139 Answers
SOURCE: Hotpoint Condenser Dryer Model CDT00
Either your heater is blow or your thermal cut outs are blown easy to check and replace ...
The are located at the back of the dryer behind the protuding funny shaped panel...
Check the continuity on the t-stats if no present then replace both of them small round things
then its the heater....
Posted on Jan 21, 2008
  • 139 Answers
SOURCE: no heat
hi there
your problem is either the t-stats have blown which is very common or your heater is blown..
im guessin your t-stats beacuse they are the most common on hotpoint dryers to blow. There always blowing
They located at the back of the dryer behind the protuding panel so there for you dont need to open it all up just that panel.
To check if their blown check for continuity,, no continuity no good merry christmas cheers
Posted on Dec 24, 2007
SOURCE: HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Posted on Sep 10, 2009
I have a Hotpoint Aquarius condenser dryer model number tdc32p serial number 28101317. Is this a recall tumble dryer please
call ge they'll know i think it's 1-800-gecares look at the model tag or manual to find number
Feb 06, 2018 | Hotpoint Dryers
Hotpoint Aquarius condenser dryer, TCM 580p. Where can I purchase a pump microswitch?
A local appliance parts supplier might be able to help. You also can go to www.repairclinic.com and enter Hotpoint TCM580P to see a list of available parts.
Dec 16, 2015 | Dryers
Model: LG Steam Dryers DLEX2501R Problem: Shows "Check Filter", while dryer still does the job
do you mean a condenser dryer?, as steam is water doesn't dry anything to well, if it is a condenser dryer the check filter or clean filter light should always come on towards the end of the cycle (varies between models some have both clean filter and empty tank lights on at end of cycle just as a reminder to do so and some don't have any lights), it is simply a reminder for you to clean the filter after each use unless this is something that has only just recently happened
Apr 17, 2011 | LG DLE2514 Electric Dryer
I have a new (1 month old) Hotpoint Condenser Dryer (TCD980G). When it is on the drying cycle it runs for about 30 minutes and then trips the RCD circuit. I have cleaned the condenser filter and the water...
There should be no condensation present if it is a condenser dryer, this is the idea of it.
As for tripping the electrice, then it suggests to me that the steam could be the cause of the problem.
As it is a new dryer, then I would strongly advise you ring Hotpoint service, or ring the help line number in your instruction book.
You can contact them at the following address if needed.
WWW.HOTPOINTSERVICE.CO.UK
Jan 01, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WD440 1400spin. How long can the vent pipe From the Dryer be ???
If it is washer dryer, then it does not need ventimg, as it is a condenser type dryer, which condenses the steam back to wate therefore no hose neededr
Nov 01, 2010 | Hotpoint Washing Machines
PROBLEM WITH HOTPOINT WASHER DRYER - MODEL BWD 129-ON DRY CYCLE CLOTHES COME OUT STEAMING AND WET. PLEASE ADVISE
If the clothes are coming out hot and steaming, then the water from the clothes is not condensing, it could be a blocked condenser, which will have to be removed and unblocked and cleaned.
The other possibility is that there is no cold water coming in on the drying cycle, this can also have the same effect.
Hope this helps.
Dec 03, 2009 | Hotpoint Washing Machines
Condenser on Hotpoint Aquarius dryer not collecting water
I think that I have already suggested some possible reasons for the prob you are experiencing with your dryer, but I don't think I have mentioned the fact that the pump could be fauty, you should be able to hear it running, just a thought , you never know.
Jan 12, 2009 | Hotpoint TDC32 Electric Dryer
Dryer problrm
The sympoms are typical of a couple of reasons.
  1. Blocked condenser.
  2. faulty cold inlet valve, not letting water in to condense steam back to water.
When it is on the drying cycle, see if you can see water pumping out of the drain at. a slow rate.
If you can see no water at all coming from outlet hose, then chances are it is a faulty valve, and you will have replace same.
Plz rate my solution.
Thanks.
Jan 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Not drying
the steam gets condensed back to water and pumped away so sometimes draining problems cause poor drying. is the machine plumbed in according to handbook?
also your dryer filter may be blocked but this is not accesable without the dryer box being stripped down.
Nov 05, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryers Logo
76 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
