Question about Panasonic Heating & Cooling
12000 BTU ion Panasonic Panasonic fan indoor fan ghost fast and then slow and again
  • 148 Answers
Capacitor need replace
Posted on Nov 10, 2013
Speed boy
  • 76 Answers
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
  • 5 Answers
SOURCE: fan is working on inside unit and also on
you are most likly short or out of refrigerent which mean you have a leak somewhere find a refirgeration mechanic.. if need be fill it with nitro to find the leak
Posted on Jun 30, 2009
  • 45 Answers
SOURCE: frigidaire fac127p1a 12000 btu compressor
The compressor is probably going out on either a pressure related or heat related overload. Both are a result of low refrigerant. There may be a low pressure safety swich that protects the compressor. Otherwise it may be an internal thermal overload that is tripping. It resets itself and comes back on. The thermal overload heats up and shuts off the compressor to protect it from too much heat which is gernerated by not enough refrigerant in the system to keep the compressor cool. It may be cheaper to replace the unit than have someone try and fix it. It is pretty time consuming and you cannot try it yourself unless you have an EPA Certificate to buy the refrigerant. Check with your local appliance repair man to see if he will tackle it.
Posted on Jun 05, 2010
  • 5 Answers
SOURCE: Soleus 14000 btu air 12000 btu heat
Hi
Your text "will not blow out" indicates lack of air flow.
There are two posiblilities:
The upper blower wheel has failed (evaporator coil) OR the lower blower wheel has disintegrated (condenser coil in cooling mode) - which is very common on this Soleus Air model. The blower motors are very good and rarely fail.
Unplug from outlet, remove the six phillips head screws which secure the back to front of the appliance. Look for many broken pieces of your blower wheel.The proceed to www.soleusparts.com and order a blower wheel replacement kit(s).
Problem solved!
Posted on Jul 09, 2010
heatman101
  • 43501 Answers
SOURCE: Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Posted on Jul 21, 2010
Testimonial: "Thanks for the speedy reply and your time."
My gree ac 12000 btu after 2 hour running ******* pipe is frosting .and slow slow indoor unit being fully frost .what to do?
get in a technician to check gas pressures as it may be low on gas
the frosting pipe will be the ******* line where the liquid turns to gas and a dirty evaporator fins
Jun 20, 2016 | Miscellaneous
Not cooling good and has an odd smell.... We've repaired a leak in freon in 2 places in the last 2 months!! ugh!!! I'm so frustrated with this thing.... it was cooling like a dream when we first installed...
Where were the leaks in the system. If they were in either the indoor or outdoor coils, I would replace the entire system. If they were in the refrigerant lines that connect the indoor and outdoor units, I would replace the line set only.
Oct 29, 2013 | AMVENT 12000 BTU 1 Ton Ductless Wall Mount...
I have a contractor that wants to install a 36000btu outdoor unit(model # mh080fxca4a) and two indoor 18000btu indoor units(model #mh052fnca). What would be the output of the outdoor unit? The contractor...
Yes it rated for a maximum out put of 36,000 btu (3 ton) with the right indoor fan coil units which based on the model numbers should give the 36,000 btu's combined when both fan coil units are on, otherwise 18,000 btu's (1.5 ton)per fan coil.
Aug 23, 2011 | Samsung Heating & Cooling
HI there, I have a Goldstar WG1205R 12000 BTU window air conditioner that has no filter, blows slightly cool air and the fan power is very weak for 12000 BTU's How can I improve the performance of...
Sounds like you have a 220 volt air conditioner plugged into a 120 volt outlet.This will cause the conditions you are describing.
Put a filter on it please.
Jul 10, 2011 | Goldstar Heating & Cooling
Where does the water drain out of the unit on the frigidaire 10000-12000 btu and the 22000-285000 btu units?
The unit should be angled back to the outside. The water will run thru a tube from the indoor coil to the outdoor coil, then most fan blades have a slinger on them that picks up the water and throws it on the out door coil, which makes it more efficient but after time the water and dust will pile up on the coil and require cleaning at some point. If you clean the coil you can extend the life of the unit quite a bit. So you may not get any water to drip outside.
Jul 02, 2011 | Frigidaire Wall Room Air Conditioner...
How many tons is my unit?
divide your btu rating by 12000. (1 ton = 12000 btu)
For example - a 24,000 BTU Air Conditioner is a 2 ton unit. 24000 divided by 12000 = 2
A 18000 btu air condtioner is a 1 1/2 ton unit 18000 divided by 12000 = 1 1/2
you can find out your btu rating by looking on the tag on your unit.
Jun 07, 2011 | Heating & Cooling
Lg 12000 btu air conditioner inverter is not working and the led 6 times.thanks
This alarm state is a CH 06 alarm.
Indication for the Indoor unit pipe temperature sensor (thermister) not plugged in or out of calibration.
This alarm will also occur when the unit gas charge is to low and the indoor unit temperature reached a temperature of -5°C for longer that 30 sec. It will switch the machine off.
Mar 21, 2010 | LG Electronic Window Air Conditioner
I just installed a ductless mini split 12000. when I put power to it the outside unit compresser runs no fan the led read out just blinks very fast the remote does't do any thing
One thing you need to check is Polarity. the 2 wires red and white, need to be on the same terminals inside as they do outside. this is very important.
Oct 28, 2009 | LG LS-L1210HL 12000 BTU Heat and Cool Mini...
Good luck.
Wouter.
Oct 21, 2008 | Sanyo 09KS51 Mini Split Air Conditioner
Heating & Cooling Logo
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
