Question about Kenmore Elite HE4 Electric Dryer
Pf code on kenmore quietpak HE9 frontloading dryer
  • 146 Answers
SOURCE: kenmore 67082 "PF" power failure code
Check your circuit breaker. Reset it even if it doesn't look tripped. It is a dual switch and sometimes you can't tell if one of them is tripped. Then try it. When you reset the breakers leave them off for about 10 minutes before turning them back on.
Posted on Dec 24, 2007
SOURCE: My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Posted on Feb 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Smartheat Quietpak 9 HE4 dryer taking longer to dry
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
  • 314 Answers
SOURCE: kenmore dryer will only work on no heat
The Kenmore H5T is an electric clothes dryer meant for residential use and manufactured by the Kenmore Company, which manufactures a wide variety of appliances for the home, including refrigerators, dishwashers, microwaves, stoves, and clothes washers and dryers. While most Kenmore clothes dryers work well with only basic care and maintenance, certain problems, such as the dryer not heating, occasionally occur. Troubleshooting this issue may solve the problem without the help of a service technician.
instruction
  • Ensure that the dryer is properly connected to a working grounded power supply. Confirm that the power cord is plugged firmly into the dryer and the power outlet. Reset household fuses or circuit breakers if necessary.
  • 2 Remove the lint screen from the bottom front of the dryer. Pull off all lint so that the filter screen is clean, and replace the lint screen in the dryer.
  • Run the dryer for 5 minutes on a normal cycle and hold your hand under the outside exhaust hood to feel for air movement. If there is no air movement, turn off the dryer and unplug the unit. Disconnect the exhaust vent and clean out any possible obstructions, such as excess lint. Reconnect and confirm that the vent is not kinked or crushed and preventing proper heated air flow.
  • Ensure the dryer is not in a room or outside with ambient temperatures below 45 degrees Fahrenheit. The dryer will be unable to heat properly if the ambient temperature is too low.
  • Avoid overloading the dryer with too many clothes, which will limit proper heat and air flow in the dryer. Make sure the dryer is not set on an "Air Only" dry cycle, which does not provide heat.
  • Contact an authorized service technician if the preceding steps do not resolve the problem.
  • Posted on Dec 20, 2010
    LG WASHER/DRYER COMBO PF Issues
    pf is power failure,, need to replace main board... there should be a parts/repair manual inside unit.. usually bottom panel...
    Aug 15, 2016 | LG Washing Machines
    Kenmore Elite Oasis Electric Dryer - no power (PF code)
    Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
    Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
    May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
    PF code but I have power at the outlet.
    Here is a tips that I wrote that will help to explain why you get the PF Error Code
    PF Error Code for Appliances
    heatman101
    Dec 18, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
    It is showing a code of PF on the front
    heatman101
    Sep 16, 2010 | Kenmore Elite HE4 Electric Dryer
    Kenmore elite he4 quiet pak 9 dryer display code
    May 15, 2010 | Kenmore Elite HE4 Electric Dryer
    dave
    Feb 09, 2010 | Kenmore Elite HE4 Electric Dryer
    Kenmore Elite QuietPak 9 Dryer - door opens constantly
    I'm not solving the problem, but just wanted to say I have the same problem for the same dryer
    Aug 04, 2009 | Kenmore Elite HE4 Electric Dryer
    Kenmore Elite HE4 Electric Dryer Logo
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal De
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
