Question about Epson Stylus CX3200 All-In-One InkJet Printer
I have the same problem...what has anyone else done?
  • 3 more comments
  • laketoe Apr 23, 2009
    my printer makes a nasty sound and then a "Printer Error" message followed by "see your documentation and call service if necessary" appears
    No paper jam.
    Makes the sound when I first turn it on.
    Tried to turn it off...no luck.
    Can't seem to find the spot where the noise is coming from.
  • adi May 11, 2010
    is it happening when you first turn it on?
    or making a print job
  • inkypete May 11, 2010
    Nasty sounds are never good. Have you had a paper jam?
  • adi May 11, 2010
    what is the problem your having?
  • 526 Answers
1. Look inside, and see if a tan colored belt is secure and not loose. if you are able to move the belt and the printhead does not move, it means the clip on the printhead is damaged. Really not worth repairing.
2. since its giving you a printer error and not a scanner error, then most likely the printhead is in the cleaning assembly and the locking mechanism will not release. it could be a simple as manually lowering it. Look in the printer, just to the left of the printhead, there should be a lever in the up position, with a pencil or maybe a small screwdriver, see if you can move it backward (toward the front of the printer) and manually move the printhead left and back to right, turn the printer back on and see if it helps.
Posted on Apr 23, 2009
  • Kate756 Feb 16, 2011
    Thank you for the tip, I've just followed your instructions. The tan-coloured belt was fine, so I tried following tip number 2. Our printer had previously jammed and then made the same horrible grinding noise/showed a red error light when switching it on as the person above described. Being a complete novice, was not really sure what I was doing, but I moved the ink cartridges to the left; discovered the print head underneath; fiddled with a pencil as directed and the little lever suddenly dropped back down into place! Yippee! I think it must have got stuck and was grating against the cartridges. The cartridges moved back to the right and slotted in much further along. It all sounds normal now when I switch on and the nozzle check was fine. Thank you so much. Very inky, but very grateful!
Thanks for the help !! Dose anyone know what code dOnE mean on a Jeep Wrangler ?
only reference os far is the wrangle has finished reading fault codes
join this free jeep wrangler forum
lots of good help and information there
Jeep Wrangler Forum Jeep Wrangler Owners Community
Oct 15, 2016 | Jeep Cars & Trucks
The key is programmed to the car and unlocks doors and locks them but when trying to start the car the immobilizer kicks on and shuts the car off. how do I reset the key? ive done it before by doing...
get the car to run then remove the chip from the key and remove the shroud around the steering wheel and tape the chip to the transponder ,then its permanently activating the immobilisor and no more problems .Just buy a decent steering wheel lock in case anyone works out whats been done .nudge nudge wink wink dont tell anyone what you have done not even your own mother
Nov 10, 2012 | 2006 Volkswagen Jetta
Has anyone ever done fuel injectors on a 1993 chevy K3500 p/u w/a 6.5 liter turbo diesel?If so is it hard or something I can do myself?
not a diy project as the injectors have to be calibrated to crack at a specific pressure
Best take it to a professional diesel shop where new tips can be fitted and the calibration done correctly
Feb 23, 2018 | Cars & Trucks
Want to clean egr valve myself. has anyone done
Thats simple, Just remove it, Get an old tooth brush and some carb cleaner, spray inside egr, and port where it was bolted, Not to excessive though, then take tooth brush to knock debris loose, Then spray again to insure clean.
Jun 09, 2010 | 1995 Honda Accord
The belt has snapped. Does anyone know how to
If there is no removeable rear panel then it can be done from the top, it is not easy, but I have done it in the past.
If you tilt the washer towards you, it gives more room to get your hands and arms in to fit the belt.
Otherwise it means removing the rear half of the cabinet.
Hope this helps.
Jan 25, 2010 | Zanussi F1245W Front Load Washer
2001 Hyundai Elentra window replacement
one of those clips moves in and out,you have to push that side in first.then the other one will fall right in.
Jun 01, 2009 | E-Machines eMachines Desktop PC
Timing a Panasonic AG-1970 VCR
timing the AG-1970 is best done with a service manual. it has several diagrams in it which show how to time the gears. it may still be available from Panasonic.
Mar 13, 2008 | Panasonic Televison & Video
Does anyone know?
Have you looked it up in the manual:
http://yalda.us/CVA615_us[1].pdf
Feb 11, 2008 | Miele CVA615 Espresso Machine
Epson Stylus CX3200 All-In-One InkJet Printer Logo
154 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
