On my 1999 Olds Intrigue I have never had to turn on my lights at night. All night time driving lights come on automatically until recently. Now only the headlights come on.To get the dash lights,tail...
Without testing i would say you have DRL control module problem , But that would just be a guess .
In the night mode, the DRL ambient light sensor senses darkness. Then, the DRL module turns off the front turn lamps and turns on the headlamps through circuit 10. The DRL module also turns on the park, side marker, license, and tail lamps. If the engine should stall with the DRL control module in the night mode, the DRL control module will turn off the headlamps and leave the side marker, park, license and tail lamps on while the engine is being cranked. The headlamp switch operates as usual.
The Daytime Running Lamps (DRL) control module is designed to automatically operate exterior lights depending on outside light conditions. The DRL control module operates in two modes, the day mode and the night mode. In the day mode, the DRL ambient light sensor senses daylight. Then, the DRL control module turns on the front turn lamps (non-flashing) if under the following conditions:
• The ignition switch is on.
• The headlamps switch is in the OFF position.
• The park brake is released.
The brightness of the Vacuum Fluorescent (VF) displays is controlled by two signals: the park lamps on signal (circuit 230) and the VF dimming signal (circuit 308). With the park lamps on, the VF display of the radio, heater, A/C control (with RPO CJ2) and the instrument cluster will dim for nighttime viewing. When the park lamps on signal is not present (park lamps off), the VF displays are at high brightness for daytime viewing. When the park lamps are on, the I/P lamp dimmer switch provides a signal (VF Dimming Signal circuit 308) which controls the brightness of the VF displays when the I/P lamp dimmer switch is adjusted.
Do the Daytime running light's work ?
Did you ultimately resolve the problem? I am also not able to find how to use the light
i have the same question how to on the light during night of taksun=613a
There is no switch as mentioned in the manual. So don't try.
