Question about Car Audio & Video
How do you fit the belt to a Kenwood P78 turntable?
techman
  • 3130 Answers
SOURCE: fixing a Kenwood KD 491F turntable
The reason why the audio is low, is that todays receivers do not have a phono input, and these types of inputs are differant then the ones of today. You will need whats called a phono preamp, and one should still be available from Radio shack. Or you can go here to find out more about them: http://www.phonopreamps.com/ To reseat the belt, take off the rubber mat on the turntabe disc. Install the belt around the inside ridge, there should be a couple of holes on the platter disc. Install the patter back onto the center spindle. Turn the platter around till you see the motor pully through one of the holes in the platter. Take the belt that is around the turntable platter, and pull it over to the motor pulley. Good Luck
Posted on Jun 15, 2007
pgh_pa_guy
  • 2992 Answers
SOURCE: Belt broken; how do I fit in a new one?
I believe the platter simply lifts straight up off the spindle. Put the new belt on the platter and reinstall it. Then, working through the access hole in the platter, put the belt around the motor drive shaft. Rotate the platter a couple of revolutions to make sure everything's seated properly and you should be back to spinnin' the hits in no time!
Posted on May 04, 2009
  • 104 Answers
SOURCE: how do i put turntable belt back on?
you must first get the platter off [the bit that you put the record on ]
this will prise off with equal pressure on both sides but remove the rubber mat on the platter first [it might have a little clip on the centre spindle if so just get a screwdriver and push the clip off ] then just jiggle the platter with your hands until it frees , when off you should see a small round disc thats connected to the motor that turns the platter via a rubber belt , you just connect the new belt around this and then connect the other end to the platter very fiddly , not being familiar with kenwood turntables i could be totally wrong here and the belt might go to another pulley in which case you might need more than one belt , your best bet is to get the platter off and let me know what it looks like
Posted on May 23, 2009
  • 7 Answers
SOURCE: Kenwood Trio Turntable belt broken.
I have them listed as item 250423608612 on Ebay .. softwaredivision
Posted on Feb 12, 2010
STYLUSCITY
  • 271 Answers
SOURCE: I need to fit the replacement turntable belt on my
Hi, we have all Kenwood belts in stock. What model do you have. Cheers John. Styluscity@gmail.com
Posted on Aug 10, 2011
I have two problems. One: Does the Kenwood KD34R Turntable does it need a system cord? Two: I have a Kenwood KD491/492F turntable, it drags. It has a new belt. Please help. Thank you.
just had that problem when i replaced my belt on a pioneer pl600 turns out there was residue from the old belt on the drive pulley making the belt ride on the edge of the pulley instead of in the groove there is also two adjuster screws under the turntable that u took off to replace the belt with these u can adjust the speed manually was told that by a repair person from vintage electronics great place online for help
Sep 29, 2013 | Kenwood Audio Players & Recorders
I need a kenwood P28 turntable belt drive.
If a belt cannot be obtained from Kenwood, a computer search for turntable belts will turn up several sources
Sep 24, 2012 | Audio Players & Recorders
I need to fit the replacement turntable belt on my Kenwood stack system record player
Aug 09, 2011 | Kenwood Audio Players & Recorders
I have new belt and needle for kenwood 38r turntable how to install them
Belt is easy, Just remove the base, and change the belt.
Needle change is done by cartridge change. remove the old cartridge and insert the new one with the new needle.
Mar 18, 2011 | Kenwood Audio Players & Recorders
Kenwood KD-491F belt come off How do I put it back?
You have got to lift the table on which the vinyl is placed underneath you will find the belt laying loose on the bottom of the table is a pulley on you fit the belt then on the right hand side or rear is the pulley on the motor which the belt also has to be fitted then carefully lower the so as not to let the belt come off again this should provided the belt is not stretched or snapped then it will have to be reaplaced
Oct 11, 2010 | Kenwood KD-291RC Turntable
Feb 07, 2010 | Audio Players & Recorders
Fixing turntable
go to this site as if the belt came off it may have stretched in which case it will re-occur? http://www.needledoctor.com/Online-Store/Turntable the belt goes round the inner ring under the turntable platter and onto a little brass capstan on the motor. fit it on the capstan motor first then onto the inner ring on the platter. good luck.
Sep 06, 2009 | Kenwood KD-291RC Turntable
My KD-291RC has power but my turntable wont turn. I touch the needle and I can hear its on and when I move the arm towards the record or set it on it it will not turn. Help?
Your turntable is belt-driven, it's likely that the belt just fell off. The belt lives under the turntable. On my turntable (a totally different model) the turntable lifts off.
Apr 13, 2009 | Kenwood KD-291RC Turntable
Stylus for a Kenwood Belt Drive Turn table
I suggest try 'Lpgear@yahoo.com' There is a long list of Kenwoob turntable cartridges & needels. I hope you find your needel.
Sep 18, 2008 | Kenwood KD-291RC Turntable
Fixing a Kenwood KD 491F turntable
Jun 15, 2007 | Kenwood KD-291RC Turntable
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
