Question about Sewing Machines
Light will come on when turned on but machine will not sew??????
    Problem Solver:
  • 8 Answers
It could be your foot control has gone bad or the connection between machine and foot control have a problem.
Posted on Oct 28, 2013
I have a Viking 6690, it will sew when pedal is pushed but the machine does not turn on.
Not understanding your question. Not sure how the machine sews if it doesn't turn on...
Are you saying the light doesn't come one? If so, the light bulb is probably burned out and needs to be replaced.
Dec 04, 2017 | Sewing Machines
What light bulb fits 4300 Morse sewing machine
The Morse 4300 and 4400 use the same small 15W screw in light bulb as many other sewing machines. This is one vendor: https://a1sewingmachine.com/LB716sm~Bulb%2C+15+Watt+Small+screw+in+base.htm . Another source is https://www.sewingpartsonline.com/light-bulb-white-7scw.aspx .
I hope this helps. However, if you have a bulb in the sewing machine, take it out and confirm that it is the screw in type. (If there is no bulb, look at the socket for some turns for threading in a bulb.) If the bulb or socket doesn't have threads, then look for a 15W push and twist bulb at sewing machine parts suppliers.
Nov 08, 2017 | Sewing Machines
I step on the foot pedal, the light turns on, but why won't it sew?
read your instruction manual .I own several and none turn the light on when stepping on the control pedal . all have a separate switch so the light is on to see before sewing . look up the manufacturer online and ask their tech support .
Aug 16, 2015 | Sewing Machines
No power to my sewing machine
If you have had your Janime machine for quite some time, the pedal may have simply worn out.
Dec 18, 2013 | Janome L-344 Mechanical Sewing Machine
No power to machine, checked power cords were all plugged in properly and plugged into outlet, still can not turn on light or machine to operate
If you have a light to light up the sewing area, this light has to be on or the machine will not work.
The switch should be next to were the cord goes in the machine.
Jun 22, 2011 | Singer 3116 Simple
I have a Juki MO-655. I just threaded the machine, plugged it in and when I turn it on the light comes on but the motor doesn't start when I press the foot control. I have all the doors on the machine...
I also have the Juki M)-655. Look at the power button; it should have 3 positions. First position turns the power switch Off, second position turns the power switch on and it will sew, third position turns on both the power switch and the sewing light. Several times I have thought I turned on the power switch to sew only to realize it was not in the second position. Hope this helps.
Jun 14, 2010 | Juki MO-655 Mechanical Sewing Machine
Machine wont work
PLUG IT IN BETTER. Your plug is loose at the machine or the wall.
Apr 06, 2010 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machine light flickers/dims while sewing.
There may be a loose connection. If this is a brand new machine the warranty should cover the repair.
Check the return policy at Sears/K-Mart as it may be better to return it for a replacement.
Feb 20, 2010 | Kenmore Sewing Machines
The sewing light on my shark intellisew 9110 has decided it's created purpose is to be a tiny timing light that strobes any time the machine is on. I have turned of, turned on, unplugged, & replugged...
I would contact the manufacturer on this one-or maybe the shop who sold it to you. If under guarantee it may well need to be returned. Look in your manual for contact details.
Oct 03, 2009 | Sewing Machines
Sewing Machines Logo
18 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
