My pensonic color tv has no sound i turn on the volume to max level but still no sound my tv model hg-1477sf
    Top Expert:
  • Televison & ... Master
  • 75,304 Answers
Check its speaker first. If found OK, check and replace damaged component/s at its audio output section circuit. If you're sound in electronics and If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 12, 2013
4 Suggested Answers
  • 145 Answers
SOURCE: Diagram TV Samsung TXE 1970
have you tried physically unplugging the unit from the wall. wait 2 minutes. this resets the microprocessor computer part of the tv. then plug it back in. fixed. the computer is confused. unplug. plug back in
Posted on Nov 14, 2009
  • 36 Answers
SOURCE: no clear sound from speakers
Use a audio signal tracer to pinpoint the distorted sound location,you can use an amplified pair of computer speakers.Or request the complete 9mb 126pages schematic diagram from my personal server at computec40@hotmail.com
Posted on Nov 21, 2009
gopakumarg43
  • 75304 Answers
SOURCE: Jensen color tv model ts2750j volume is maxed out but stll can't hear it
Check its speaker. If it is found OK, check and replace damaged component/s in the audio output circuit inside.
Posted on Oct 04, 2012
I have pensonic led-2416 diamond cut tv but the remote is lost what can ido,if i plug my tv its only a red color in power on.not working
Google TV remotes and there are several choices there. You can order a universal one and then program it for your TV.
Jan 10, 2018 | Televison & Video
Pioneer vsx 52
I am trying to work out which has got the high volume.
If it is the Pioneer then it could be the volume control chip that is faulty. These days volume is no longer determined by a control that adjusts the signal level. The signal is passed to a chip and the volume control setting information is also passed to the same chip. If the chip goes faulty then the volume will sometimes go to max, regardless of the volume control setting. This can also apply to the TV sound as well.
If the sound level is high on other functions of the receiver, such as the radio, then it is certain to be the sound volume control IC.
Nov 10, 2017 | Pioneer Elite VSX-52
Oct 04, 2012 | Jensen TS2750J TV
My tv has no sound
increase the volume to max level .close yourself to TV speaker and listen.if could not hear anything,just turn it off and turn on if you could not hear at least pop sound from the speaker,you will have to replace new speaker.if you are able to hear Buzz noise or very low sound ,sound circuit has to be repaired.
Jun 15, 2011 | JVC Televison & Video
Low Volume despite High setting on TV
HI I am having the same problem. tv sound is fine, then fades so that 50 is the only sound volume to hear the show. It happens intermittently. Did you get your's solved? thanks
Jul 06, 2010 | JVC AV-27050 TV
Have to turn the volume near max on my Onkyo receiver to hear TV
it sounds like a source level adjustment refer to your users manual and see if there is a way to turn the SLA up and if not then a small amp can be bought or purchased to boost the sound from the tv. check out the Fiio E5 for examples it might just do the trick
Feb 18, 2009 | Onkyo TX-SR500 Receiver
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
WON'T CHANGE CHANNELS ADJUST VOLUME OR SHUT OFF
If the volume buttons work when using the Radio, then the buttons on the Remote are fine.
Now if the volume on your TV is set to MAX and you can barely hear it.
The issue lies with your TV.. ()
Now if I understand correctly or if I am to assume you are using a Reviever.
If the reciever is used for all volumes... If this is the case.
I also assume the volume on the TV Speakers is set to off
Therefore when you use the Radio/DVD the volume control is using the Reciever volume.
and when you switch to TV it uses the TV volume thus the TV volume is not gonna work as well.
2 scenarios
1 The TV volume even at max is not giving you enough power to get the low receiver volume
2 the Receiver volume is at max and barely audible.. if this is the case just manualy adjust your TV volume to get it to a decent sound level.
Hard to explain but I know the 2 issues can be fixed.
Apr 21, 2008 | Logitech Harmony 550 Remote Control
Volume turned to MAX for almost no sound from record player
You will need to purchase small box that converts your phono magnetic cartridge level output to a higher line input level before it goes into the TV input jack. Radio Shack used to sell a small amp for about $20 that was made just for that purpose and was called a stereo pre-amplifier and was model number SPA-50 and it plugged into the standard wall outlet to get power. Back in the "old" days when phono magnetic cartridges first became popular some of the older home stereos had only the ceramic phono style inputs (or an aux. input) which were about the same input level as a tape input or aux. input (or TV input) and so you would have to use one of these adapters to boost the newer magnetic cartridge signal up to the same level as a ceramic cartridge in order to use a new style of phono. This will fix your problem if you can find one at Radio Shack or some other place, perhaps on the internet. Hope this helps you.
Nov 20, 2007 | Sony STR-DG510 Receiver
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
