Question about MSI VR601 Notebook
My laptop is standing o a laptop cooler and still keeps overheating all the time. it works for about a hour and then switches off. If i was playing games i would understand but im working in corel draw. pls help
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
Hi Zelda, its not un-common. You will probably find that it is a build up of dust inside the laptop. So if you know someone with an air compressor, you can take out the battery keep the screen open and blow through the cooling vents underneath and on the sides. If not you could go to a service station where you would inflate your tyres on your car and take your laptop with you and a friend to hold it for you.
Hope that helps
Steve
Posted on Oct 12, 2013
Can't plat need for speed world for a straight hour
Verify that the Fan and vents are free of dust, use a can of Compressed Air the clear the vents, heat sink and fan. Improve air flow from the bottom of the laptop through the machine and out the vents. Use a Laptop Cooler with multiple fans. If necessary replace the Thermal Paste on the Graphics Adapter and CPU. Overheating will cause catastrophic damage/failure to the components. When the Laptop sensors read a specific temp it will shut down to prevent damage. I'm not sure if this freeware program will work but you can try: http://www.filehippo.com/download_speedfan/ ALSO, try this freeware program. RAZER GAME BOOSTER, to disable ALL unnecessary, you select/configure, to improve Gaming Performance: http://www.razerzone.com/gamebooster It may help to reduce heat by stopping some services , reducing the CPU and Memory load.
Mar 13, 2013 | Sony VAIO VGN-CR220E/P Notebook
How do Ifix an overheating problem on a eee 1015pe
The most easy way is to buy a notebook cooler stand. If it's overheating again you must open the case and clean cpu cooler and put some thermoconductor paste on cpu and graphic card.
Nov 17, 2012 | ASUS Eee PC 1015PE
My sony vaio vgn nw250f is overheating, cpu is getting so hot after I switch it on and one minute after it switches off but before it freezes. I have cleaned fan ,replaced thermal compound but after 6...
6 months is about right for the fan to become clogged and need re-cleaning. You could try the basics, which is:
1) Don't operate the laptop on your lap.
2) Ensure the vents are kept clear at all times
3) From time to time, simply blow into the vent holes to dislodge any dust.
4) If you can, use a laptop cooler to keep the temperature down in the laptop.
Sorry, I know overheating laptops are a pain, but it sounds like you are already doing as much as you can to reduce/stop/fix this.
Jul 31, 2011 | Sony VAIO VGN-NW350F/S Notebook
The unit overheated and stopped working
Let it sit out for a while to avoid any heat damage. It should work once again once it has cooled this is a security for the PS3 to protect the internal components. To avoid overheating place PS3 in a well ventilated place where it can get a steady flow of cool air. Do not place it on carpet or any other surface that might insulate the system. Try to reduce play time take a break once in a while. If you would like longer game time buy an air cooler that hooks up to the PS3 and increases airflow and keeps it cooler longer.
Feb 26, 2011 | Sony Playstation 3 (PS3) Console
When i play NFS MOST WANTED game, the display crashes. please help me to resolve it. computer specifications: HP 15.4" WINDOWS 7 HOME BASIC (64 BIT) 3GB RAM 300GB HD 1GB ATI premium Graphics...
you may want to check the temperature inside you computer. While playing the game better check if the temperature will not rise. See if all fans or blowers are working. You may need to install additional fan to keep mainboard cool and prevent it from overheating.
These are most common for those laptop with higher specs.
There are laptop stands available with cooler in the bottom. This is most advisable for users who will use their laptop for computer gamings and programs requiring graphics displays.
Jan 22, 2011 | HP Pavilion dv6000z Notebook
My arrow keys will work for a little bit and then they will stop working. If I am playing a game, the character will move by itself, sometimes I can hit the arrow key that the character is moving and it...
Deadeye, the problem isn't with the keyboard but with the motherboard overheating. Grab a cheap laptop cooler from geeks.com and you will find that this will keep the laptop cool enough to play a game without key creep taking over. The DV9000 laptop from HP is notorious for overheating and dying due to improper ventilation and you need a laptop cooler no matter what else you do.
Otherwise your laptop could simply overheat and the solder will separate.
Oct 26, 2010 | HP Pavilion dv9000z Notebook
The laptop suddenly stops working . Sometimes after one hour, sometimes after 4 hours. Like you shut down the TV. What is wrong?
THis is called hanging. Most common cause is your display driver. Try re-installing the display driver and see if that fixes it.
Mar 21, 2010 | HP Compaq 8510p Notebook
Laptop keeps hanging
TRY TO BACK THE OLD ONE IF IT IS OK THE NEW ONE ARE NOT COMPATIBLE
Aug 18, 2009 | HP Compaq nx6110 PC Laptop
Advent overheating
you'll need a laptop cooler pad
Jan 24, 2009 | Toshiba Satellite A25-S207 Notebook
MSI VR601 Notebook Logo
22 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
